Dual Profiles
shadybrothers
Post Fri Jul 30, 2010 2:45 am
Dual Profiles
Hi Guys, I have been using serviio religiously with my Samsung LA46B650 for months now with no complaints - I have moved my PS3 to another room and it is now hooked up to a non DLNA Samsung.
I have successfully had it streaming from my WHS box that has seviio running using the PS3 profile. While I have the PS3 profile active, the B650 is unable to stream, I believe that this is due to the profile incompatibilities.
I was wandering if it was possible to create a profile with both the Samsung B Series + PS3 characteristics so that both devices are able to take advantage of streaming media.
Cheers,
Post Fri Jul 30, 2010 8:12 am
Re: Dual Profiles
Some profile management improvements are planned in future.
shadybrothers
Post Mon Aug 02, 2010 2:13 am
Re: Dual Profiles
Excellent news, I look forward to future updates.
In the mean time, has anyone been able to serve to 2x Samsung TV's at the same time using the one console?
theone01
Post Mon Aug 02, 2010 4:10 pm
Re: Dual Profiles
I am serving successfuly to 3 devices using the "Samsung WiselinkPro (C series)" profile:
A Samsung TV 46C650 and 2 WD TV Live HD players
with no problem as both devices support more or less same video formats.
Post Mon Aug 02, 2010 5:14 pm
Re: Dual Profiles
all 3 at the same time? Serviio should cope, how does the network cope though? ;-)
shadybrothers
Post Mon Aug 09, 2010 4:31 am
Re: Dual Profiles
Nice one - when the PS3 loads up with the B Series profile selected all *.mkv files are unsupported data.
I have installed PS3MS on my WHS box to run alongside Serviio and have both the TV and PS3 streaming *mkv files.
Serviio does handle better than the PS3MS - their transcoding has a few stuttering issues or corrupted sound files.
Post Mon Aug 09, 2010 9:12 am
Re: Dual Profiles
That's expected, as the Samsung cannot be detected automatically ATM - so it'll use generic profile instead. I hope to sort this out soon-ish.
aeproberts
Post Thu Aug 26, 2010 5:02 pm
Re: Dual Profiles
Just for my understadning.
I have a Sony BDP-s570 BR Player and an xbox 360.
If I have Serviio configured to use the custom sony profile I created, then the Xbox will by default also attempt to use that profile?
Post Fri Aug 27, 2010 8:19 am
Re: Dual Profiles
Yes, unless you select Auto detection (which should work for your devices).
