Resume from where video stopped.
Signex
Post Tue Feb 14, 2017 10:07 pm
Before we had an UE46ES5700 samsung TV i could always stop a video and resume it later.
After purchasing a Samsung UE55KU6000 this feature isn't working anymore, from what i can read it has to do with Samsung's media player?
Is there any way to get this feature working again for this new TV?
Post Wed Feb 15, 2017 12:54 am
Re: Resume from where video stopped.
Doubt it. That's a feature of the TV, and doesn't matter what is feeding it. I don't believe my JU7100 will resume either. I know my Panasonic won't, nor will my Sony BD player. The only player I have that offers resume is my Roku players, and then only files that either are not transcoded or are transcoded with applehttp.
Post Wed Feb 15, 2017 1:25 pm
Well, I tried it on my JU last night, and it did resume from the last place. Note that I tested it with files that did not require transcoding, as I doubt it would work with those. On that note, what profile do you have selected? If the profile you are using is forcing transcoding, that might be the issue. There is no K profile, so use the J profile.
Signex
Post Wed Feb 15, 2017 2:25 pm
atc98092 wrote:Well, I tried it on my JU last night, and it did resume from the last place. Note that I tested it with files that did not require transcoding, as I doubt it would work with those. On that note, what profile do you have selected? If the profile you are using is forcing transcoding, that might be the issue. There is no K profile, so use the J profile.
I always use the default profile, and it always worked with my old samsung TV, i'll try the J profile and see if it works.
EDIT: Ah it was set to Generic DLNA Profile, i'm pretty sure it used a Samsung profile when i still had my ES5700 model.
I will try it in a bit and see if it resumes.
Post Sun Feb 19, 2017 12:59 pm
yes you will need to use a Samsung profile
bat0nas
Post Wed Mar 08, 2017 9:05 pm
So what are the results?
Post Thu Mar 09, 2017 9:09 am
If you use the Samsung profile, it should resume. What I found it doesn't work for all file types, but that is due to the TV. On my C series I get a Blue button notification which, when pressed, will take me to the resume point.
bojt
Post Tue Nov 07, 2017 12:06 pm
zip wrote:If you use the Samsung profile, it should resume. What I found it doesn't work for all file types, but that is due to the TV. On my C series I get a Blue button notification which, when pressed, will take me to the resume point.
Not sure that this is only due to the TV.
I have LG LM620 and Samsung H6400 TV's connected trough LG and Samsung-H Serviio profiles, no transcoding.
For most files resume works on both TV's, but for some (random) files resume does not (and when it doesn't, it not works on both TV's).
When resume works, also seek, timesearch, FF/RW etc work on both (except FF/RW, which not works on LG).
Unfortunately, I could not be able to find the reason/pattern why this is happening.
For example, those two files:
Vice.Principals.S02E07.Spring.Break.720p.mkv
Vice.Principals.S02E08.Venetian.Nights.720p.mkv
are very similar, have the same origin, codec's, bitrates(s), fps, version of encoders and multiplexer etc etc, but for S02E07 resume works, and for S02E08 not, on both LG & Samsung TV's.
On the other hand, when I use "oShare" simple DLNA server instead of Serviio, for S02E08 resume works on both TV's.
Mediainfo:
Unique ID : 217083949859949686750084982674447644299 (0xA350D91320A7ED9FB3711D4B4F3BB68B)
Complete name : Vice.Principals.S02E07.Spring.Break.720p.mkv
Format : Matroska
File size : 208 MiB
Duration : 31mn 21s
Overall bit rate : 926 Kbps
Encoded date : UTC 2017-11-07 11:14:01
Writing application : mkvmerge v10.0.0 ('To Drown In You') 32bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
DURATION : 00:31:10.666000000
NUMBER_OF_FRAMES : 777
NUMBER_OF_BYTES : 25124
_STATISTICS_WRITING_APP : mkvmerge v10.0.0 ('To Drown In You') 32bit
_STATISTICS_WRITING_DATE_UTC : 2017-10-30 09:32:48
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 31mn 21s
Nominal bit rate : 860 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.039
Writing library : x264 core 129 r2245 bc13772
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=860 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 / zones=0,167,b=0.5/168,528,b=1.5
Language : English
Default : Yes
Forced : No
Format : AAC
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 31mn 21s
Channel(s) : 2 channels
Sampling rate : 48.0 KHz / 24.0 KHz
Compression mode : Lossy
Delay relative to video : 31ms
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : Yes
Forced : No
Unique ID : 192654473851010649981482584023214134138 (0x90EFE6EA31183DF38DFFE5CA55C9137A)
Complete name : Vice.Principals.S02E08.Venetian.Nights.720p.mkv
Format : Matroska
File size : 219 MiB
Duration : 33mn 2s
Encoded date : UTC 2017-11-07 11:13:36
DURATION : 00:32:56.666000000
NUMBER_OF_FRAMES : 615
NUMBER_OF_BYTES : 20470
_STATISTICS_WRITING_DATE_UTC : 2017-11-06 06:16:37
Format : AVC
Duration : 33mn 2s
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Format : AAC
Codec ID : A_AAC
Duration : 33mn 2s
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Language : English
Default : Yes
Forced : No
