Online sources - BUG - odd missing items and force refresh
Paul C
Post Mon Mar 12, 2018 2:43 pm
There appears to be a problem/bug with the Online sources.
I have a file of 212 items and 212 appear on the Export but only 211 show on the Audio/Online category.
There is no indication of any item being flagged with an issue or not processed.
The file (version 10) is attached.
The file then imports on another machine successfully (i.e. does not report any issues).
Using "force refesh" on every individual item is a nightmare (which I did) and there is danger of hitting adjacent "Remove" or "Disable" when you are doing it repetitively for 200-odd items.
Can the force redresh be made automatic when the individual items are saved or saving the online sources?
There are other major issues with Import/Export which need to be dealt with - see viewtopic.php?f=5&t=24390
internet-radio-stations-version-10.sob
Internet Radio Stations - version 10.
(78.35 KiB) Downloaded 486 times
Godsbusy
Post Mon Mar 12, 2018 11:45 pm
Re: Online sources - BUG - missing items and force refresh
I am having similar problems. When I add an item to a shared folder, it sometimes appears, it sometimes doesn't. This has only started happening since I updated. I can hit force reload .. it still doesn't add the item??
Paul C
Post Tue Mar 13, 2018 1:51 pm
Godsbusy wrote:I am having similar problems. When I add an item to a shared folder, it sometimes appears, it sometimes doesn't. This has only started happening since I updated. I can hit force reload .. it still doesn't add the item??
This issue is different to Shared Folders.
This item concerns Online Sources which works in a different manner.
Post Tue Mar 13, 2018 4:45 pm
As noted, this thread is for Online Sources, not shared folders. Please start a new thread with your issue.
dbase25
Post Sun Mar 18, 2018 12:00 pm
Hello everbody,
i have the same Problem. Since install the New Version 1.9.1 (Windows) i cant see my Online Source (Web+DLNA).
I see the Folder Online but no content. I have create a new online source but doesnt appears too, i have update & check all old but no luck.
Change to old Version V1.9 (downgrade with DB) it works.
Greetings dbase
Post Sun Mar 18, 2018 9:35 pm
dbase25 wrote:Hello everbody,
Greetings dbase
Can you provide an example of the online source that isn't working? Zip would probably need to test it.
Paul C
Post Mon Mar 19, 2018 4:40 pm
We seem to be off-track - my original post was not about 1.9.1 issues which is working fine on Online Sources. Has nothing to do with Shared Folders either.
It concerns why odd items in Online Sources do not show, are not flagged in any way and are difficult to isolate if you have lots of entries.
What verification/checks/conditions would cause them not to be displayed/available when they seem OK and to Export OK too.
Post Mon Mar 19, 2018 4:45 pm
Paul C wrote:We seem to be off-track - ...
I agree. @dbase25, please create a new thread with your issue, and provide the information I mentioned above.
Post Wed Mar 21, 2018 2:20 pm
Re: Online sources - BUG - odd missing items and force refre
you guys need to post detailed logs when adding the content that is missing. It's most likely missing due to Serviio / ffmpeg not being able to fetch the file metadata.
Users browsing this forum: No registered users and 71 guests
