[Solved] Fedora init script doesn't stop Serviio
mrforsythexeter
Post Sun Oct 02, 2011 7:14 pm
Me again, I have created an init script using the fedora Template. However it fails to stop serviio. My best guess is that its stopping the sh script which launches serviio, but not the child(ren) it starts. Any ideas?
#!/bin/sh
# serviio       Serviio Startup Script
# chkconfig:   35 50 80
# description:  Simple script to start Serviio
### BEGIN INIT INFO
# Provides: Serviio
### END INIT INFO
# Source function library.
. /etc/rc.d/init.d/functions
exec="/usr/sbin/serviio/bin/serviio.sh"
prog="serviio"
user="serviio"
[ -e /etc/sysconfig/$prog ] && . /etc/sysconfig/$prog
lockfile=/var/lock/subsys/$prog
start() {
    [ -x $exec ] || exit 5
    echo -n $"Starting $prog: "
    # if not running, start it up here, usually something like "daemon $exec"
    daemon --user $user $exec &
    retval=$?
    echo
    [ $retval -eq 0 ] && touch $lockfile
    return $retval
stop() {
    echo -n $"Stopping $prog: "
    # stop it here, often "killproc $prog"
    killproc $prog
    retval=$?
    echo
    [ $retval -eq 0 ] && rm -f $lockfile
    return $retval
restart() {
    stop
    start
reload() {
    restart
force_reload() {
    restart
rh_status() {
    # run checks to determine if the service is running or use generic status
    status $prog
rh_status_q() {
    rh_status >/dev/null 2>&1
case "$1" in
    start)
        rh_status_q && exit 0
        $1
    stop)
        rh_status_q || exit 0
        $1
    restart)
        $1
    reload)
        rh_status_q || exit 7
        $1
    force-reload)
        force_reload
    status)
        rh_status
    condrestart|try-restart)
        restart
        echo $"Usage: $0 {start|stop|status|restart|condrestart|try-restart|reload|force-reload}"
        exit 2
esac
exit $?
Last edited by mrforsythexeter on Tue Oct 04, 2011 7:03 pm, edited 1 time in total.
Post Sun Oct 02, 2011 8:19 pm
Re: Fedora init script (SysVInitScript) doesn't stop Serviio
serviioservice ;) rather than serviio, would be my guess. also check out this post.
viewtopic.php?f=17&t=71
Mods: can we move to third party section please :)
mrforsythexeter
Post Sun Oct 02, 2011 9:52 pm
Thank you for forcing me to read that post yet again, even though it didn't give me a direct answer, it made me determined to create my own script which works. Here it is encase any one wants it... you will need to change exec and user line
!!! Important, I run serviio as its own user, nothing else runs on it.. becuase of this I stop serviio completely by killing all process's by user, be careful... you have been warned!
#!/bin/sh
### BEGIN INIT INFO
# Provides: Serviio
### END INIT INFO
prog="serviio"
user="serviio"
start() {
    retval=$?
    echo
    return $retval
stop() {
    /usr/bin/pkill -U $user
    retval=$?
    echo
    return $retval
restart() {
    stop
    start
reload() {
    restart
force_reload() {
    restart
rh_status() {
    status $prog
case "$1" in
    start|stop|restart|reaload|force-reload)
        $1
    status)
        rh_status
        restart
        exit 2
esac
exit $?
