Service won't start
flipandboef
Post Sun Apr 17, 2016 12:25 pm
Service won't start
I just installed Serviio, but when running the console I see: Cannot connect to the server, it doesn't seem to be running...
Reading through the forum, checked if the service is running. It's not. When trying to run it, it says it cannot start the service and gives an error 5000 (unclear what that is)
Also removed and reinstalled Java then reinstalled Serviio. Still same result.
As a side-note: Using ZoneAlarm as my FW. Disabled this during installation. Disabling it when trying to run Serviio also did not work.
I know (when it workes) Serviio is a great tool and would love to get it to run again on my new pc.
Windows 10 Home - 64 bit (dutch)
Attached ar the 2 log files I found in the Serviio\log folder
Hope anyone can help?
(11.34 KiB) Downloaded 411 times
derby.log
(712 Bytes) Downloaded 373 times
Post Sun Apr 17, 2016 10:49 pm
Re: Service won't start
There's no errors in that log. It shows a normal startup. Java does not need to be installed, as Serviio installs a version for itself.
That log is fairly small, and doesn't appear to show a shutdown. It does show it recognizing an AVR-X2200W, which I assume is your Denon receiver. Like I said, it appears to be running correctly.
What happens if you use your browser to connect to the console (http://localhost:23423/console)? I am wondering if you are trying to use a console from an older version (before version 1.6)? That console no longer works, as it has been switched to a web based console.
flipandboef
Post Mon Apr 18, 2016 6:51 am
When I goto http://localhost:23423/console, I get a "Page cannot be displayed"
I also noticed indeed that my Denon receiver was detected in the log, so I also thougt it was working. But as mentioned; the console refuses :( As does the service when I check this via Windows services and it's not to be seen from any other system.
As for your question about using an older version of the console; I think this is unlikely? It's a new/clean pc and have downloaded the latests version from Serviio from the website and installed that.
(Unless Serviio by mistake added an old console to the latest version? Doubt that ;))
What I did notice: When starting the console (that gives me the " Cannot connect to the server, it doesn't seem to be running..."), it does not say Serviio at top, but Electon or something?
flipandboef
Post Tue Apr 19, 2016 2:13 pm
Anyone who can assist on this?
I should be able to use a newly installed Serviio I would expect.... ;)
Post Tue Apr 19, 2016 9:39 pm
Try to open the console on your PC's IP address rather than localhost:
http://192.168.0.15:23423/console
flipandboef
Post Wed Apr 20, 2016 5:58 am
It gives the same result as going to localhost I'm afraid....
Post Wed Apr 20, 2016 6:20 pm
Is this the correct IP address to use on your PC?
wlan1 (802.11n USB Wireless LAN Card) and address 192.168.0.15
flipandboef
Post Wed Apr 20, 2016 10:20 pm
That's indeed the local ip where Serviio is installed / should be running on.
It's a fixed ip as are other equipment that have their own fixed ip (same subnet etc...)
flipandboef
Post Fri Apr 22, 2016 3:54 pm
Still no ideas? :cry:
Post Fri Apr 22, 2016 6:33 pm
try to enable detailed log, restart the service / pc and then post the log again
flipandboef
Post Fri Apr 22, 2016 9:26 pm
Enabled the detailed log as described on http://wiki.serviio.org/doku.php?id=detail_logging
Restarted the pc.
Same result; Service won't start. Console won't start. Trying http://192.168.0.15:23423/console still same result, etc...
Looked at the log-folder having the detailed log enabled and I noticed that both log-files were unchanged. Nothing added/changed... (made a copy before and compared them).
Thought le't go crazy and deleted the log-files. Reinstalled Serviio (still same results after) and saw that only 1 log-file "serviio.log" was created.
It had now only 1 line in it:
2016-04-22 23:11:23,054 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
(Disabled virusscan + firewall during all this to be sure that had no negative effect)
flipandboef
Post Fri Apr 22, 2016 9:52 pm
hmmm.... Tried the following:
in \Serviio\bin\ started serviio.bat + serviioservice.exe as administrator. Then in Serviio\console\ started ServiioConsole.exe as admin.
