online resource file skipping
guestofhonor
Post Wed Mar 14, 2018 1:02 am
I have 3 online resources, when i play the 1st file and the connection gets lost it will skip and play the second resource and then skip to the 3rd online resource, when at the 3rd online resource it will stay there and reconnect when the connection is lost.
how can i stop skipping for the first 2 online resources to reconnect like the last one ?
Thanks in advance
Post Wed Mar 14, 2018 12:35 pm
Re: online resource file skipping
The developer will likely want to see some detailed logs when this is happening. Configure detailed logging and then attach the log here.
guestofhonor
Post Wed Mar 14, 2018 1:26 pm
2018-03-14 17:20:03,378 DEBUG [ServiioHttpService] Incoming request from /192.168.0.50:57941: GET /resource/1000001150001518/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.0.1:8895]]
2018-03-14 17:20:03,378 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2018-03-14 17:20:03,379 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2018-03-14 17:20:03,379 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.50, Profile=Samsung TV / player (E/F-series), Name=UA46F5500'
2018-03-14 17:20:03,379 DEBUG [ResourceDeliveryProcessor] Request for resource 1000001150001518 and type 'MEDIA_ITEM' received
2018-03-14 17:20:03,379 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000001150001518 (online)
2018-03-14 17:20:03,379 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 115)
2018-03-14 17:20:03,383 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000001150001518, format AVC_TS_MP_HD_AAC_MULT5_ISO and profile Samsung TV / player (E/F-series)
2018-03-14 17:20:03,383 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000001150001518 (online)
2018-03-14 17:20:03,383 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 115)
2018-03-14 17:20:03,384 DEBUG [VideoDeliveryEngine] Delivering item '1000001150001518' for client 'Identifier=192.168.0.50, Profile=Samsung TV / player (E/F-series), Name=UA46F5500'
2018-03-14 17:20:03,384 DEBUG [VideoDeliveryEngine] Delivering file 'http://24.thgss.com:8000/live/14401520720888/14401520720888/278.ts' in native format
2018-03-14 17:20:03,384 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-03-14 17:20:03,385 INFO [PlaybackEventsManager] Playback of media item 1000001060001570 (http://sport.alsartawi.com:8000/tv.ts [http://sport.alsartawi.com:8000/tv.ts]) has stopped at 0% on Identifier=192.168.0.50, Profile=Samsung TV / player (E/F-series), Name=UA46F5500
2018-03-14 17:20:03,385 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Wed, 14 Mar 2018 13:20:03 GMT,MediaInfo.sec: SEC_Duration=18000000;,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-03-14 17:20:03,385 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2018-03-14 17:20:03,386 INFO [PlaybackEventsManager] Playback of media item 1000001150001518 (http://24.thgss.com:8000/live/144015207 ... 888/278.ts [http://24.thgss.com:8000/live/14401520720888/14401520720888/278.ts]) has started at 0% on Identifier=192.168.0.50, Profile=Samsung TV / player (E/F-series), Name=UA46F5500
2018-03-14 17:20:03,707 DEBUG [OnlineInputStream] Byte range not supported for http://24.thgss.com:8000/live/144015207 ... 888/278.ts, returning the whole stream
2018-03-14 17:20:05,882 DEBUG [ServiioHttpService] Incoming request from /192.168.0.50:57132: HEAD /resource/1000001150001518/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2018-03-14 17:20:05,882 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2018-03-14 17:20:05,883 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.50
2018-03-14 17:20:05,883 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.50, Profile=Samsung TV / player (E/F-series), Name=UA46F5500'
2018-03-14 17:20:05,883 DEBUG [ResourceDeliveryProcessor] Request for resource 1000001150001518 and type 'MEDIA_ITEM' received
2018-03-14 17:20:05,883 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000001150001518 (online)
2018-03-14 17:20:05,883 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 115)
2018-03-14 17:20:05,884 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000001150001518, format AVC_TS_MP_HD_AAC_MULT5_ISO and profile Samsung TV / player (E/F-series)
2018-03-14 17:20:05,884 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,Date: Wed, 14 Mar 2018 13:20:05 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-03-14 17:20:17,558 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.0.1:63458s
2018-03-14 17:20:17,558 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.1
2018-03-14 17:20:17,821 DEBUG [OnlineInputStream] Closing stream
2018-03-14 17:20:17,929 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2018-03-14 17:20:17,929 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2018-03-14 17:20:17,930 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 114)
2018-03-14 17:20:17,931 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 115)
2018-03-14 17:20:17,931 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 5)
2018-03-14 17:20:17,932 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 106)
2018-03-14 17:20:17,933 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 113)
2018-03-14 17:20:18,075 DEBUG [SearchManager] Committing search index
guestofhonor
Post Wed Mar 14, 2018 1:29 pm
atc98092 wrote:The developer will likely want to see some detailed logs when this is happening. Configure detailed logging and then attach the log here.
Thanks for the info.
i have posted the log file and in case it's not clear enough anyone can add online resources and test what i mean
1: http://24.thgss.com:8000/live/144015207 ... 888/259.ts
2: http://24.thgss.com:8000/live/144015207 ... 888/256.ts
once resource 1 loses connection it will automatically play stream 2
Thanks in advance
guestofhonor
Post Thu Mar 15, 2018 12:25 pm
I believe i know the cause of the issue but i don't know the configuration to stop it !
lets say you have a shared directory on serviio and it has more than one video ! once the first video playback is done it will start playing the second etc. autoplay all !
how can i stop that ?
Regards
Post Thu Mar 15, 2018 12:28 pm
Regards
That is not controlled by Serviio. It is solely the control of your player. I have no idea if your player allows changing that setting. Some do, some don't. You'll have to look through the player settings.
guestofhonor
Post Thu Mar 15, 2018 12:39 pm
Regards
could you please direct me to the location of that settings for samsung f series ?
Thanks for the help
Post Thu Mar 15, 2018 4:19 pm
I don't have access to an F Series Samsung. I'll check my JU when I get home, but I don't recall seeing any such setting. I don't think my Sony BD player has that setting either. With the Roku, I know it can be disabled in the Roku Media Player.
guestofhonor
Post Thu Mar 15, 2018 5:20 pm
Thanks a lot for your help
The TV itself doesnt have that option, i thought maybe an extra setting in the profiles xml could do the trick
Thanks again
