Re: Streaming over vpn
I want to ask, that i have done installing Kodi on my Mac, now do i need to install some specific plugin or i just need to play?
mariad wrote:Unfortunately, i had to watch it on a live stream. Although i download Kodi but it took so long before that the race was ending. So had to go on with the channel only although it lagged a lot and was quite frustrating.
mariad wrote:Does vyprvpn have dedicated servers to work with kodi or any location would do.
mariad wrote:Asked their support this is what they had to say "we do offer VyprVPN Cloud to VyprVPN Premium and Business customers. This service can utilize a Static or Dedicated IP address"
MSGBen wrote:I am talking to their support. let's see if I could get a custom made deal.
h20 wrote:I wonder why you don't know about this https://www.bestvpnrating.com/blog/best ... -algorithm because this can solve everything you ask here. I'm sure it's the best way to make it work
sajansen wrote:Hey, i trying to do the following:
Source: computer in my home network (internet: 200/20) -> Connection: vpn:pptp -> Destination: a friends home (internet: 30/3)
from my friends home i start up my laptop (running serviio) and connect to vpn. i already have the database scanned and everything in it. when im at my friends place, i can vieuw the list just fine... after a bit it starts streaming but then the problem accrues: after about 6 seconds the movie needs to buffer again and this keeps happening. when i try movies that are stored on my laptop itself, everything works fine. that would eliminate everything between serviio and the media player i guess...so the problem has to be around the vpn and input to serviio?
you may think internet is to slow to stream it... but this is not the problem because my upload is 20Mbit and my movies are lower. also when i stream them in vlc it works just fine. when i look at my internet usage it uses around 5 Mbit and other movies it doesnt go more then 3Mbit... so somehow it uses just a bit less then what the movie exactly is. is there a way to fix this?
i did try another media streamer and that one had the same problem.
i also tried using IP and mounted network folder but it didnt change anything with the performance.
MikeL wrote:When using Mediabrowser from a remote location (either through a VPN or not) what is the streaming protocol that is used? Is it RTMP or something else? Given that the file being streamed is of a fixed quality there is no need for an adaptive streaming protocol such as HLS or DASH.
atc98092 wrote:VPN adds overhead to your Internet connection. You may have 20Mbps upload, but after the VPN takes it's share you may drop more than you would think. When I VPN into work, it is almost laughable how slow my connection is. I have 50/5, but you'd think I was on dial-up! I don't know exactly what their upload speed is, but since we're the US Gvmt I expect it is more than I can use. When I open a simple spreadsheet from a work server, it can take 45 seconds or longer to open. And this is a tiny file size. I could probably download it faster and run it local.
So, depending on the quality of the file you are playing (is it HD?), you could easily reach the level to end up buffering. I'm not sure, but the DLNA protocol might be adding network overhead to the stream as well.
atc98092 wrote:Kodi is media streaming and viewing software for a computer. It doesn't have any connection to Serviio, but is capable of streaming media from Serviio. It also has a large number of plug-ins that might provide some of the channels you are seeking. But again, it runs on a computer.
Hulu is a pay streaming site, similar to Netflix, Vudu, or Amazon Streaming Video. It is not something you can add to Serviio. There used to be a Hulu plug-in for Serviio, but they changed their web site and it no longer works. Same with many other plug-ins that used to be able to stream a web site via Serviio that no longer function.
