YouTube
it.x
Post Thu Aug 05, 2021 3:36 pm
Re: YouTube
fast and nice way to bring the Serviio YouTube plugin back to life, is to replace the lines <106..132> (YouTube.groovy rel.09.02.2020/14005B) with this code:
// body of youtube.groovy rel.09.02.2020 (14005B)
// lines <0..105>
      for (elType in ['&el=embedded', '&el=detailpage', '&el=vevo', '']) {
            // ver.1 blocked by Google  ca. 01.05.2021 def videoInfoUrl = "https://www.youtube.com/get_video_info?&video_id=$videoId$elType&ps=default&eurl=&gl=US&hl=en"
            // ver.2 blocked by Google  19.06.2021 def videoInfoUrl = "https://www.youtube.com/get_video_info?html5=1&video_id=$videoId$elType&ps=default&eurl=&gl=US&hl=en"
            // ver.3 blocked by Google  30.07.2021 def videoInfoUrl = "https://www.youtube.com/get_video_info?video_id=$videoId&eurl=https%3A%2F%2Fyoutube.googleapis.com%2Fv%2F$videoId&html5=1&c=TVHTML5&cver=6.20180913$elType&ps=default&eurl=&gl=US&hl=en"
            def videoInfoUrl = "https://youtubei.googleapis.com/youtubei/v1/player?key=AIzaSyAO_FJ2SlqU8Q4STEHLGCilw_Y9_11qcW8"
            def TmpPost = new URL("https://youtubei.googleapis.com/youtubei/v1/player?key=AIzaSyAO_FJ2SlqU8Q4STEHLGCilw_Y9_11qcW8").openConnection();
            def TmpBody ='{"context": {"client": {"hl": "en",  "clientName": "WEB", "clientVersion": "2.20210721.00.00",  "mainAppWebInfo": {"graftUrl":  "/watch?v='+"$videoId"+'"}}},  "videoId":  "'+"$videoId"+'"}'
            TmpPost.setRequestMethod("POST")
            TmpPost.setDoOutput(true)
            TmpPost.setRequestProperty("Content-Type", "application/json")
            TmpPost.getOutputStream().write(TmpBody.getBytes("UTF-8"))
            //org def videoInfoWebPage = new URL(videoInfoUrl).getText()
            def videoInfoWebPage = TmpPost.getInputStream().getText()
            //org def parameters = [:]
            //org videoInfoWebPage.split('&').each { item -> addParameter(item, parameters, '=') }
            def jsonSlurper2 = new JsonSlurper()
            def parameters = jsonSlurper2.parseText(videoInfoWebPage)
            // org def playerResponse = parameters['player_response']
            def playerResponse = parameters['responseContext']
            if(playerResponse) {
                //org def pr = new JsonSlurper().parseText(URLDecoder.decode(playerResponse, 'UTF-8'))
                //org def streamingData = pr['streamingData']
                def streamingData =  parameters['streamingData']
                if(!streamingData) {
                    continue
// lines <133..322>
Fyi:
- cause of a problem: YouTube API v3 "/get_video_info" issue (looks like step blocking by Google in 2021)
- solution: change groovy URL.GetText() method to REST POST request to symulate native YouTube player and then test new JSON response
- JSON response: property "player_response" has been changed to "responseContext"
- fully modified and functional version of plugin attached
- please remember to manage your own API key ( line 53/55 acc. to file version)
- 17.06.2022: reformatting comments and testing original Serviio API key (at this time works fine)
Thanks to:
- https://stackoverflow.com/questions/676 ... -not-found
- https://stackoverflow.com/questions/256 ... ttp-client
Enjoj :) gratitude by any donation are welcome: https://zrzutka.pl/en/y4nk6p
Regards and good luck to Serviio Team :)
Youtube.groovy
(15.31 KiB) Downloaded 2028 times
bmn
Post Thu Sep 02, 2021 3:25 pm
Re: YouTube
it.x wrote:Hello,
Doesnt work (anymore?).
[WebResourceParser] Plugin YouTube returned no value for resource item 'null'
EDIT : btw, returns HTTP ERROR 410
it.x
Post Thu Sep 02, 2021 7:30 pm
Re: YouTube
It works fine and stable for many weeks.
I non stop use searches and channels like this:
SEARCHES:
 https://www.googleapis.com/youtube/v3/search?q=YOUR_STRING_TO_FIND&order=date
CHANNELS:
https://www.googleapis.com/youtube/v3/channels?forUsername=YOUR_STRING_TO_FIND
Maybe you have a problem with the right Google API key: line 53.
Good luck.
bmn
Post Fri Sep 03, 2021 2:34 pm
Re: YouTube
it.x wrote:I
The key is in line 55 and Im using mine. Still got [WebResourceParser] Plugin YouTube returned no value for resource item 'null'
it.x
Post Fri Sep 03, 2021 5:18 pm
Re: YouTube
My job ended when plugin start working again.
There are many possible causes for your problem: maybe you need search this forum or ask Serviio support for help, but you definitely need to be brave and smart against quotas, firewalls, antivir, etc... :)
Alex532
Post Sat Jan 08, 2022 8:55 pm
Re: YouTube
Greetings to the developer and all users, the plugin is working at the moment, if so then you can have detailed instructions on how to install it from 0, I am using this technology for the first time.
Post Sun Jan 09, 2022 1:03 am
Re: YouTube
The instructions for using this plugin should be back in the original post. You have to copy the plugin file into the plugins folder where Serviio is installed on your computer. On Windows, that's C:\Program Files\Serviio\plugins
Alex532
Post Sun Jan 09, 2022 7:07 am
Re: YouTube
Thank you for the quick answer, yes I did it, but what to do next, how to open a video from YouTube on my TV?)) :?
SlavaUkraini
Post Thu Apr 07, 2022 4:06 pm
Re: YouTube
Unfortunately the offered plugin has errors, about 9 lines of the previous version were missing, the attribute "streamingFormats" was no longer defined. :roll:
I guess that an own Google API key is still required and has to be set in line 57 of my version.
Youtube.groovy
Youtube plugin for Serviio
(16.13 KiB) Downloaded 2021 times
it.x
Post Thu Jun 02, 2022 11:03 pm
Re: YouTube
It works fine and stable - I use it often and conveniently with DLNA vs TV Sony Bravia sets or Sony Blu-ray/DVD/network/multimedia/... , several models of Android TV box and few other native DLNA players like Android/iOS apps etc.
I see that you are using the wrong version of groovy file to modify.
Maybe I will help by repeating - two ways:
1. (education:) get the original, last working file, from Serviio Admins post:
https://forum.serviio.org/viewtopic.php?f=20&t=3276&hilit=you+tube#p21613
(Youtube.groovy rel.09.02.2020/14005B)
than make the modifications I am writing about:
https://forum.serviio.org/viewtopic.php?f=20&t=3276&hilit=you+tube&start=580#p133877
that is replace lines <106..132> with new code and manage your own API key at line 53.
2. (fast) get the file already modified by me:
(Youtube.groovy rel.30.07.2021/15673B)
and manage only your own API key at line 55.
good luck
it.x
Previous
Return to Available plugins
