Cannot see serviio on TV
miro_
Post Sat Sep 26, 2020 10:11 am
I used serviio couple of years with no problem. Suddenly, it disappeared from my TV. I checked the settings and everything lookes fine. I even tried to launch different consele - plex - and it works. I attach print screen from serviio console - the status is green and server is running. Any idea where the problem might be?
freaknik
Post Sat Sep 26, 2020 1:09 pm
Re: Cannot see serviio on TV
That's weird, try binding the ip address to your whatever network adapter you intend to use.
miro_
Post Sat Sep 26, 2020 1:35 pm
I have dedicated ip address for TV 192.168.0.129. I checked TV and it is the same as shown on the router. The only think that comes to my mind is that I connect TV to my private network wirelessly. But as I said, I see Plex which I installed just today.
Post Sat Sep 26, 2020 7:43 pm
miro_ wrote:I have dedicated ip address for TV 192.168.0.129. I checked TV and it is the same as shown on the router. The only think that comes to my mind is that I connect TV to my private network wirelessly. But as I said, I see Plex which I installed just today.
Some routers have a setting that hides devices that connect wirelessly from seeing and being seen on the network. Perhaps a firmware update activated that setting. You might be seeing Plex via their public access function. That's why I can use Plex on a Roku when I travel. It can't actually see my server, but it "sees" it through the Plex servers.
Return to Panasonic
