Chromecast
freaknik
Post Sat Jan 27, 2018 5:26 am
Chromecast
Using chromecast mostly nowadays.
On my android I go to Serviigo, set external video player and medium content quality, pick a show or movie, play through localcast, and it plays anything.
Mediabrowser does not work very well with the chromecast. No music will play at all. And the chromecast casting icon only appears every other time mediabrowser is used for video. In other words watch a show, exit, sign back in, go to next episode, very buggy.
But serviigo works perfectly. :mrgreen:
Post Sun Jan 28, 2018 3:53 pm
Re: Chromecast
I made some improvements to 1.9.1. But the missing button will be there until Flowplayer fix it. https://bitbucket.org/xnejp03/serviio/i ... disappears
freaknik
Post Sun Feb 18, 2018 6:19 pm
Re: Chromecast
Great job on 1.9.1!
It installed over the 1.9 perfectly and now audio works in media broswer!!!!!!!!!!!!!1111111111
SO happy and excited, thank you for sticking with it.
Working much better than 1.9 already and only had it installed 5 minutes.
carpler
Post Mon Nov 05, 2018 9:09 pm
Re: Chromecast
Looking for long time to understand if and how Serviio support Chromecast.
I think that if so, there must be a guide somewhere...
What I need to be Chromecast working with Serviio?
In this thread freaknik talks about Serviigo, but I don't know if the app is still developed because I can't find it on Playstore...
I need the Pro version? I just installed the last version (1.10) of Serviio and I got 14 days trial period for pro version, but I don't know how to test it...
Can someone give me some answer?
Many thanks!
Post Mon Nov 05, 2018 9:29 pm
Re: Chromecast
Serviigo, to my understanding, was pulled from the Play Store for an update, and hasn't passed permission yet from Google to deploy. Yes, it requires Serviio Pro to work.
I don't know a lot about Chromecast, as I never liked the idea of having to use my phone or tablet to control it. While I have an Android phone, I've never used Chromecast. I have the older version of Serviigo on my phone, and I have it set to use VLC as the video player. However, even connected to my home network on a 5 GHz wireless router, I can't play a 4K video on my S8. It constantly buffers, so it can't handle the video bitrate. 1080 or DVD quality is no problem.
JNehru
Post Fri Nov 16, 2018 1:18 pm
Re: Chromecast
Great job. It working!
freaknik
Post Sat Nov 17, 2018 9:52 pm
Re: Chromecast
I have paid bubbleupnp and server application on the same server as serviio. It works like a champ, can do playlist, shuffle play, search, etc.
Just leave Serviio profile on your phone as generic and it plays all since version 10.
Flawless victory!
carpler
Post Sun Nov 18, 2018 5:36 pm
Re: Chromecast
freaknik wrote:I have paid bubbleupnp and server application on the same server as serviio. It works like a champ, can do playlist, shuffle play, search, etc.
Flawless victory!
I think that BubbUpnp Server should be useless: Serviio would be able to do transcoding when necessary, but maybe it does not have a suitable app to be able to recall it ...
freaknik
Post Sun Nov 18, 2018 8:52 pm
Re: Chromecast
In a perfect world you are right. In a perfect world the movie should beam Jessica Alba out of my brain and in to my car.....
Just install it, works for everything.
If your network is slow like mine, the bubbleupnp since it has own server allows you to control transcoding speed in the app. I use the fastest setting, ultrafast.
Put another way, the max my chromecast2 can produce is 720p, and imo it looks awesome everything I have played.
Even some higher def wbem files I had since the new version 10 those play too.
I do what I want but if I were you I would install the server and be happy.
So many times using serviigo and localcast I got the dreaded poop of doom, with paid bubblesoft and server I don't have to get off the couch...
#WINNING!!!!!!!!!!!!11111111
downlow
Post Sun Jan 20, 2019 4:11 pm
Re: Chromecast
freaknik wrote:In a perfect world you are right. In a perfect world the movie should beam Jessica Alba out of my brain and in to my car.....
Agree. Just installed a Chromecast and the BubbleUPnP server and it's working very well. One issue with Serviio is the Chromecast doesn't show up as a DLNA device, so I don't see any way to tweak it from there. BubbleUPnP on my phone and their server SW on the server PC is doing everything I want. It still uses Serviio as the media server and it's index, so the BubbleUPnP service is just a supplement to the process that adds function and features. One tip I'd suggest is to use the "all user" installation of BubbleUPnP. I tried "single user" but encountered installation problems on Windows 10. All user installed cleanly and worked immediately.
freaknik
Post Mon Jun 17, 2019 6:44 am
Re: Chromecast
Cool. My server had win7 so single user was no problem.
Chromecast doesn't show as dlna device because it isn't one lol.
Return to User experiences
