Bulk file renamer
sand
Post Wed Dec 12, 2018 12:17 pm
Bulk file renamer
What app (Windows) do people use for renaming files?
I am looking for something simple to use preferable open source/freeware. Ideally something that can use wildcards for episode number.
freaknik
Post Wed Dec 12, 2018 3:10 pm
Re: Bulk file renamer
I love total commander for that, uses regular expressions too
Post Wed Dec 12, 2018 9:14 pm
Filebot - but there are others here: http://wiki.serviio.org/doku.php?id=wintools
freaknik
Post Thu Dec 13, 2018 2:39 pm
Wow cool link, thank you, this deserves some delving into. That nfo editor looks promising!
kittmaster
Post Fri Dec 14, 2018 2:53 am
jimcuk
Post Fri Dec 28, 2018 5:55 pm
I use Metamorphose, Bulk rename utility and advanced renamer for generic file renaming however since installing Sonarr it does it all for me
peter1212
Post Wed Aug 28, 2019 12:29 pm
I somehow managed to destroy my raid 10 array. I won't go into too many details as to why and how this could have happened. Multiple power outages have caused problems with my RAID 10 array. First, one drive indicated that it was degraded, then all 4 drives were indicated as being offline. Now I need a solution for raid 10 data recovery, I figured I would try Diskinternals RAID Recovery as it has a lot of good said about it by many people. Most of the time you want to force the existing disks back online. But this software does all the hard work for you and you get back everything that you have lost.
johanparker535
Post Tue Dec 24, 2019 5:07 am
Does it work for people who are using a bad mouse?
Return to General discussion
