Serviio 1.6 laaggy and displays same movie multiple times
billforesman
Post Fri Jan 29, 2016 6:21 pm
I'm using an Samsung UN75ES9000 series television with 1.6 and just loading the movie list takes FOREVER...
In addition it displays the same file (movie) multiple times even though there'ss only 1 file.
rgsurplus
Post Sun Feb 21, 2016 4:35 am
Re: Serviio 1.6 laaggy and displays same movie multiple time
Im on a crappy windows 7 system 64bit
my hardware is good, sony box is wired not running wireless,, drives are 15k sas so fast ,not as fast as as ssd ,but a good start
16gb of memory
no transcoding ,very fast load but must wait a bit to fast forward
no ghost files,, matter of fact naming was fixed with upgrade ,,
try fixing database to remove ghost files,if using wifi change router channel and the wifi adapter channel
wifi signal testing soft is out there or move to cable, yucky those ugly wires
and as always change your log files to show all, can't remember how its done ,but its easy LOL
remember, you now are using the best dlna software out IMO
Return to User experiences
