YouTube
Jimbo
Post Thu Apr 06, 2017 2:41 am
Re: YouTube
fidmas wrote:Well, the 64bit version quite correctly tells me it can't run on my 32bit system. And, the TV's media player can't even see Serviio when I use the latest 32bit version of ffmpeg.exe. So, I guess I gotta give-up.
My system is 64-bits. The 32-bit should work the same as the 64-bit. I downloaded the 32-bit version selecting:
3.2.4
32-bit
static
I unzipped it and put the ffmpeg.exe file into the serviio/lib subfolder, restarted the serviio service and everything worked.
I, of course, assume that you are running the windows os. I am running windows 10.
fidmas
Post Thu Apr 06, 2017 1:38 pm
Re: YouTube
Thanks. It's OK. I'm running this on a 32bit XP Pro, and it's still serviio 1.6.1 since I don't want it starting at every boot-up and I need to write code to only start/stop the service independently. I'll try the new ffmpeg again later and maybe the latest serviio if that fails. My Sony TV has a Youtube app that's not "too" bad, so it's not critical. Just annoying.
Tarrasque
Post Sun Apr 09, 2017 9:27 am
Re: YouTube
Can confirm, had to upgrade ffmpeg to get youtube to work again.
fidmas
Post Sun Apr 09, 2017 1:56 pm
Re: YouTube
Thank you much for the information. The latest 32bit ffmpeg doesn't work at all with serviio 1.6. I may play with upgrading serviio at sometime, but since it'll require more than a simple installation, this version is "Good Enough." Aside from streaming local content with serviio, the only plugins i care about are Youtube, CBS and TuneIn. Youtube is working for the most part and the Sony has a Youtube App for when it doesn't. CBS works fine for "some" shows and no-one has any interest in figuring out it fails for the majority of CBS programs. TuneIn stations normally work after 4 or 5 attempts at getting a stream started.
It seams there is very little interest in serviio support anymore (at least for what I use it for), and upgrading is hardly worth the hassle unless the things "I" use it for are made to work better.
Thanks for all your trouble.
norm
Post Tue Apr 25, 2017 4:47 pm
Re: YouTube
gslater wrote:Problem I was having is resolved. I updated FFMPEG to the latest version according to the instructions at http://wiki.serviio.org/doku.php?id=win_ffmpeg and now my youtube content is updating and playing normally.
Thanks had the same problem. Noticed that youtube was not updating and "[FeedUpdaterWorker] Failed to retrieve online item information for" was appearing in the log for a whole lot of youtube content. Updated my ffmpeg to the latest version from Optware-ng and all is working again. Thanks for the hint.
mame32
Post Sun Apr 30, 2017 12:19 am
Re: YouTube
It works for me! Thank you for your help!
I have:
* Serviio 1.8
* Windows 10 (64bits)
* Samsung TV (LE40B650)
I had to update ffmpeg.exe .
After that, all works again!
Thanks! :D
matehr
Post Mon May 01, 2017 5:18 pm
Re: YouTube
mame32 wrote:Hi,
I have:
* Serviio 1.8
Thanks! :D
please can you write how to install, because i have same problem but don't know how to install ffmpeg
thanks
inspired
Post Fri May 12, 2017 2:21 pm
Re: YouTube
Hi!
I have server:
Ubuntu 16.04 64-bit / Serviio 1.8 + YouTube plugin from 1st post/ ffmpeg 2.8.11
I installed Serviio 1.8 with this instruction: http://wiki.serviio.org/doku.php?id=howto:linux:install:ubuntu15-04.
The first trouble what I have - it's that Serviio don't understand cyryllic names of shared folders. Error: "An unexpected error occurred (404). Check the log."
From log:
2017-05-12 14:05:54,836 WARN  [ServiioStatusService] FileNotFoundException occurred. Returning error code 404 to the REST layer. Message: '/torrents/Сериалы' is not an existing folder or is not readable for the current user
All path has r+x permissions.
locale:
LANG=ru_RU.UTF-8
LANGUAGE=
LC_CTYPE="ru_RU.UTF-8"
LC_NUMERIC="ru_RU.UTF-8"
LC_TIME="ru_RU.UTF-8"
LC_COLLATE="ru_RU.UTF-8"
LC_MONETARY="ru_RU.UTF-8"
LC_MESSAGES="ru_RU.UTF-8"
LC_PAPER="ru_RU.UTF-8"
LC_NAME="ru_RU.UTF-8"
LC_ADDRESS="ru_RU.UTF-8"
LC_TELEPHONE="ru_RU.UTF-8"
LC_MEASUREMENT="ru_RU.UTF-8"
LC_IDENTIFICATION="ru_RU.UTF-8"
LC_ALL=
Second trouble is that YouTube plugin don't work properly. For example, through Serviio TubeFox I added link on this channel: https://www.youtube.com/user/PitbullVEVO/videos, but the videos did not appear in the list.
