Sony BDP-S4100 and S4500 not showing SRT-subtitles
Janiporo
Post Sat Aug 27, 2016 2:33 pm
Server:
-Ubuntu 16.04
-Serviio 1.6.1
-FFmpeg from repo
Hardware to watch on (Clients), Blu-ray-players:
-Sony BDP-S4100 (Euro model)
-Sony BDP-S4500 (Euro model)
I can see subtitles fine that are inbuilt in MKV-file, but external files are not showing (SRT for example). One post here says it has the the exact opposite problem with S4500, so they do work on some setups.
I can not use burned in subtitles, since it is too old machine (solution is not to buy new).
I am pretty sure they worked before I upgraded Ubuntu from 14.04 --> 16.04
I have followed these instructions --> http://serviio.org/index.php?option=com ... icle&id=33
I installed libASS, but problem is still there.
Any ideas what to do? :roll:
PS: Can anyone else confirm subtitles are working on either of these machines?
Post Tue Sep 13, 2016 7:17 am
Re: Sony BDP-S4100 and S4500 not showing SRT-subtitles
These devices don't support srt. You will have to use burned in subs.
marianituns
Post Fri Nov 11, 2016 4:56 am
Para poder ver los subtítulos en formato .srt en mi Sony KDL-50W805B por DNLA en la configuración de subtítulos de Serviio en lugar de "UTF-8" o "ANSI" yo lo solucione poniendo "windows-1252" sin las comillas, espero que les sirva, saludos!
