Error transcoding
Post Fri Mar 02, 2018 3:27 am
Error transcoding
When Serviio tries to transcode a certain file, it fails with this error in the logs:
2018-03-01 22:13:20,727 DEBUG [ProcessExecutor] Starting /usr/local/bin/ffmpeg -fflags +genpts -threads 0 -i /data/Media/video.mp4 -y -threads 0 -c:v copy -bsf:v h264_mp4toannexb -c:a:0 ac3 -b:a:0 32k -ac:a:0 2 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-223d03cddbbdb16eee7e494300d737c9.stf
2018-03-01 22:13:20,954 WARN [ProcessExecutor] Process /usr/local/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
Stream #0:1 -> #0:1 (aac (native) -> ac3 (native))
[ac3 @ 0x2cc7460] Bit allocation failed. Try increasing the bitrate.
Audio encoding failed (avcodec_encode_audio2)
Conversion failed!
2018-03-01 22:13:20,954 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
I get the same error running ffmpeg from the command line, but it works if I increase the 32k. Is there a way to change / configure the ffmpeg parameters?
Post Fri Mar 02, 2018 8:01 am
Re: Error transcoding
Which profile are you using?
You should be able to edit the profile and change the targetACodec="ac3" bit in the transcoding video block statement to be something like targetACodec="ac3" aBitrate="384". 32k is weird - I thought the default rate was 128k if nothing was specified?
Panasonic Viera CS610A | Panasonic Viera V20A | Sony PS4 | Sony PS3 | Panasonic DMP-BD79 | Yamaha RX-V500D | iPad | Windows 10 | Serviio 1.9 Pro
Post Thu Mar 08, 2018 12:23 pm
default is whatever the source stream bitrate was
