Where are the apps???
MoparsOnly
Post Thu May 31, 2018 11:20 pm
I tried to download and the playstore to retry and that is for either
Post Fri Jun 01, 2018 12:21 am
Re: Where are the apps???
What exactly are you talking about? There are no apps that can be installed in Serviio. There are a number of iOS and Android apps for either controlling the Serviio server or playing Serviio media. The latter only has to be DLNA aware.
MoparsOnly
Post Fri Jun 01, 2018 12:35 am
ServiiGo for my tablet . Do I need pro just to download ServiiGo
Post Fri Jun 01, 2018 2:52 pm
I believe that is correct. See this page for more info: http://www.serviio.org/buy-pro/10-uncat ... ree-vs-pro
I don't think you need Pro to download it from the app store, but you will have to have Pro for ServiiGo to work.
MoparsOnly
Post Fri Jun 01, 2018 6:07 pm
I do know that I need pro for it to work but, I can't even download the app from the google play store.
Post Fri Jun 01, 2018 6:45 pm
oh, it seems they are not available on the Play Store ATM. I will try to contact the author.
Post Fri Jun 01, 2018 10:51 pm
The developer will try to enable the apps in the store soon. It's related to GDPR.
MoparsOnly
Post Sat Jun 02, 2018 10:00 pm
Hey Zip, Thanks for the 411, But whats GDPR
freaknik
Post Sun Jun 03, 2018 10:56 pm
New law in europe. Google it, that's why you see so many privacy policy change notices recently.
ronnyrock
Post Mon Jun 11, 2018 6:58 am
Wow!. We will hope a serviigo in play store.
Any suggestions to replace serviigo in android for the soon?
regards
freaknik
Post Mon Jun 11, 2018 10:40 am
Here you go:
https://openload.co/f/Ig7I4V-hF9g/ServiiGo_4.4.1.apk
I upped it and am sure its clean.
dgangi
Post Sun Sep 30, 2018 10:58 pm
Any update on this? I really like the Serviigo app and have tried to donate a few times but the link doesn't work. The app also has a few bugs that I hope will be addressed, such as issues building a queue list across multiple albums as well as crashes in album playback mode.
Post Mon Oct 01, 2018 8:35 am
Sorry, no update from me. Will (the dev) was busy, but you can try to ping him on the app topic to see if he made some progress.
viewtopic.php?f=17&t=6803
