Serviio 1.9.2 MKV playback issue
PhYziCiAN
Post Wed May 16, 2018 5:54 am
QNAP TS-251 8Gb
Samsung UE40ES7207
File info:
UniqueID/String                  : 225319452614176567467151129160899884590 (0xA982F2B5A663774795D1DBB85E6FF62E)
CompleteName                     : \\10.x.x.x\Movies\Harry Potter\4. Harry Potter and the Goblet of Fire\HP4.BDRip.720p.DVD9.mkv
Format                           : Matroska
Format_Version                   : Version 2
FileSize/String                  : 6.06 GiB
Duration/String                  : 2 h 37 min
OverallBitRate/String            : 5 524 kb/s
Movie                            : Harry.Potter.and.the.Goblet.of.Fire.BDRip.720p.DVD9.DXVA
Encoded_Date                     : UTC 2009-12-14 09:10:50
Encoded_Application/String       : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Encoded_Library/String           : libebml v0.7.7 + libmatroska v0.8.1
ID/String                        : 1
Format_Profile                   : High@L4.1
Format_Settings                  : CABAC / 8 Ref Frames
Format_Settings_CABAC/String     : Yes
Format_Settings_RefFrames/String : 8 frames
CodecID                          : V_MPEG4/ISO/AVC
BitRate/String                   : 5 074 kb/s
Width/String                     : 1 280 pixels
Height/String                    : 532 pixels
DisplayAspectRatio/String        : 2.40:1
FrameRate_Mode/String            : Constant
FrameRate/String                 : 23.976 FPS
ColorSpace                       : YUV
ChromaSubsampling/String         : 4:2:0
BitDepth/String                  : 8 bits
ScanType/String                  : Progressive
Bits-(Pixel*Frame)               : 0.311
StreamSize/String                : 5.45 GiB (90%)
Encoded_Library/String           : x264 core 79 r1347 5ddd61b
Encoded_Library_Settings         : cabac=1 / ref=8 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.1 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=6 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / rc_lookahead=0 / rc=2pass / mbtree=0 / bitrate=5074 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=16500 / vbv_bufsize=62500 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80
Language/String                  : English
Default/String                   : No
Forced/String                    : No
ID/String                        : 2
Format                           : AC-3
Format/Info                      : Audio Coding 3
Format_Settings_Endianness       : Big
CodecID                          : A_AC3
BitRate_Mode/String              : Constant
BitRate/String                   : 448 kb/s
Channel(s)/String                : 6 channels
ChannelPositions                 : Front: L C R, Side: L R, LFE
SamplingRate/String              : 48.0 kHz
FrameRate/String                 : 31.250 FPS (1536 SPF)
BitDepth/String                  : 16 bits
Compression_Mode/String          : Lossy
StreamSize/String                : 503 MiB (8%)
Title                            : Rus (Dub -BD.CEE-)
Language/String                  : Russian
ServiceKind/String               : Complete Main
Default/String                   : Yes
Forced/String                    : No
After upgrading to 1.9.2 (x64) version playback issues occured. After starting file there were 2 identical messages displayed (somewhat "File do not supported") and movie starts to play but without Rew/FF and with wrong overall movie duration.
Steps I tried to resolve this:
- checking TV profile in STATUS tab
- deleting and re-adding Movies folder
- checking if Transcoding option enabled in DELIVERY tab
- deleting and reinstalling Serviio 1.9.2
- compare all Serviio options in 1.9.1 and 1.9.2 versions if somewhat accidentally changed (options were identical between versions)
Then I downgrade to 1.9.1 (x64) version and my playback return to normal: whithout any errors (messages) with actual movie duration (time) and Rew/FF function.
It is not isolated to one file issue, I found some others MKV files with the same issue and all work fine after downgrading Serviio.
rodrigoitaqui
Post Wed May 16, 2018 2:08 pm
Re: Serviio 1.9.2 MKV playback issue
same movie in mkv, when it advances the film in versions 1.8 or 1.9 of this error in any tv, I tested in LG, sansung among others.
