Transcoding and Brand new Samsung Q9FN
Quarktasche
Post Wed May 30, 2018 1:30 pm
i have a new Samsung UHD TV Q9FN but the TV cant play DivX, xvid and DTS Sound :-(
is it possible that one can solve this via transcoding?
Post Thu May 31, 2018 2:37 am
Re: Transcoding and Brand new Samsung Q9FN
That TV appears to support the same media that older Samsung sets do, so transcoding is certainly an option. However, I have to warn you that my JU7100 refuses to play any video that is transcoded. I don't know if that has been resolved with the newer sets, but wanted to bring it up.
So, first try the Samsung M series profile. It's the most recent Samsung profile, and should have you well covered.
Panasonic ST30 Plasma, Samsung JU7100 4K TV, Sony BDP-S3500, Sharp 4K Roku TV, Insignia Roku TV, Roku 4, Ultra and Stick, Yamaha RX-V583 AVR.
Primary server: Intel i5-6400, 8 gig ram, Windows 10 Pro, 18 TB hard drive space | Test server Windows 7 Home Premium, AMD Phenom II X4 965, 8 gig ram
Quarktasche
Post Thu Jul 05, 2018 12:40 pm
I tried all the samsung profiles but none worked. what do I have to change in the profiles.xml so that transcoding is enabled for .avi (xvid and divx).
EDIT:
if I switch to the profile "panasonic foura 2013" then I can watch avi with xvid but then go uhd content no longer.
I then added
<Matches container="avi" /> <!-- Remove this line for models that natively support AVI's with Xvid video (some ST60's) -->
<Matches container="avi" vCodec="mpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
<Matches container="avi" vCodec="msmpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
to the profile E / F player profile but then the menu for profile is empty
Post Thu Jul 05, 2018 3:55 pm
I'm unfamiliar with the DivX and xvid video codecs, so can't offer any suggestions for those. I'll have to let someone else answer.
Quarktasche
Post Thu Jul 05, 2018 5:41 pm
I've added the code lines to the samsung m-series profile. now works divx, xvid and uhd
Post Thu Jul 05, 2018 8:04 pm
Good work, and nice troubleshooting! :D
Don't forget that the profiles.xml file is replaced every time Serviio is updated. You can create your own personal profile file that isn't overwritten:
If you want to have your profile changes persisted across upgrades, you can add new profiles to a file config/user-profiles.xml. All the syntax and rules described below apply to this file as well.
http://serviio.org/index.php?option=com ... icle&id=16
Quarktasche
Post Fri Jul 06, 2018 6:30 am
icreate a new file with user-profiles.xml
<Profiles version="1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="http://www.serviio.org/xsd/profiles/v/1.9.1/Profiles.xsd">
========================= DO NOT EDIT - start ====================================
<Profile id="sam_q" name="Samsung TV / player (Q-series)" extendsProfileId="sam_j">
<Detection>
<UPnPSearch>
<ModelName>(^[A-Z]{2}\d{2}M[A-Z]?\d{3,4}.*)</ModelName>
<ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
</UPnPSearch>
<HttpHeaders>
<!-- some models only support headers -->
<User-Agent>(.*SEC_HHP_\[TV\] [A-Z]{2}\d{2}M[A-Z]?\d{3,4}.*)</User-Agent>
</HttpHeaders>
</Detection>
</Profiles>
and now my brand new Samsung Q9FN is in the menu and he play XVID, DIVX...
all Samsung models from the year 2018 are no longer playing DivX and DTS for licensing reasons
is it possible with serviio transcoded by a video only the DTS sound?
Post Fri Jul 06, 2018 9:48 am
Add
            <Matches container="*" aCodec="dts-hd" />
after the <Matches container="avi" vCodec="dvvideo" />statement. This will transcode any file that has either DTS (dca) and DTS-HD.
This will do the job, but you may be better off only re-muxing the video (this would mean that you would hve to basically copy the whole sam_j profile and mdify that, as you wont be able to use inheritance like you have).
Panasonic Viera CS610A | Panasonic Viera V20A | Sony PS4 | Sony PS3 | Panasonic DMP-BD79 | Yamaha RX-V500D | iPad | Windows 10 | Serviio 1.9 Pro
lolo_aguirre
Post Sun Jul 08, 2018 8:59 am
The file for the user profile should be called user-profileS.xml. I spent some time to notice it. Thanks.
Post Sun Jul 08, 2018 8:48 pm
lolo_aguirre wrote:The file for the user profile should be called user-profileS.xml. I spent some time to notice it. Thanks.
And that's exactly what I posted above, which was a copy and paste from the Serviio web site. :D
Quarktasche
Post Mon Jul 09, 2018 4:26 am
he meant me. I forgot a "s" above.
crystygye
Post Sat Aug 11, 2018 7:16 pm
thanks guys for all this info. great work 10x a lot
