HOWTO: Serviio on DNS-320 & DNS-325
Lukas718
Post Sat Jan 07, 2012 5:38 pm
Re: HOWTO: Serviio on DNS-320 & DNS-325
Everything seems to be fine. I created libraries in webUI and looks like everything is working. I tested avi,mkv,mp4 files and they all play with an option to resume. I still have to test my Toshiba tv that gave me headaches before but so far Samsung works great. Takes some time for serviio to update files so I can see them but thats normal I had the same issue with my HTPC box.
Whats not working with your install ?
jsviverette
Post Mon Jan 09, 2012 11:03 am
"Takes some time for serviio to update files so I can see them but thats normal I had the same issue with my HTPC box."
what does this mean? When i add my libarys none of my files ever show up (+3 hours and over 2TB of data)
Post Mon Jan 09, 2012 11:23 am
jsviverette wrote:"Takes some time for serviio to update files so I can see them but thats normal I had the same issue with my HTPC box."
Thats means more than likely you have a permissions issue and serviio is unable to access the location you gave for your file because either the location does not exist or the serviio service does not have access to that location.
jsviverette
Post Wed Jan 11, 2012 8:38 am
what permissions does it need to be i have
/mnt/HD/HD_a2/Data/Movies
and i ran chmod 777 and chown 501:nobody on the directory.
tihob
Post Fri Jan 13, 2012 8:13 pm
jsviverette wrote:what permissions does it need to be i have
Have you launched WebUI ?
The parameters have they are properly saved ?
Could you post your log file (/opt/serviio../log)
jsviverette
Post Mon Jan 16, 2012 1:09 am
2012-01-16 01:44:27,945 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-16 01:44:27,985 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2012-01-16 01:44:27,986 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-16 01:44:27,986 INFO [MediaServer] http://www.serviio.org
2012-01-16 01:44:27,987 INFO [MediaServer]
2012-01-16 01:44:27,988 INFO [MediaServer] Java 1.6.0_18-Sun Microsystems Inc.
2012-01-16 01:44:27,989 INFO [MediaServer] OS Linux arm 2.6.22.18
2012-01-16 01:44:27,990 INFO [MediaServer] File encoding: US-ASCII
2012-01-16 01:44:27,990 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-16 01:44:29,216 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2012-01-16 01:44:29,802 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-16 01:44:47,459 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-16 01:44:56,621 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-16 01:45:03,233 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-16 01:45:07,504 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2012-01-16 01:45:11,491 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-16 01:45:16,596 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-16 01:45:20,270 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-16 01:45:28,758 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-16 01:45:31,016 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2012-01-16 01:45:45,891 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2012-01-16 01:46:13,337 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2012-01-16 01:46:21,353 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-16 01:46:27,320 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2012-01-16 01:46:31,217 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-16 01:46:31,457 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-16 01:46:31,969 INFO [WebServer] WebServer starting on port 8895
2012-01-16 01:46:32,091 INFO [Device] Created UPnP Device with UUID: 6abd6656-330d-34bc-8480-58290724adb1, bound address: 192.168.1.50
2012-01-16 01:46:32,387 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2012-01-16 01:46:32,519 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2012-01-16 01:46:32,574 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2012-01-16 01:46:32,575 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2012-01-16 01:46:32,592 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-01-16 01:46:32,603 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2012-01-16 01:46:32,606 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1326674792604, LastAccessTime = 1326674792604, getTimeToLiveSeconds() = -1, createTime = 1326674792604 ]
2012-01-16 01:46:32,695 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2012-01-16 01:46:32,878 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2012-01-16 01:46:32,880 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-01-16 01:46:32,883 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2012-01-16 01:46:32,885 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2012-01-16 01:46:32,886 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2012-01-16 01:46:32,887 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2012-01-16 01:46:32,888 INFO [CompositeCacheConfigurator] Finished configuration in 345 ms.
