Serviio broken After OS X 10.7.4 update
Ive tried to re-install Serviio but it does not change. It seems to keep crashing. The console loads fine and is online but the other part of the app keeps bouncing in the dock. My Sony Bravia sees the server but it seems to drop in and out of connection as you try to navigate through the menus as 1 second it's there but as you navigate it suddenly tells you it can't find the server and kicks you out.
My system worked seamlessly before I updated from 10.7.3 to 10.7.4
Please help!,,,
Please help!,,,