Yes! The console now shows.
However, this I would have to do every time to get the console running. Not very handy (as of cos I want to have it run automatically at startup).
Now there's also more in the logfiles (added them as xxxx2.log) while Debugging is still on.
Think you can see more of what might be going on?
Sure hope you can help further :)
serviio2.log
(37.54 KiB) Downloaded 373 times
derby2.log
(705 Bytes) Downloaded 351 times
Post Sun Apr 24, 2016 1:03 pm
Don't see anything new, but it's still not detailed log.
Also, you don't need to start serviio.bat - it's the same as the service .exe.
you can check if the Serviio service is started and running in the Windows Services tool.
flipandboef
Post Sun Apr 24, 2016 7:25 pm
I did enable the detailed log as described.
The service is not running and also refuses to start as mentioned in my earlier post (something with a 5000 error?)
Post Mon Apr 25, 2016 10:43 am
Hmm ok. so it looks like it crashes / gets stuck when it tries to figure out if another Serviio instance is already running. Looks like something to do with networking (trying to open a localhost socket 44331), but I've no idea what it could be preventing it on your PC.
flipandboef
Post Mon Apr 25, 2016 10:56 am
Me neither I'm afraid....
I'll look some further to see if I can find anything, but if not.... I'm afraid Serviio is no longer an option for me anymore if you or anyone else also are not able to assist on this issue :(
(Really would be a bummer, as I loved the simplicity and power of Serviio)
flipandboef
Post Wed Apr 27, 2016 10:19 am
looked a little further;
In the logging I see:
Service Serviio stopped with the following service error:
Signoff from network
(As I have a Dutch version, hope I translated this correctly?)
Logboeknaam: System
Bron: Service Control Manager
Datum: 27-4-2016 12:13:21
Gebeurtenis-id:7024
Taakcategorie: Geen
Niveau: Fout
Trefwoorden: Klassiek
Gebruiker: n.v.t.
Computer: PRPC
Beschrijving:
De service Serviio is gestopt met de volgende specifieke servicefout:
Afmelden van netwerk
Gebeurtenis-XML:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
<EventID Qualifiers="49152">7024</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2016-04-27T10:13:21.918627400Z" />
<EventRecordID>5594</EventRecordID>
<Correlation />
<Execution ProcessID="1544" ThreadID="3412" />
<Channel>System</Channel>
<Computer>PRPC</Computer>
<Security />
</System>
<EventData>
<Data Name="param1">Serviio</Data>
<Data Name="param2">%%5000</Data>
<Binary>5300650072007600690069006F000000</Binary>
</EventData>
</Event>
Tried looking up related things regarding this error online but could not find anything
Post Thu Apr 28, 2016 9:43 am
flipandboef
Post Fri Apr 29, 2016 6:42 pm
I already tried that without success.
But.... Decided to remove Serviio and Java and (only) reinstall Serviio again. This time not on my D-drive but on the C-drive.
It works!.... Almost....
Finally the console starts up, the service can be started.
However:
- The service does not seem to start automatically, even when it's set to Automatic
- When I start the service, I then have to stop and start the server in the console, before the TV sees Serviio
- When I quit the console, so does the connection to Serviio again? (Meaning, the TV then does not see Serviio anymore). Not a big deal but I cannot minimize it to the system-tray, so it's off my taskbar.
Any suggestions on the above?
Thanks so much so far for your help and patience and devotion, willing to help me :)
flipandboef
Post Fri Apr 29, 2016 8:13 pm
I'm afraid I was to happy to soon :(
It worked for a few times with my tv, now nothing... Service is running (can also restart it) and console is working.
Tried restarting my pc, restarting the service, stop/start the Serviio server, but Serviio is no longer seen.
Added the logs again. Hopefully we're able to discover more this time?
Named: xx_3.log
derby_3.log
(727 Bytes) Downloaded 345 times
serviio_3.log
(345.43 KiB) Downloaded 293 times
