Post Sat Feb 10, 2018 12:07 pm
Profile for Sony KDL-40NX715?
The standard profile for KDL-40NX715 works fine most of the time, but not with recordings from Vu+ Solo4K Receiver. The TV shows/recognizes "AVC" and Serviio thinks it has not to transcode. When I try to playback the recordings the time stays at 0:00 (black screen) and nothing happens. How can I tell Serviio to transcode AVC videos too?
I'm sorry if my english is bad
Here is the info from MediaInfo for an example video:
Allgemein
Complete name                            : J:\Serviio\Paw Patrol\20180108 0704 - SUPER RTL HD - Paw Patrol - Helfer auf vier Pfoten.ts
Format                                   : MPEG-TS
File size                                : 1,23 GiB
Duration                                 : 25 min 59s
Start time                               : UTC 2018-01-08 06:04:04
End time                                 : UTC 2018-01-08 06:29:33
Overall bit rate mode                    : variabel
Overall bit rate                         : 6 757 kb/s
Menu ID                                  : 11931 (0x2E9B)
Format profile                           : High@L4
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Ja
Codec ID                                 : 27
Duration                                 : 25 min 58s
Bit rate                                 : 6 035 kb/s
Width                                    : 1 920 Pixel
Height                                   : 1 080 Pixel
Frame rate                               : 25,000 FPS
Scan type                                : MBAFF
Scan order                               : oberes Feld zuerst
Bits/(Pixel*Frame)                       : 0.116
Stream size                              : 1,09 GiB (89%)
Codec ID                                 : 6
Bit rate mode                            : konstant
Bit rate                                 : 384 kb/s
Channel(s)                               : 2 Kanäle
Sampling rate                            : 48,0 kHz
Frame rate                               : 31,250 FPS (1536 SPF)
Delay relative to video                  : -1s 158 ms
Stream size                              : 71,4 MiB (6%)
Language                                 : Deutsch
Service kind                             : Complete Main
Andere
ID                                       : 320 (0x140)-100
Format                                   : Teletext
Language                                 : Deutsch
Menü
List                                     : 300 (0x12C) (AVC) / 310 (0x136) (AC-3, Deutsch) / 321 (0x141) () / 320 (0x140)-100 (Teletext, de) / 330 (0x14A) (DVB Subtitle) / 311 (0x137) () / 312 (0x138) ()
Language                                 :  / Deutsch /  / Deutsch
