BBC Radio
qwertyjon
Post Sun Dec 21, 2014 12:21 pm
BBC Radio
I went onto the site, http://bbcstreams.com/, dsownloaded the .asx file, then in Win Media Player, opened the file and went to properties to find the feed URL.
Hope this helps someone.
Qwertyjon
Paul C
Post Tue Feb 20, 2018 12:48 pm
Re: BBC Radio
The latest BBC radio stations list is at
http://www.suppertime.co.uk/blogmywiki/ ... adio-urls/
One or two later discontinued and note BBC Stoke has typo, otherwise they all work.
Paul C
Post Sat Feb 24, 2018 5:40 pm
Re: BBC Radio
Many of the BBC stations are included in my file of 104 working Internet Radio stations (but may only work in UK).
See http://forum.serviio.org/viewtopic.php?f=42&t=24378
norm
Post Fri Jun 23, 2023 7:33 pm
Re: BBC Radio
Looks like BBC have depreciated their old mp3 streams. I've tried the new streams from https://gist.github.com/bpsib/67089b959e4fa898af69fea59ad74bc3. The streams play ok in mediabrowser although don't seem to play via DLNA. What are we missing from the generic profile?
ffmpeg version n3.3.1-8-g6ee4b20-compiled_by_barmalej2_for_ffp0.7arm Copyright (c) 2000-2017 the FFmpeg developers
  built with gcc 4.9.2 (GCC)
  configuration: --prefix=/ffp --cpu=armv5te --disable-runtime-cpudetect --disable-armv6 --disable-armv6t2 --disable-vfp --disable-neon --disable-debug --disable-stripping --disable-ffplay --disable-ffserver --disable-doc --disable-htmlpages --disable-podpages --disable-txtpages --disable-xlib --disable-static --enable-shared --enable-gpl --enable-avresample --enable-gnutls --enable-libass --enable-libmp3lame --enable-libopus --enable-librtmp --enable-libshine --enable-libtheora --enable-libtwolame --enable-libv4l2 --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --extra-cflags=-Wno-deprecated-declarations --extra-version=compiled_by_barmalej2_for_ffp0.7arm
  libavutil      55. 58.100 / 55. 58.100
  libavcodec     57. 89.100 / 57. 89.100
  libavformat    57. 71.100 / 57. 71.100
  libavdevice    57.  6.100 / 57.  6.100
  libavfilter     6. 82.100 /  6. 82.100
  libavresample   3.  5.  0 /  3.  5.  0
  libswscale      4.  6.100 /  4.  6.100
  libswresample   2.  7.100 /  2.  7.100
  libpostproc    54.  5.100 / 54.  5.100
Input #0, hls,applehttp, from 'http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_med/ak/bbc_radio_one.m3u8':
  Duration: N/A, start: 8303.142756, bitrate: N/A
  Program 0
      variant_bitrate : 135680
    Stream #0:0: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp
Return to Audio streams
