These MKV files don't play on PS3
File 1:
Media Info
- Code:
Unique ID : 196464359986102109260371442183145870048 (0x93CDA8CDCBFE7B8094082B8BD6B152E0)
Complete name : Z:\video\Movies\The Return of the King 2003 1080p\The Return of the King 1080p.mkv
Format : Matroska
File size : 15.3 GiB
Duration : 3h 21mn
Overall bit rate : 10.9 Mbps
Encoded date : UTC 2009-03-14 16:09:37
Writing application : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Codec ID : V_MPEG4/ISO/AVC
Duration : 3h 21mn
Bit rate : 9 392 Kbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.255
Stream size : 12.9 GiB (84%)
Writing library : x264 core 89 r1471M 1144615
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.20 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9392 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 / pulldown=0
Language : English
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 3h 21mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 2.12 GiB (14%)
Language : English
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Menu
00:00:00.000 : en:00:00:00.000
00:06:13.582 : en:00:06:13.582
00:09:10.633 : en:00:09:10.633
00:12:08.394 : en:00:12:08.394
00:15:10.535 : en:00:15:10.535
00:19:09.899 : en:00:19:09.899
00:26:45.646 : en:00:26:45.646
00:29:39.736 : en:00:29:39.736
00:31:39.940 : en:00:31:39.940
00:37:13.398 : en:00:37:13.398
00:39:50.346 : en:00:39:50.346
00:43:46.040 : en:00:43:46.040
00:44:21.367 : en:00:44:21.367
00:46:38.337 : en:00:46:38.337
00:49:21.375 : en:00:49:21.375
00:51:53.319 : en:00:51:53.319
00:56:09.992 : en:00:56:09.992
00:58:09.820 : en:00:58:09.820
01:01:11.251 : en:01:01:11.251
01:06:30.153 : en:01:06:30.153
01:11:11.851 : en:01:11:11.851
01:14:45.898 : en:01:14:45.898
01:19:27.554 : en:01:19:27.554
01:21:55.869 : en:01:21:55.869
01:23:19.077 : en:01:23:19.077
01:25:19.906 : en:01:25:19.906
01:27:05.470 : en:01:27:05.470
01:29:59.394 : en:01:29:59.394
01:37:23.629 : en:01:37:23.629
01:46:32.136 : en:01:46:32.136
01:47:09.048 : en:01:47:09.048
01:47:43.582 : en:01:47:43.582
01:48:50.399 : en:01:48:50.399
01:54:52.135 : en:01:54:52.135
01:55:57.450 : en:01:55:57.450
02:01:33.786 : en:02:01:33.786
02:03:29.193 : en:02:03:29.193
02:07:20.258 : en:02:07:20.258
02:08:50.681 : en:02:08:50.681
02:10:34.702 : en:02:10:34.702
02:11:29.048 : en:02:11:29.048
02:12:20.391 : en:02:12:20.391
02:14:21.387 : en:02:14:21.387
02:16:27.137 : en:02:16:27.137
02:18:15.037 : en:02:18:15.037
02:24:41.423 : en:02:24:41.423
02:26:35.704 : en:02:26:35.704
02:29:38.553 : en:02:29:38.553
02:34:13.619 : en:02:34:13.619
02:36:25.918 : en:02:36:25.918
02:37:29.523 : en:02:37:29.523
02:39:02.199 : en:02:39:02.199
02:39:36.233 : en:02:39:36.233
02:45:14.863 : en:02:45:14.863
02:47:28.163 : en:02:47:28.163
02:50:59.749 : en:02:50:59.749
02:53:21.266 : en:02:53:21.266
02:58:13.349 : en:02:58:13.349
03:02:55.214 : en:03:02:55.214
03:12:12.521 : en:03:12:12.521
FFMPEG
- Code:
BECONAS> ffmpeg -i "/volume1/video/Movies/The Return of the King 2003 1080p/The Return of the King 1080p.mkv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab
384k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts /volume1/@tmp/Serviio/transcoding-temp-14-MPEG2TS.stf
