YouTube
I also own a Series E/D Samsung TV and the last update broke the youtube playback. I received a message stating that the sound codec is not supported and then got a blank screen. I fixed the issue with the youtube play in the 1.6.1 version by overwriting the profiles.xml with the older version from 1.6. For me it worked.
Re: YouTube
Hi everybody
I have a problem, I want to share a video from youtube for my child, the address of these video on the browser is https://www.youtube.com/watch?v=9Sb8N9ohXtU
Now, follo these page of the forum I have:
added the address http://gdata.youtube.com/feeds/api/vide ... Sb8N9ohXtU and I have select "Web Resurce"
added the address http://gdata.youtube.com/feeds/api/vide ... Sb8N9ohXtU and I have select "RSS Online/Atom Feed"
But both doesn't work.
I have Try to put the address https://www.googleapis.com/youtube/v3/v ... Sb8N9ohXtU and select "Web resurce" but the the result is a video unwatchable.
My TV is a Samsung LE40C550 and I have a Serviio 1.6.1
Thanks for the answer
Re: YouTube
See the first post for valid forms...gdata is no longer valid with apiV3.
You second googleapis should work. What do you mean by unwatchable?
Post your TV, the profile you are using and a DEBUG log.
Re: YouTube
Personally I find Serviio TubeFox add-on for Firefox really saves me some time and effort on adding YouTube feeds to Serviio. Check it out:
https://addons.mozilla.org/en-US/firefox/addon/serviio-tubefox/?src=search
Re: YouTube
How do I delete a playlist from serviio without deleting it from YouTube??
Can anyone help me with this?
Re: YouTube
Open console/Library/online sources/select the playlist/edit/remove
Re: YouTube
Hi, Im using serviiio 1.8 and downloaded the latest youtube plugin.
With any youtube url (like this https://www.googleapis.com/youtube/v3/c ... DHQJ6FgpwQ) I get this error:
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (YouTube): Cannot get property 'thumb' on null object
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:79)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:187)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:207)
at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:203)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:109)
Caused by: java.lang.NullPointerException: Cannot get property 'thumb' on null object
at org.codehaus.groovy.runtime.NullObject.getProperty(NullObject.java:56)
at org.codehaus.groovy.runtime.InvokerHelper.getProperty(InvokerHelper.java:156)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:208)
at org.codehaus.groovy.runtime.dgm$306.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite$PogoMetaMethodSiteNoUnwrapNoCoerce.invoke(PogoMetaMethodSite.java:308)
at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite.call(PogoMetaMethodSite.java:64)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.NullCallSite.call(NullCallSite.java:32)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at YouTube.extractItems(Youtube.groovy:64)
at org.serviio.library.online.WebResourceUrlExtractor.extractItems(WebResourceUrlExtractor.java:72)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:34)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:31)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
... 1 more
What can I do to make it work? (in version 1.7 was the same result)
... 1 more
Re: YouTube
There is a small bug in the plugin, but it's visible because this channel has no items on it. Where did you get this URL?
Petr
Help translate Serviio
Re: YouTube
The url was added automatically by Serviio Tubefox addon.
Can I do something to make it work? o just wait for an updated plugin?
Re: YouTube
can you post the YouTube URL that this is supposed to represent?
Petr
Re: YouTube
I don't remember the original URL so I replayed the procedure with another one with the same result:
Firefox URL -->
https://www.youtube.com/channel/UC-9-ky ... pwQ/videos
Serviio Tubefox generated URL (and added to Serviio) -->
Firefox URL -->
Re: YouTube
Ah, these are all Vevo videos, which are DRMed, so not available anywhere else than the YouTube website.
Petr
Re: YouTube
I don't see all videos for a channel. I'm probably doing something stupid, so before I post a detailed log, maybe someone can tell me what I''m not understanding. https://www.googleapis.com/youtube/v3/c ... e=Dave58KY shows my 21 videos, but I see 48 (or more) on-line.
Re: YouTube
Hello Petr.
I use serviio almost everyday, it think that it's a very good and useful software so thank you for it.
I recently noticed that the Youtube plugin was not functioning correctly.
Serviio is able to play videos (even new videos) from all the youtube playlists added previously (about 6 months ago, not sure) but not the ones that i add now.
I don't know what the problem is, but i don't think that it is caused by the DRM videos.
Thank you for reading.
Re: YouTube
Anyone monitor this thread or support this plugin anymore?
Re: YouTube
This plug-in was created by the Serviio developer (Zip) and does watch it closely. However, I wouldn't blame him if he's taking some well deserved time off for the holidays.
Re: YouTube
It's not my intention to 'blame' anyone. I just wondered if this was the correct place to post a question. Just replying to this thread doesn't allow a 'Subject'.
Re: YouTube
DEFCON SHARK wrote:Hello Petr.
Do you have an example URL you add to Serviio? And a video example that fails to play? And what device are you trying it on?
Petr
Re: YouTube
zip wrote:DEFCON SHARK wrote:Hello Petr. ....
Yes, i tried several playlists, here is one of the recently added :
- the URL in Serviio : https://www.googleapis.com/youtube/v3/p ... Fs1ydrqbXN
- the Youtube URL : https://www.youtube.com/watch?v=LZ7eJoX ... Fs1ydrqbXN
For this playlist, i can see the names and the lenght of the videos correclty in Serviio but none of them can play.
Here is a similar playlist (from the same YT channel) that i added long time ago :
- the URL in Serviio : https://www.googleapis.com/youtube/v3/p ... 1OvwEtkW2o
- the Youtube URL : https://www.youtube.com/watch?v=BPiT_m4 ... 1OvwEtkW2o
With this playlist, everything works properly.
When i get an error, i usually try to play it on all of my 4 devices, which are :
- the "Bbox Sensation" (it is a 2 in 1 decoder of the Internet Service Provider)
- the Playstation 3
- the Xbox 360
- my phone with the "Smart Player" app (i got a windows phone, Nokia Lumia 650)
Thank you.
Re: YouTube
I tried this playlist and it plays on both, MediaBrowser and XBox One.
Petr
