SeasonVar.ru (Web Resource)
Jurijlv
Post Wed Dec 23, 2015 12:10 pm
Re: SeasonVar.ru (Web Resource)
ka81 wrote:sorry for being nubs, but - how to use/install plugin on OSx ?
As all other plugins, look for necessary topic in main forum. As I remember there is video in youtube as well. Good luck.
ka81
Post Wed Dec 23, 2015 12:33 pm
choosed - http://seasonvar.ru/serial-12701-Elemen ... eason.html
but it says - chosen file is currently not supported (выбранный файл в настоящее время не поддерживается)
pan Oleksiy
vtamc
Post Sun Jan 17, 2016 1:26 pm
Jurijlv
Post Fri Jan 29, 2016 9:37 pm
Since yesterday as of 28 JAN it is not working... sad. Probably again they have made some changes on their website. Hope that someone knows how to fix the problem and will update season plugin.
Thank you.
ivanoff999
Post Sat Jan 30, 2016 7:38 pm
Hi, plugin doesn't works! Need help, thanks
Sony Bravia 2010 - KDL-32EX40B Serviio 1.9.2 Pro on Windows 7 x64 SP1/macOS Sierra 10.12.6/Ubuntu Mate 17.04 x64
victor500k
Post Sun Jan 31, 2016 8:05 pm
The plugin is stopped working. I have the following error:
WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-12470-CHernyj_spisok-3-season.html, waiting for expiry time to try again: Unexpected error while invoking plugin (SeasonVar): Lexing failed on line: 1, column: 8, while reading 'i', no possible valid JSON value or punctuation could be recognized.
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): Lexing failed on line: 1, column: 8, while reading 'i', no possible valid JSON value or punctuation could be recognized.
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:186)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:203)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:191)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:108)
Caused by: groovy.json.JsonException: Lexing failed on line: 1, column: 8, while reading 'i', no possible valid JSON value or punctuation could be recognized.
   at groovy.json.JsonLexer.nextToken(JsonLexer.java:83)
   at groovy.json.JsonSlurper.parseObject(JsonSlurper.java:219)
   at groovy.json.JsonSlurper.parse(JsonSlurper.java:75)
   at groovy.json.JsonSlurper.parseText(JsonSlurper.java:59)
   at groovy.json.JsonSlurper$parseText.call(Unknown Source)
   at SeasonVar.getSourceFromPlayer(SeasonVar.groovy:123)
   at SeasonVar.extractItems(SeasonVar.groovy:66)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
   at java.util.concurrent.FutureTask.run(FutureTask.java:266)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
   ... 1 more
qanatoz
Post Sat Feb 06, 2016 5:51 pm
Plugin fixed. Download latest version (16).
victor500k
Post Sat Feb 06, 2016 8:19 pm
Good job! Thank you very much!
ivanoff999
Post Sun Feb 07, 2016 10:01 pm
Thanks for good job!
urkas
Post Wed Mar 23, 2016 4:42 pm
Спасибо большое за плагин, только столкнулся с одной проблемой:
2016-03-23 19:25:48,855 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-13057-CHernye_parusa-3-season.html?translation=Amedia, will try again soon: Unexpected error while invoking plugin (SeasonVar): Cannot invoke method replaceAll() on null object
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): Cannot invoke method replaceAll() on null object
Caused by: java.lang.NullPointerException: Cannot invoke method replaceAll() on null object
        at org.codehaus.groovy.runtime.NullObject.invokeMethod(NullObject.java:77)
        at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:45)
        at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
        at org.codehaus.groovy.runtime.callsite.NullCallSite.call(NullCallSite.java:32)
        at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:54)
        at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:120)
        at SeasonVar.fetchItems(SeasonVar.groovy:152)
        at SeasonVar.this$4$fetchItems(SeasonVar.groovy)
        at SeasonVar$this$4$fetchItems.callCurrent(Unknown Source)
        at SeasonVar.extractItems(SeasonVar.groovy:89)
        ... 1 more
ivanoff999
Post Sun Apr 03, 2016 6:05 pm
Добрый вечер, со вчерашнего дня перестал работать плагин ver. 16, помогите!
The plugin doesn't works, see attached serviio.log, please help!
2016-04-14 09:29:32,911 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-6246-Tajny_s ... eason.html, waiting for expiry time to try again: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at SeasonVar.getPlaylistURL(SeasonVar.groovy:117)
at SeasonVar.extractItems(SeasonVar.groovy:68)
... 1 more
serviio.zip
(11.12 KiB) Downloaded 514 times
victor500k
Post Sat Apr 16, 2016 10:56 am
Добрый день,
Хочу уточнить - плагин версии 16 перестал работать частично.
Некоторые ссылки продолжают работать, а некоторые нет.
Например, pабочая ссылка: http://seasonvar.ru/serial-12470-CHerny ... eason.html.
Не рабочая ссылка: http://seasonvar.ru/serial-12394-Skorpi ... dash_.html со следующей ошибкой:
2016-04-16 12:57:46,450 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-12394-Skorpion_serial_2014_ndash_.html?translation=BaibaKo, waiting for expiry time to try again: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
   ... 1 more
qanatoz
Post Wed Jun 01, 2016 8:32 pm
victor500k wrote:Добрый день,
   ... 1 more
Fixed, download version 18. Was some problem with missed translations.
qanatoz
ivanoff999 wrote:Добрый вечер, со вчерашнего дня перестал работать плагин ver. 16, помогите!
... 1 more
qanatoz
Post Wed Jun 01, 2016 8:34 pm
urkas wrote:Спасибо большое за плагин, только столкнулся с одной проблемой:
        ... 1 more
Fixed, download version 18 :)
ivanoff999
Post Wed Jun 08, 2016 8:02 pm
Thanks!!!
jornada
Post Thu Jul 28, 2016 9:30 am
Добрый день. С сегодняшнего дня опять перестал работать плагин..
ivanoff999
Post Sat Aug 06, 2016 11:54 am
Да точно плагин перестал работать где-то 3 дня назад, опять кто-то с Сизнвара что-то сделал
serviio.zip
(7.96 KiB) Downloaded 427 times
qanatoz
Post Sat Aug 27, 2016 10:15 pm
Plugin fixed, you can download version 19.
Changes in version 19
  • Some bug fixes after site changes
ivanoff999
Post Mon Aug 29, 2016 4:18 am
Thank you very much! Good job!
Return to Available plugins
Users browsing this forum: No registered users and 70 guests