Code from Serviio server
https://www.googleapis.com/youtube/v3/channels?forUsername=PitbullVEVO
From log:
2017-05-12 17:11:12,650 WARN  [FeedUpdaterWorker] Failed to retrieve online item information for https://r3---sn-nx8xon3t-83vl.googlevideo.com/videoplayback?sparams=dur%2Cei%2Cgcr%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Clmt%2Cmime%2Cmm%2Cmn%2Cms%2Cmv%2Cpl%2Cratebypass%2Crequiressl%2Csource%2Cupn%2Cexpire&upn=ZWizdda5PGU&id=o-AGlAEA-Ou7UfIXSn0UfQwFK1hJAFGPD3yvWRp6v1EN1r&mn=sn-nx8xon3t-83vl&mm=31&ms=au&mv=m&mt=1494598163&ip=46.39.238.133&key=yt6&initcwndbps=2942500&ipbits=0&ratebypass=yes&mime=video%2Fmp4&expire=1494619863&source=youtube&itag=22&pl=19&dur=234.916&gcr=ru&requiressl=yes&ei=d8IVWYqnIcevYPzQtegJ&lmt=1492798032561107. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:330)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveTechnicalMetadata(FeedUpdaterWorker.java:255)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:129)
   at java.lang.Thread.run(Thread.java:748)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:481)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:309)
   ... 3 more
From this channel https://www.youtube.com/user/AcademeG/videos several videos in the list are displayed.
Post Fri May 12, 2017 3:38 pm
Re: YouTube
I think you might have to install / compile FFmpeg with support for SSL to play that video.
inspired
Post Fri May 12, 2017 10:39 pm
Re: YouTube
Thanks for reply.
I tryed to compile ffmpeg with --enable-openssl key, but plugin still don't want work properly. Same warning such as top.
Is any idea?
BTW, TonyB has same problem: http://forum.serviio.org/viewtopic.php?f=20&t=3276&start=480#p113551. Mb Google changed something in API?
nishit1
Post Tue Jun 06, 2017 7:38 pm
Re: YouTube
I downloaded new ffmpeg and add to the Serviio\lib folder and that works :) thank you
ffmpeg : http://ffmpeg.zeranoe.com/builds/
edilbertoteles
Post Thu Jun 08, 2017 3:15 am
Re: YouTube
Hello, I tried installing the youtube plugin but it did not work, I put it in the plugins folder in the serviio, I put the link in the library but nothing appears on the TV.
Any suggestion?
*I'm Brazilian, via google translate
JLin
Post Mon Aug 07, 2017 3:50 pm
Re: YouTube
Well, You Tube fails to update all of my playlists now. It updates a few, but it stops after updating only 4. It doesn't matter what order they are in. I have updated the FFmpeg back in April when a similar problem occured (You Tube videos would not play) and just recently to see if that was the issue. It does not appear to be that. The plugin is the most current one. I am curious if You Tube changed some things, and it is causing this issue. It just started happening when I upgraded to version 1.9. So I rolled back to version 1.8, after uninstalling, 1.9. This is on a Sony BDP-S570 running Serviio vesion 1.8. This is not a DRM or any other issue that would block the playlist. The playlists would load, and now they don't, well not all of them.
ljstrickler
Post Wed Sep 13, 2017 4:25 am
Re: YouTube
The Youtube Groovy fails the "normal" test (run from command line)
dad@HP-xw4600 ~/serviio-1.9 $ groovy -cp lib/serviio.jar:lib/slf4j-api.jar:lib/slf4j-log4j12.jar:lib/log4j.jar:lib/org.restlet.jar plugins/Youtube.groovy
Sep 12, 2017 9:12:01 PM org.restlet.engine.connector.HttpClientHelper start
INFO: Starting the internal HTTP client
Caught: java.lang.IllegalArgumentException: The JSON input text should neither be null nor empty.
   at YouTube.extractItems(Youtube.groovy:52)
   at YouTube$extractItems.call(Unknown Source)
   at YouTube.main(Youtube.groovy:194)
What am I missing?
JunJun
Post Thu Sep 14, 2017 3:42 pm
Re: YouTube
Has something changed with Tubefox/Youtube ?? I can't see the Serviio button anymore on the YT pages... and Firefox says my Tubefox addon is obsolete... even if I had it updated.
Any info ??
Thanx
matjan
Post Sun Oct 15, 2017 2:18 pm
Re: YouTube
JunJun wrote:Has something changed with Tubefox/Youtube ?? I can't see the Serviio button anymore on the YT pages... and Firefox says my Tubefox addon is obsolete... even if I had it updated.
Any info ??
Thanx
Hi, same problem here. Is there a solution to this?
richbranch
Post Sat Nov 04, 2017 2:17 pm
Re: YouTube
I've been searching for some time, but I can't seem to find a solution to this. I've placed the most recent version of youtube.groovy in the Source URL I get "The stream URL is not valid or is not currently available. I've tried with multiple playlist, channels etc and get the same error. I've tried restarting my PC and no luck.
The link I'm using is https://www.googleapis.com/youtube/v3/p ... YMX5TWREr1
I'm using serviio 1.9
Would appreciate any help/advice
rihards
Post Tue Nov 07, 2017 2:13 pm
Re: YouTube
utaaanaga
Post Wed Nov 08, 2017 9:46 pm
Re: YouTube
Hi
Is there a bookmarklet type thing for this plugin so that one could use it with non firefox browser. I love the firefox addon but I am not on firefox always.
thanks
utaaanaga
Post Thu Nov 09, 2017 5:18 pm
Re: YouTube
Also is there a way to control the video quality?
Return to Available plugins
