Updates needed for sony2010 profile
crash369
Post Fri Oct 12, 2018 5:54 pm
Hello
Not sure, if this is the right place to post, but I think there are some updates that need to be made to sony2010 profile. For reference, I have a KDL-xxHX800 TV.
Every time I install a new version of Serviio, I have to change the following:
  • add `<Matches container="*" vCodec="h265"/>` to "Transcode" list to support newer compression.
  • move all `aCodec="eac3"` from "Remux without transcode" to "Remux and transcode" audio block for all containers, since this TV can't handle eac3 audio natively.
  • decrease `maxVBitrate=17000` to something lower. I had to go to 13000 for the TV to stop stuttering on playback of certain high-data scenes.
Thanks!
Post Fri Oct 12, 2018 9:27 pm
Re: Updates needed for sony2010 profile
I suggest creating your own personal profile that won't get replaced at update time. See this page: http://www.serviio.org/index.php?option ... icle&id=16
If you want to have your profile changes persisted across upgrades, you can add new profiles to a file config/user-profiles.xml. All the syntax and rules described below apply to this file as well.
crash369
Post Sat Oct 13, 2018 8:24 pm
That's good to know. Although I still feel the first 2 points should be updated in the official release since those TV models don't support h265 or eac3.
Post Sat Oct 13, 2018 10:04 pm
Some profiles are developed and maintained by someone other than the Serviio developer, and he includes them when someone provides them. If he has time he might take a look, but hopefully someone with the same equipment can help modify them. Your comments in your post could be of assistance there as well.
