CDS Login prolbem
GhostMaster75
Post Mon May 04, 2015 2:02 pm
CDS Login prolbem
I'm trying to use the API with PHP but are still at login.
He keeps telling me that my password is incorrect but does not with response 552.
this is my code:
$data = date("D, d M Y H:i:s e");
$pass = "mypass";
$string = hash_hmac("sha1", $data, $pass);
$password = base64_encode($string);
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "http://localhost:23424/cds/login");
curl_setopt($ch, CURLOPT_RETURNTRANSFER, TRUE);
curl_setopt($ch, CURLOPT_HEADER, FALSE);
curl_setopt($ch, CURLOPT_POST, TRUE);
curl_setopt($ch, CURLOPT_HTTPHEADER, array("Accept: application/xml | application/json", "Date: " . $data, "X-Serviio-Date: " . $data,  "Authorization: Serviio " . $password));
$response = curl_exec($ch);
curl_close($ch);
var_dump($response);
what's wrong???
thank you
Post Tue May 05, 2015 4:35 pm
Re: CDS Login prolbem
the Accept header must be either application/xml or application/json
wasant
Post Wed Mar 29, 2017 2:45 pm
Hi ,
I found this problem as well --> '{"errorCode":552}'
my code below:
$data = gmdate('D, d M Y H:i:s T');
$pass = "1234"; // This password I set with GUI Console in Remote menu.
$ch = curl_init();
"Accept: application/json",
"Date: ".$data,
"X-Serviio-Date:".$data,
"Authorization:Serviio ".$password
what's wrong?
thank you
Post Wed Mar 29, 2017 6:56 pm
does this code produce the example value specified in the API docs?
wasant
Post Thu Mar 30, 2017 2:14 am
zip wrote:does this code produce the example value specified in the API docs?
Yes,I followed the example in the API documentation.
I'm a beginner. I'm not sure in the steps below.
Calculating the Signature
Calculating the value to include in the request is a simple procedure.
1.Calculate an RFC 2104-compliant HMAC-SHA1 hash, using the string (see 4.3.2) and the user's password as the key.
2.Convert the resulting value to base64.
3.The result is the signature you include in the request.
my code below , I'm doing it right?
Do you have any suggestions or samples for me?
Thanks in advance for your help.
Post Thu Mar 30, 2017 8:04 am
it looks ok to me. Do you get the right value when you use the date and password defined in the API ocs as an example? (search for "The following table shows a string, a fake Secret Access Key, and what the resulting base64 encoded signature would be.")
y3ti
Post Mon Apr 08, 2019 11:51 am
This is the code i use to Generate the Auth Token to then be able to pass through the API for the rest of the functions.
replace $server with your Server IP (eg: 192.168.x.x)
replace $pass with the password from your Serviio
   $auth_signature = base64_encode(hash_hmac("sha1", $data, $pass, true));
   $ch = curl_init();
   curl_setopt($ch,CURLOPT_VERBOSE, true);
   curl_setopt($ch,CURLOPT_HEADER, false);
   curl_setopt($ch,CURLOPT_URL, "http://" . $server . "/cds/login");
   curl_setopt($ch,CURLOPT_HTTPHEADER, array(
      "Content-Type: application/json",
      "Date: " . $data,
      "Authorization: Serviio " . $auth_signature
   curl_setopt($ch,CURLOPT_POST, true);
   curl_setopt($ch,CURLOPT_RETURNTRANSFER, true);
   curl_setopt($ch,CURLOPT_FOLLOWLOCATION, true);
   curl_setopt($ch,CURLOPT_SSL_VERIFYPEER, false);
   $output = curl_exec($ch);
   $info = curl_getinfo($ch);
   curl_close($ch);
   $json = json_decode($output, true);
   @$authToken = $json['parameter'][0];
Hope this helps
Clifford
Main Serviio Server: Intel i5 4590T - 8GB Ram (Windows 10 Pro)
Node1: Intel i3 3220T - 8GB Ram - Dual network card (Windows 10 Pro)
Node2: Intel i3 3220T - 8GB Ram - Dual network card (Windows 10 Pro)
Node3: Intel i3 3220T - 8GB Ram - Dual network card (Windows 10 Pro)