built on Apr 8 2011 17:16:26 with gcc 4.2.3
configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt/include --extra-ldflags=-L/opt/lib --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 0xb8ecf0] max_analyze_duration reached
[matroska,webm @ 0xb8ecf0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from '/volume1/video/Movies/The Return of the King 2003 1080p/The Return of the King 1080p.mkv':
Duration: 03:21:02.04, start: 0.000000, bitrate: 1536 kb/s
Chapter #0.0: start 0.000000, end 373.582000
title : 00:00:00.000
Chapter #0.1: start 373.582000, end 550.633000
title : 00:06:13.582
Chapter #0.2: start 550.633000, end 728.394000
title : 00:09:10.633
Chapter #0.3: start 728.394000, end 910.535000
title : 00:12:08.394
Chapter #0.4: start 910.535000, end 1149.899000
title : 00:15:10.535
Chapter #0.5: start 1149.899000, end 1605.646000
title : 00:19:09.899
Chapter #0.6: start 1605.646000, end 1779.736000
title : 00:26:45.646
Chapter #0.7: start 1779.736000, end 1899.940000
title : 00:29:39.736
Chapter #0.8: start 1899.940000, end 2233.398000
title : 00:31:39.940
Chapter #0.9: start 2233.398000, end 2390.346000
title : 00:37:13.398
Chapter #0.10: start 2390.346000, end 2626.040000
title : 00:39:50.346
Chapter #0.11: start 2626.040000, end 2661.367000
title : 00:43:46.040
Chapter #0.12: start 2661.367000, end 2798.337000
title : 00:44:21.367
Chapter #0.13: start 2798.337000, end 2961.375000
title : 00:46:38.337
Chapter #0.14: start 2961.375000, end 3113.319000
title : 00:49:21.375
Chapter #0.15: start 3113.319000, end 3369.992000
title : 00:51:53.319
Chapter #0.16: start 3369.992000, end 3489.820000
title : 00:56:09.992
Chapter #0.17: start 3489.820000, end 3671.251000
title : 00:58:09.820
Chapter #0.18: start 3671.251000, end 3990.153000
title : 01:01:11.251
Chapter #0.19: start 3990.153000, end 4271.851000
title : 01:06:30.153
Chapter #0.20: start 4271.851000, end 4485.898000
title : 01:11:11.851
Chapter #0.21: start 4485.898000, end 4767.554000
title : 01:14:45.898
Chapter #0.22: start 4767.554000, end 4915.869000
title : 01:19:27.554
Chapter #0.23: start 4915.869000, end 4999.077000
title : 01:21:55.869
Chapter #0.24: start 4999.077000, end 5119.906000
title : 01:23:19.077
Chapter #0.25: start 5119.906000, end 5225.470000
title : 01:25:19.906
Chapter #0.26: start 5225.470000, end 5399.394000
title : 01:27:05.470
Chapter #0.27: start 5399.394000, end 5843.629000
title : 01:29:59.394
Chapter #0.28: start 5843.629000, end 6392.136000
title : 01:37:23.629
Chapter #0.29: start 6392.136000, end 6429.048000
title : 01:46:32.136
Chapter #0.30: start 6429.048000, end 6463.582000
title : 01:47:09.048
Chapter #0.31: start 6463.582000, end 6530.399000
title : 01:47:43.582
Chapter #0.32: start 6530.399000, end 6892.135000
title : 01:48:50.399
Chapter #0.33: start 6892.135000, end 6957.450000
title : 01:54:52.135
Chapter #0.34: start 6957.450000, end 7293.786000
title : 01:55:57.450
Chapter #0.35: start 7293.786000, end 7409.193000
title : 02:01:33.786
Chapter #0.36: start 7409.193000, end 7640.258000
title : 02:03:29.193
Chapter #0.37: start 7640.258000, end 7730.681000