2012-01-16 01:46:32,913 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-16 01:46:32,926 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-16 01:46:32,915 INFO [EventDispatcher] Starting EventDispatcher
2012-01-16 01:46:32,995 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-16 01:46:32,996 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-16 01:46:33,043 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface egiga0 (egiga0) and address 192.168.1.50, timeout = 0
2012-01-16 01:46:35,714 INFO [RendererManager] Stored a new renderer: uuid='20962456-3305-2000-0000-0017fa466484', name = 'Xbox 360', ipAddress='192.168.1.115', profile = '3'
2012-01-16 01:46:37,038 INFO [RendererManager] Stored a new renderer: uuid='fccbe57f-6f9d-45e4-b865-bd4f6719b5b5', name = 'Unrecognized device', ipAddress='192.168.1.118', profile = '1'
2012-01-16 01:46:59,516 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-16 01:46:59,610 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-16 01:48:35,013 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-16 01:48:58,606 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-16 01:49:52,229 WARN [OutputTextReader] Error reading output of an external command:Stream Closed
2012-01-16 01:50:14,049 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 6 Extra 01 - A Hero's Journey.mkv' (title: Lost) to Library
2012-01-16 01:52:47,194 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 6 Extra 02 - Crafting A Final Season.mkv' (title: Lost) to Library
2012-01-16 01:54:00,414 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 6 Episode 04 - The Substitute.avi' (title: The Substitute) to Library
2012-01-16 01:55:11,203 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 6 Episode 11 - Happily Ever After.avi' (title: Happily Ever After) to Library
2012-01-16 01:56:13,867 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 6 Episode 09 - Ab Aeterno.avi' (title: Ab Aeterno) to Library
2012-01-16 01:57:27,809 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 6 Episode 01 & 02 - LA X.avi' (title: LA X (1)) to Library
2012-01-16 01:57:37,163 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 01:57:40,730 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 01:59:26,882 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 01:59:28,313 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 01:59:46,746 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 6 Episode 13 - The Last Recruit.avi' (title: The Last Recruit) to Library
2012-01-16 01:59:58,794 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:00:04,962 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:01:33,388 WARN [LibraryManager] Cannot read metadata of file /mnt/HD/HD_a2/Data/TV/L/Lost/Season 6/Lost Season 6 Episode 03 - What Kate Does.avi via extractor ONLINE_VIDEO_SOURCES. Message: Cannot retrieve series search results for tvdb.com: Read timed out
2012-01-16 02:01:33,511 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-16 02:01:40,063 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:01:43,436 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-16 02:01:43,552 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-16 02:01:46,944 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:01:53,668 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:01:58,673 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:02:01,861 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:02:04,342 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:02:10,421 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:04:33,661 WARN [OutputTextReader] Error reading output of an external command:Stream Closed
2012-01-16 02:04:37,259 WARN [LibraryManager] Cannot read metadata of file /mnt/HD/HD_a2/Data/TV/L/Lost/Season 6/Lost Season 6 Episode 19 - The New Man In Charge.mkv via extractor ONLINE_VIDEO_SOURCES. Message: Cannot retrieve episode details (series = 73739, season = 6, episode = 19), file not found
2012-01-16 02:04:37,695 WARN [LibraryAdditionsCheckerThread] Cannot add file Lost Season 6 Episode 19 - The New Man In Charge.mkv because of an unexpected error. Message: Cannot create Folder with name L
org.serviio.db.dao.PersistenceException: Cannot create Folder with name L
at org.serviio.library.dao.FolderDAOImpl.create(FolderDAOImpl.java:528)
at org.serviio.library.dao.FolderDAOImpl.getOrCreateFolder(FolderDAOImpl.java:195)
at org.serviio.library.service.FolderService.createOrReadFolder(FolderService.java:53)
at org.serviio.library.service.VideoService.addVideoToLibrary(VideoService.java:62)
at org.serviio.library.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:152)
at org.serviio.library.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:123)
at org.serviio.library.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:73)
Caused by: java.sql.SQLIntegrityConstraintViolationException: INSERT on table 'FOLDER' caused a violation of foreign key constraint 'REPOSITORY_FOREIGN_KEY' for key (1). The statement has been rolled back.
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
at org.serviio.library.dao.FolderDAOImpl.create(FolderDAOImpl.java:525)
... 8 more
Caused by: java.sql.SQLException: INSERT on table 'FOLDER' caused a violation of foreign key constraint 'REPOSITORY_FOREIGN_KEY' for key (1). The statement has been rolled back.
... 18 more
Caused by: ERROR 23503: INSERT on table 'FOLDER' caused a violation of foreign key constraint 'REPOSITORY_FOREIGN_KEY' for key (1). The statement has been rolled back.
at org.apache.derby.impl.sql.execute.ForeignKeyRIChecker.doCheck(Unknown Source)
at org.apache.derby.impl.sql.execute.GenericRIChecker.doCheck(Unknown Source)
at org.apache.derby.impl.sql.execute.RISetChecker.doFKCheck(Unknown Source)
at org.apache.derby.impl.sql.execute.InsertResultSet.normalInsertCore(Unknown Source)
at org.apache.derby.impl.sql.execute.InsertResultSet.open(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
... 12 more
2012-01-16 02:05:55,890 WARN [LibraryAdditionsCheckerThread] Cannot add file Lost Season 6 Episode 16 - What They Died For.avi because of an unexpected error. Message: Cannot create Folder with name L
... 8 more
... 18 more
... 12 more
2012-01-16 02:06:27,578 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:06:27,583 INFO [UpdateChecker] Checking if a new version is available
2012-01-16 02:07:01,562 WARN [LibraryAdditionsCheckerThread] Cannot add file Lost Season 6 Episode 12 - Everybody Loves Hugo.avi because of an unexpected error. Message: Cannot create Folder with name L
... 8 more
... 18 more
... 12 more
jsviverette
Post Mon Jan 16, 2012 3:47 am
I finally got serviio to work (deleted the db folder), however it is taking over 1 min per file to add to the library. IE.