In version 1.7 works perfect, being able to advance the film perfectly without problem.
follow the video on youtube that made the demonstration
https://youtu.be/GOhTSAGSSRA
PhYziCiAN
Post Wed May 16, 2018 2:29 pm
rodrigoitaqui wrote:same movie in mkv, when it advances the film in versions 1.8 or 1.9 of this error in any tv, I tested in LG, sansung among others.
My issue is not the same. Playback with sound is continuing in my case. Duration of movie nearly twice a less than actual and the main thing - no Rew/FF function.
Post Wed May 16, 2018 3:08 pm
RW/FF is not available for transcoded files, and it often doesn't report accurate movie length at the same time. So that's what is causing your issue. If you are certain the selected profile for your TV hasn't changed between 1.9.1 and 1.9.2, then I think that something changed in the profile.
Any chance you had made personal modifications to the profile? Every time you upgrade the profiles file is replaced with a new version. Or perhaps the profile you are using had changes between the two versions. I have no idea if that happened, but it would be an explanation.
Panasonic ST30 Plasma, Samsung JU7100 4K TV, Sony BDP-S3500, Sharp 4K Roku TV, Insignia Roku TV, Roku 4, Ultra and Stick, Yamaha RX-V583 AVR.
Primary server: Intel i5-6400, 8 gig ram, Windows 10 Pro, 18 TB hard drive space | Test server Windows 7 Home Premium, AMD Phenom II X4 965, 8 gig ram
Enable debug logging Identify media file contents
PhYziCiAN
Post Wed May 16, 2018 5:25 pm
profile.xml file in config folder has slightly different length in 1.9.1 and 1.9.2 versions. I found Samsung E/F series section in both files and it seems identical. Remarkably but replacement profile.xml with obsolete one did not fix the issue with playback (after restarting server).
Post Thu May 17, 2018 12:40 am
Well, it was worth a shot. Next step is to provide us with a copy of your Serviio log. You should probably enable debug logging first, and I also suggest changing the default log size from 500kb to 5000kb. That is changed in the same file that you have to edit for debug logging. You'll see it in the top section.
So,
Stop the Serviio service
Make the changes necessary to enable debug logging
Delete your current Serviio log so we have a clean file
Start the Serviio service, go to your TV and try to play a file that gives you problems
Stop the playback (if it even starts), stop the Serviio service, and save the log file to a different location
Turn debug logging back off until (unless) you need it again
PhYziCiAN
Post Fri May 18, 2018 8:52 am
Debug logfile
(69.78 KiB) Downloaded 39 times
Post Wed May 23, 2018 12:25 am
I was hoping Zip would have looked this over before now, but I just took a peek myself. This log is incomplete. It only has a tiny bit of the complete log, and the line that shows the beginning of playback isn't there. There's only one line in the entire file that mentions file playback, and it was when you shut Serviio down. It looks like HP4.BDRip.720p.DVD9.mkv was being played, although it shows playback stopped at 0%, which means it had just started. But again, the line that originally calls for playback isn't there.
By default, Serviio breaks the log file into 500k files. When you are making a debug log, that's far too small. In the same file you edited to enable debug, there was a line closer to the beginning the specifies the max file size. Change 500k to 5000k or more, then restart Serviio again in debug mode and try playing the file. Empty the log folder while Serviio isn't running, so you start with a fresh log. When you are done, if there's more than one log in the folder please zip them all into a single compressed file and upload them again here.
PhYziCiAN
Post Thu May 24, 2018 4:44 pm
Logs - part 1
serviio2.log
(400.09 KiB) Downloaded 32 times
serviio1.log
(400.06 KiB) Downloaded 31 times
(9.78 KiB) Downloaded 34 times
PhYziCiAN
Post Thu May 24, 2018 4:45 pm
Logs - part 2
serviio5.log
(428.32 KiB) Downloaded 36 times
serviio4.log
(461.99 KiB) Downloaded 32 times
serviio3.log
(439.93 KiB) Downloaded 33 times
Return to User experiences
