Re: YouTube
CraigWally wrote:OK Thanks - I think I understand
Is there a way to get a feed url for a specific video
you can grab the share link bellow the video, theres different formats you can use, hope that helps
zip wrote:Hi,
I tried this playlist and it plays on both, MediaBrowser and XBox One.
zip wrote:your playlists still work for me
zip wrote:The check stream only works for Live Stream type of online resource. Are you sure your you tube list is marked as WebResource?
2017-03-28 21:53:22,443 WARN [FeedUpdaterWorker] Failed to retrieve online item information for https://r2---sn-xguxaxjvh-gufe.googlevideo.com/videoplayback?source=youtube&sparams=dur%2Cei%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Clmt%2Cmime%2Cmm%2Cmn%2Cms%2Cmv%2Cpcm2cms%2Cpl%2Cratebypass%2Crequiressl%2Csource%2Cupn%2Cexpire&mime=video%2Fmp4&requiressl=yes&ipbits=0&initcwndbps=3343750&expire=1490745200&dur=210.024&lmt=1483684214629595&key=yt6&pcm2cms=yes&ip=188.232.55.251&id=o-ADmGGhoXw8gK1ZeT-iMQGSD8KiV1enY_DIxpQAs5f_74&ratebypass=yes&itag=22&mm=31&mn=sn-xguxaxjvh-gufe&upn=SOlNjR_7pEg&ei=D6PaWOCBOdWKYIn1uagH&ms=au&mt=1490723496&mv=m&pl=22. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:330)
at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveTechnicalMetadata(FeedUpdaterWorker.java:255)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:129)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:481)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:309)
... 3 more
2017-03-30 16:38:30,717 WARN [FeedUpdaterWorker] Failed to retrieve online item information for https://r5---sn-vgqs7ney.googlevideo.com/videoplayback?dur=2311.918&mv=m&mt=1490906188&ms=au&mn=sn-vgqs7ney&source=youtube&mm=31&upn=XqYcxjMXUtQ&ratebypass=yes&sparams=clen%2Cdur%2Cei%2Cgir%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Clmt%2Cmime%2Cmm%2Cmn%2Cms%2Cmv%2Cpl%2Cratebypass%2Crequiressl%2Csource%2Cupn%2Cexpire&id=o-ABZYdNpK27XjlbIda_oLrMBh2wXnbT_XOoUTdXAY7gG-&initcwndbps=813750&ip=162.207.66.59&mime=video%2Fmp4&ei=nGzdWN7SApCl-AOV-6DwCg&pl=18&requiressl=yes&gir=yes&expire=1490927868&lmt=1254132651283590&itag=18&key=yt6&clen=97699514&ipbits=0. It might not play.
... 3 more
2017-04-01 11:08:06,979 DEBUG [FeedUpdaterWorker] Retrieving file size from the URL connection
2017-04-01 11:08:07,397 DEBUG [FeedUpdaterWorker] Retrieving information about the video stream 'Ken Ham on the Age of the Earth'
2017-04-01 11:08:07,397 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: https://r6---sn-vgqsrnee.googlevideo.com/videoplayback?signature=B15B180CF2DFD4FB273FD39B8E263ABAC91015BA.76EFAA2713134F88DEFCC20AE62A261D4BAC6A20&sparams=clen%2Cdur%2Cei%2Cgir%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Clmt%2Cmime%2Cmm%2Cmn%2Cms%2Cmv%2Cpl%2Cratebypass%2Crequiressl%2Csource%2Cupn%2Cexpire&upn=rDQMD-NRMqw&beids=%5B9466592%5D&itag=18&gir=yes&source=youtube&key=yt6&mt=1491059079&initcwndbps=586250&requiressl=yes&lmt=1390943253057349&dur=2200.764&ratebypass=yes&expire=1491080860&clen=116761073&mime=video%2Fmp4&mm=31&mn=sn-vgqsrnee&id=o-AAM6X4JKbw6Rx1X0NI32vBWEJ5h8Vtfar22HBK5fasUv&ip=162.207.66.59&ipbits=0&mv=m&pl=18&ei=PMLfWN-rNIrKuQKCr4DoBA&ms=au
2017-04-01 11:08:07,397 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe -analyzeduration 10000000 -i https://r6---sn-vgqsrnee.googlevideo.com/videoplayback?signature=B15B180CF2DFD4FB273FD39B8E263ABAC91015BA.76EFAA2713134F88DEFCC20AE62A261D4BAC6A20&sparams=clen%2Cdur%2Cei%2Cgir%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Clmt%2Cmime%2Cmm%2Cmn%2Cms%2Cmv%2Cpl%2Cratebypass%2Crequiressl%2Csource%2Cupn%2Cexpire&upn=rDQMD-NRMqw&beids=%5B9466592%5D&itag=18&gir=yes&source=youtube&key=yt6&mt=1491059079&initcwndbps=586250&requiressl=yes&lmt=1390943253057349&dur=2200.764&ratebypass=yes&expire=1491080860&clen=116761073&mime=video%2Fmp4&mm=31&mn=sn-vgqsrnee&id=o-AAM6X4JKbw6Rx1X0NI32vBWEJ5h8Vtfar22HBK5fasUv&ip=162.207.66.59&ipbits=0&mv=m&pl=18&ei=PMLfWN-rNIrKuQKCr4DoBA&ms=au
2017-04-01 11:08:07,558 DEBUG [FeedUpdaterWorker] Marking online item Ken Ham on the Age of the Earth as 'invalid essence', it will not be tried again until the online feed is refreshed.
fidmas wrote:I assumed the 32bit version for a 32bit machine, but it fails.
Users browsing this forum: No registered users and 82 guests
