Sat Jan 14, 2012 2:09 am by Lukas718
I still have the same problem with profiles.xml
I decided to use ssh to do it all
here's what I did in ssh with user root and password serviio:
1.
/opt/serviio/serviio-0.5.2/bin/serviio.sh stop (to stop serviio)
2.
rm /opt/serviio/serviio-0.5.2/config/profiles.xml ( I check this file was gone after I executed this command)
3.
cp /mnt/HD/HD_a2/profiles.xml /opt/serviio/serviio-0.5.2/config/ ( new files was copied there )
4.
ls -l /opt/serviio/serviio-0.5.2/config/ (to check permissions user root had rwx)
5.
chmod ugo+rwx /opt/serviio/serviio-0.5.2/config/ ( to give rwx permission to all )
6.
restarted box by accessing it with my local ip and selecting restart in dlink UI
TV can find serviio and when I start apache and use webUI it gives me same error as before
Required Serviio 0.5.2, but found ''
Cannot connect to Serviio server, it does not seem to be running. Exiting...
So I tried to /opt/serviio/serviio-0.5.2/bin/serviio.sh start
I didnt help ( I think i does autostart anyways after box restart )
I did replace none working profiles.xml from old backup and works on old file.
Is it possible that your file is assigned to different version of serviio ?
what am I doing wrong ???
Please help !!