title : 02:07:20.258
Chapter #0.38: start 7730.681000, end 7834.702000
title : 02:08:50.681
Chapter #0.39: start 7834.702000, end 7889.048000
title : 02:10:34.702
Chapter #0.40: start 7889.048000, end 7940.391000
title : 02:11:29.048
Chapter #0.41: start 7940.391000, end 8061.387000
title : 02:12:20.391
Chapter #0.42: start 8061.387000, end 8187.137000
title : 02:14:21.387
Chapter #0.43: start 8187.137000, end 8295.037000
title : 02:16:27.137
Chapter #0.44: start 8295.037000, end 8681.423000
title : 02:18:15.037
Chapter #0.45: start 8681.423000, end 8795.704000
title : 02:24:41.423
Chapter #0.46: start 8795.704000, end 8978.553000
title : 02:26:35.704
Chapter #0.47: start 8978.553000, end 9253.619000
title : 02:29:38.553
Chapter #0.48: start 9253.619000, end 9385.918000
title : 02:34:13.619
Chapter #0.49: start 9385.918000, end 9449.523000
title : 02:36:25.918
Chapter #0.50: start 9449.523000, end 9542.199000
title : 02:37:29.523
Chapter #0.51: start 9542.199000, end 9576.233000
title : 02:39:02.199
Chapter #0.52: start 9576.233000, end 9914.863000
title : 02:39:36.233
Chapter #0.53: start 9914.863000, end 10048.163000
title : 02:45:14.863
Chapter #0.54: start 10048.163000, end 10259.749000
title : 02:47:28.163
Chapter #0.55: start 10259.749000, end 10401.266000
title : 02:50:59.749
Chapter #0.56: start 10401.266000, end 10693.349000
title : 02:53:21.266
Chapter #0.57: start 10693.349000, end 10975.214000
title : 02:58:13.349
Chapter #0.58: start 10975.214000, end 11532.521000
title : 03:02:55.214
Chapter #0.59: start 11532.521000, end 12062.048000
title : 03:12:12.521
Stream #0.0(eng): Video: h264, yuv420p, 1920x800, PAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Stream #0.1(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000
[mpegts @ 0xbb0010] muxrate VBR, pcr every 100 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to '/volume1/@tmp/Serviio/transcoding-temp-14-MPEG2TS.stf':
encoder : Lavf52.92.0
Stream #0.0(eng): Video: [0][0][0][0] / 0x0000, yuv420p, 1920x800 [PAR 1:1 DAR 12:5], q=2-31, 90k tbn, 1k tbc
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, flt, 384 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
frame= 360 fps= 25 q=-1.0 Lsize= 12349kB time=14.89 bitrate=6793.7kbits/s
video:10650kB audio:708kB global headers:0kB muxing overhead 8.726039%
File 2:
Media Info
- Code:
Unique ID : 208964331178908593381509111080240099157 (0x9D3510F73E3F599785DFDC466D612F55)
Complete name : Z:\video\Movies\Rabbit Hole 2010 1080p\Rabbit Hole 2010.mkv
Format : Matroska
File size : 6.97 GiB
Duration : 1h 31mn
Movie name : Rabbit.Hole.(2010).1080P.X264.NL.SUBBED.Bradje
Encoded date : UTC 2011-04-16 11:04:41
Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Format : AVC
Format profile : High@L4.1
Format settings, ReFrames : 4 frames
Duration : 1h 31mn
Bit rate : 8 756 Kbps
Height : 1 080 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.176
Stream size : 5.46 GiB (78%)
Title : Rabbit.Hole.(2010).1080P.X264.NL.SUBBED.Bradje
Writing library : x264 core 115 r1936 7a9e08d
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=8756 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 31mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Stream size : 419 MiB (6%)
