atc98092 wrote:If that is the name of the file on your computer, Serviio won't see it. The file must be named user-profiles.xml.
But I see what's wrong. All the transcoding sections you added are not within the <Transcoding> segment. In fact, they aren't in any segment at all. You have the closing tag </Transcoding> but not the opening one. Also, it needs to be above the Online and Generic transcoding sections.
I've corrected that and attached the file back here. Give this a try and see how it works.
Many thanks Dan,
but I cannot launch Serviio when this user file is present. Here is what I get:
- Blank serviio.PNG (4.73 KiB) Viewed 16157 times
The rest is black.
So since I could not recover Serviio by deleting the file, rebooting, etc. I uninstalled the Serviio, cleaned the whatever leftovers with CCleaner (both files and registry), reboot, and then re-installed again.
Confirmed that now Serviio can launch, copy the user profile.xml and reboot. After reboot, I hit the same problem - cannot start Serviio.
Here is what I found in the log:
2021-01-30 23:40:41,018 INFO [ProfileManager] Loading profiles from file /user-profiles.xml
2021-01-30 23:40:41,049 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-complex-type.2.4.a: Invalid content was found starting with element 'GenericTranscoding'. One of '{ContentDirectoryMessageBuilder, ProtocolInfo, DeviceDescription, ResourceTransportProtocolHandler, ContentDirectoryDefinitionFilter, H264LevelCheck, AudioTrackRemux, AlternativeQualities, AutomaticImageRotation, AllowedImageResolutions, LimitImageResolution, Subtitles, ThumbnailsResolution, AllowChunkedTransfer, MultipleAudioTrackAware}' is expected.
2021-01-30 23:40:41,049 ERROR [MediaServer] An unexpected error occurred. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
at org.serviio.profile.ProfileManager.parseProfilesFromFile(ProfileManager.java:186)
at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:160)
at org.serviio.MediaServer.main(MediaServer.java:136)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62)
at com.exe4j.runtime.WinLauncher$2.run(WinLauncher.java:96)
Caused by: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
at org.serviio.profile.ProfilesDefinitionParser.validateXML(ProfilesDefinitionParser.java:1054)
at org.serviio.profile.ProfilesDefinitionParser.parseDefinition(ProfilesDefinitionParser.java:154)
at org.serviio.profile.ProfileManager.parseProfilesFromFile(ProfileManager.java:184)
... 8 more
I hope that gives you an idea what that wrong. If you could try to fix the error, I will gladly verify it for you and share the error log if needed.
Thanks again!