2012-01-16 04:35:16,347 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 5 Extra 06 - Easter Eggs.avi' (title: Lost Season 5 Extra 06 - Easter Eggs) to Library
2012-01-16 04:36:24,027 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 5 Extra 03 - Building 23 & Beyond With Michael Emerson.avi' (title: Lost Season 5 Extra 03 - Building 23 & Beyond With Michael Emerson) to Library
2012-01-16 04:37:27,516 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 5 Episode 05 - This Place Is Death.avi' (title: Lost Season 5 Episode 05 - This Place Is Death) to Library
2012-01-16 04:38:36,478 INFO [LibraryAdditionsCheckerThread] Added file 'Lost Season 5 Episode 14 - The Variable.avi' (title: Lost Season 5 Episode 14 - The Variable) to Library
Is there any way to speed this up, if not this is going to take many DAYS to complete.
Post Mon Jan 16, 2012 11:30 am
jsviverette wrote:I finally got serviio to work (deleted the db folder), however it is taking over 1 min per file to add to the library. IE.
nope no way to speed it up this is more than like caused by slow conection to internet to detect metadata.
tihob
Post Mon Jan 16, 2012 5:51 pm
You can check your cpu... Did you stop apache's service ?
I advise you to disable metadata for your video's file, and to increase the time to refresh your media library (or uncheck and refresh manually).
Maybe, it would be interresting to test with serviio 0.6.1, if you have the patience, test to install the new package (but i'm not sure that you will accelerate the process.
blase
Post Thu Jan 19, 2012 8:58 pm
megaupload closed
please upload the files to other site
thanks
blase
Post Sat Jan 21, 2012 12:50 pm
thanks for re upload :D
blase
Post Sat Jan 21, 2012 3:13 pm
Well, after getting the files (thanks for that), I proceeded with the installation, but I doubt has arisen?
I start my fun_plug or normal, or rip fun_plug.serviio but not both at once. I say this that I have set my transmission fun_plug and stuff, and I do not like to lose.
any solution? or is it something I espace
thanks and excused for my English
tihob
Post Sat Jan 21, 2012 8:04 pm
blase wrote:Well, after getting the files (thanks for that), I proceeded with the installation, but I doubt has arisen?
I am realy sorry, but i don't understand, what is your problem :oops:
Where do you come from ? maybe, there is someone in this forum who can help you to translate what you want to say.
blase
Post Sat Jan 21, 2012 11:14 pm
Well, after obtaining the archives (thanks for that reason), I came with the installation, but doubts have arisen me.
I or tapeworm installed fun_plug previously (I use for Transsmision and openvpn) and according to the manual must change fun_plug original by the one of serviio to install serviio and to form it, but soon I can return to the original one or I must remain with serviio.
would like to be I to me with the original one and to add the service of serviio.
Bien, después de conseguir los archivos (gracias por eso), procedí con la instalación, pero me han surgido dudas.
Yo ya tenia instalado fun_plug anteriormente (lo utilizo para Transsmision y openvpn) y segun el manual debo cambiar el fun_plug original por el de serviio para instalar serviio y configurarlo, pero luego puedo volver a el original o debo quedarme con el serviio.
A mi me gustaría quedarme con el original y agregar el servicio de serviio
Post Sun Jan 22, 2012 8:08 am
blase wrote:Well, after obtaining the archives (thanks for that reason), I came with the installation, but doubts have arisen me.
if you already have fun_plug installed you dont need to install it again.
tihob
Post Sun Jan 22, 2012 12:02 pm
You can't use original fun_plug with servvio, but you can switch between the two.
When you when use serviio, rename fun_plug (the roiginal) to fun_plug.bak and rename fun_plug.debian to fun_plug.
When you want to reuse the original fun_plug rename fun_plug (serviio's version) to fun_plug.serviio and fun_plug.bak (the original) to fun_plug.
If you have some knowledge in unix system, you can use the package and install "Transmision" and openVPN, because it's an original debian (squeeze version). But it will use much more cpu.
blase
Post Sun Jan 22, 2012 12:27 pm
ok now I understand.
It would be logical to create a package ffp, so that it can be used with the original fun_plug.
ok ahora lo entiendo.
lo logico seria crear un paquete ffp, para poderlo usar con el fun_plug original.
Lukas718
Post Sat Feb 11, 2012 3:43 pm
do u have version 6.2 already available for nas-325 ?
tihob
Post Sun Feb 12, 2012 12:33 pm
Lukas718 wrote:do u have version 6.2 already available for nas-325 ?
Il will do this week.
If you want, you can upgrade this package, just unzip serviio 0.6.2 in /opt/serviio.
tinytitan
Post Tue Mar 06, 2012 4:34 pm
any update yet?