Title : AC3
Language : English
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 1h 31mn
Bit depth : 24 bits
Delay relative to video : 11ms
Stream size : 988 MiB (14%)
Title : DTS
Language : English
Text #1
Format : UTF-8
Title : Subtitles
Language : Dutch
Text #2
Format : UTF-8
Title : Subtitles
Language : English
Menu
00:04:13.837 : en:00:04:13.837
00:07:42.295 : en:00:07:42.295
00:11:24.767 : en:00:11:24.767
00:19:34.924 : en:00:19:34.924
00:24:58.288 : en:00:24:58.288
00:34:38.910 : en:00:34:38.910
00:39:10.431 : en:00:39:10.431
00:43:45.915 : en:00:43:45.915
00:49:49.153 : en:00:49:49.153
00:57:16.099 : en:00:57:16.099
01:04:46.549 : en:01:04:46.549
01:09:04.432 : en:01:09:04.432
01:14:28.172 : en:01:14:28.172
01:21:16.580 : en:01:21:16.580
01:24:59.803 : en:01:24:59.803
FFMPEG
- Code:
ffmpeg -i "/volume1/video/Movies/Rabbit Hole 2010 1080p/Rabbit Hole 2010.mkv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 6 -map 0:0 -ma
Input #0, matroska,webm, from '/volume1/video/Movies/Rabbit Hole 2010 1080p/Rabbit Hole 2010.mkv':
title : Rabbit.Hole.(2010).1080P.X264.NL.SUBBED.Bradje
Duration: 01:31:28.54, start: 0.000000, bitrate: 2176 kb/s
Chapter #0.0: start 0.000000, end 253.837000
Chapter #0.1: start 253.837000, end 462.295000
title : 00:04:13.837
Chapter #0.2: start 462.295000, end 684.767000
title : 00:07:42.295
Chapter #0.3: start 684.767000, end 1174.924000
title : 00:11:24.767
Chapter #0.4: start 1174.924000, end 1498.288000
title : 00:19:34.924
Chapter #0.5: start 1498.288000, end 2078.910000
title : 00:24:58.288
Chapter #0.6: start 2078.910000, end 2350.431000
title : 00:34:38.910
Chapter #0.7: start 2350.431000, end 2625.915000
title : 00:39:10.431
Chapter #0.8: start 2625.915000, end 2989.153000
title : 00:43:45.915
Chapter #0.9: start 2989.153000, end 3436.099000
title : 00:49:49.153
Chapter #0.10: start 3436.099000, end 3886.549000
title : 00:57:16.099
Chapter #0.11: start 3886.549000, end 4144.432000
title : 01:04:46.549
Chapter #0.12: start 4144.432000, end 4468.172000
title : 01:09:04.432
Chapter #0.13: start 4468.172000, end 4876.580000
title : 01:14:28.172
Chapter #0.14: start 4876.580000, end 5099.803000
title : 01:21:16.580
Chapter #0.15: start 5099.803000, end 5488.544000
title : 01:24:59.803
Stream #0.0(eng): Video: h264, yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
title : AC3
Stream #0.2(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
title : DTS
Stream #0.3(dut): Subtitle: [0][0][0][0] / 0x0000
title : Subtitles
Stream #0.4(eng): Subtitle: [0][0][0][0] / 0x0000
title : Subtitles
[mpegts @ 0xba6030] muxrate VBR, pcr every 100 pkts, sdt every 200, pat/pmt every 40 pkts
Stream #0.0(eng): Video: [0][0][0][0] / 0x0000, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], q=2-31, 90k tbn, 1k tbc
title : AC3
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
frame= 279 fps= 15 q=-1.0 Lsize= 15753kB time=11.51 bitrate=11209.1kbits/s
video:13990kB audio:550kB global headers:0kB muxing overhead 8.341480%
DLNA Server: Synology, Serviio, Twonky, Plex
DLNA Player: Raspberry Pi Raspbmc
DLNA Tablet: Yatse
