Post Fri Jan 12, 2018 3:06 pm
Re: Panasonic UHD TV 2015 model
Now I get this:
2018-01-12 16:20:57,939 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2015)' (id=viera2015)
2018-01-12 16:20:57,940 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2018-01-12 16:20:57,940 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2018-01-12 16:20:57,940 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2018-01-12 16:20:57,940 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2018-01-12 16:20:57,940 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2009)' (id=viera2009)
2018-01-12 16:20:57,941 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2018-01-12 16:20:57,941 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2018-01-12 16:20:57,941 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2018-01-12 16:20:57,941 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2018-01-12 16:20:57,941 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2018-01-12 16:20:57,942 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2018-01-12 16:20:57,942 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2018-01-12 16:20:57,942 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2018-01-12 16:20:57,942 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2018-01-12 16:20:57,942 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2018-01-12 16:20:57,943 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2018-01-12 16:20:57,943 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2018-01-12 16:20:57,943 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2018-01-12 16:20:57,943 INFO [ProfileManager] Loading profiles from file /application-profiles.xml
2018-01-12 16:20:57,961 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2018-01-12 16:20:57,962 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2018-01-12 16:20:57,962 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2018-01-12 16:20:57,962 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2018-01-12 16:20:57,963 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2018-01-12 16:20:57,963 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2018-01-12 16:20:57,963 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2018-01-12 16:20:57,964 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2018-01-12 16:20:57,964 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2018-01-12 16:20:57,964 INFO [ProfileManager] User profiles definition (user-profiles.xml) not found, using built-in profiles only
2018-01-12 16:20:57,982 INFO [PluginCompilerThread] Looking for plugins at /home/bogdan/Downloads/serviio-1.9/plugins
2018-01-12 16:20:57,982 INFO [PluginCompilerThread] Started looking for plugins
2018-01-12 16:20:57,983 INFO [UpdateChecker] Checking if a new version is available
2018-01-12 16:20:58,037 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg
2018-01-12 16:20:58,038 INFO [FFMPEGWrapper] FFmpeg details: [version=3.3.4, libRtpmPresent=false, libAssPresent=true, libShinePresent=false, libMxfPresent=false]
2018-01-12 16:20:58,049 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2018-01-12 16:20:58,102 INFO [WebServer] WebServer starting on port 8895
2018-01-12 16:20:58,102 INFO [Device] Updated bound IP address of Device with UUID: f9b00e1b-a55b-3c2f-b101-b7731030fd1d, bound address: 192.168.0.5
2018-01-12 16:20:58,106 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-01-12 16:20:58,106 INFO [EventDispatcher] Starting EventDispatcher
2018-01-12 16:20:58,106 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-01-12 16:20:58,107 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth1 (eth1) and address 192.168.0.5, timeout = 0
2018-01-12 16:20:58,108 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2018-01-12 16:20:58,108 INFO [RendererSearchSender] Starting Renderer searcher process
2018-01-12 16:21:18,110 INFO [FeedUpdaterWorker] Started looking for information about online resources
2018-01-12 16:21:18,143 INFO [TrakttvService] Started trakt.tv sync updater
2018-01-12 16:21:18,143 INFO [TrakttvService] Started trakt.tv scrobble poster
2018-01-12 16:21:18,151 INFO [FileDeltaWatcher] Using 'sun.nio.fs.LinuxWatchService' for delta scan
2018-01-12 16:21:18,156 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2018-01-12 16:21:18,169 INFO [LocalLibraryManager] Starting automatic library scan
2018-01-12 16:21:18,213 INFO [LibraryDeltaScanner] Added repository '/home/bogdan/Torente' to delta scanner (NATIVE)
2018-01-12 16:21:18,213 INFO [LibraryDeltaScanner] Starting the library delta scan
2018-01-12 16:21:18,214 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2018-01-12 16:22:21,700 INFO [PlaybackProgressUpdater] Started playback progress updater
2018-01-12 16:22:21,706 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2018-01-12 16:22:22,105 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2018-01-12 16:22:28,548 INFO [PlaybackEventsManager] Playback of media item 42 (The Aristocats [The.AristoCats.1970.BluRay.REMUX.1080p.AVC.DTS-HD.MA.5.1.RoDubbed-playBD.mkv]) has started at 0% on Identifier=192.168.0.18, Profile=Panasonic Viera (2015), Name=Panasonic VIErA
2018-01-12 16:22:29,875 WARN [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error. Detailed output follows.
encoder : Lavc57.89.100 ac3
frame= 512 fps=0.0 q=-1.0 size= 63699kB time=00:00:21.40 bitrate=24381.3kbits/s speed=42.8x
frame= 1047 fps=1047 q=-1.0 size= 133555kB time=00:00:43.73 bitrate=25014.6kbits/s speed=43.7x
frame= 1585 fps=1056 q=-1.0 size= 204546kB time=00:01:06.04 bitrate=25372.3kbits/s speed= 44x
2018-01-12 16:22:30,381 INFO [PlaybackEventsManager] Playback of media item 42 (The Aristocats [The.AristoCats.1970.BluRay.REMUX.1080p.AVC.DTS-HD.MA.5.1.RoDubbed-playBD.mkv]) has stopped at 0% on Identifier=192.168.0.18, Profile=Panasonic Viera (2015), Name=Panasonic VIErA
2018-01-12 16:22:30,382 INFO [PlaybackEventsManager] Playback of media item 1350 (Arrival [Arrival.2016.2160p.UHD.Blu-ray.REMUX.HEVC.HDR.DTS-HD.MA7.1-playBD.mkv]) has started at 0% on Identifier=192.168.0.18, Profile=Panasonic Viera (2015), Name=Panasonic VIErA
2018-01-12 16:23:27,124 INFO [PlaybackEventsManager] Playback of media item 1350 (Arrival [Arrival.2016.2160p.UHD.Blu-ray.REMUX.HEVC.HDR.DTS-HD.MA7.1-playBD.mkv]) has stopped at 0% on Identifier=192.168.0.18, Profile=Panasonic Viera (2015), Name=Panasonic VIErA
Whatever 4K file is I can't see it (on Arrival I can hear the sound) but screen is black
Any ideas?
Kind regards,
Bogdan
