ITV Player (UK only) - Web Resource
Post Sat Apr 21, 2012 3:36 pm
A web resource plugin for ITV player content. Requires at least Serviio 1.0
Works with URLs of series web pages.
An example URLs:
https://www.itv.com/itvplayer/the-jeremy-kyle-show
Added 21/4/2012
Updated 31/05/2012
Updated 31/12/2012 V2 (to support new itvPlayer)
Updated 8/1/2013 V3
Updated 9/2/2015 V4 (for Serviio 1.5)
ITVPlayer.groovy
(9 KiB) Downloaded 1063 times
Post Sat Apr 21, 2012 3:49 pm
Re: ITV Player (UK only) - Web Resource
EDIT: I've added some links to http://serviidb.com so if you use ServiiDroid you can search for 'ITV' to get a list of results which you can add directly to your library. Please add the ones I haven't to serviidb.com so that we can build up a nice list of them.
I'll start adding links to serviidb.com, very little on ITV that I would watch, but should be a few things that my partner would like :)
Post Sat Apr 21, 2012 3:50 pm
they do have the last 3 Champions league matches :-)
Post Sat Apr 21, 2012 4:21 pm
Didn't quite get to the end, this is for http://www.itv.com/itvplayer/video/?Filter=315193 which is 123 min, with librtmp and ffmpeg updated and compiled this morning.
ffmpeg -i "rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEbqdBbyahb9dadDd3bzawd1cCcqcZajbmd5dGcKdPcedSbWcNcfcWbrcAcAb_dCb_-bpKTRK-eS-aAt2GAukwuws&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/CATCHUP/c42c7b3b/d8f0/47b8/8194/060175a44f9f/1-5007-0167-001_UEFA-CHAMPIONS-LEAGUE-LIVE-2011-12_TX180412_ITV1200_16X9.mp4 swfvfy=true buffer=100000000"  -y -async 1 -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /mnt/data0/tmp/Serviio/transcoding-temp-1.stf
ffmpeg version N-40023-gdd3043d Copyright (c) 2000-2012 the FFmpeg developers
  built on Apr 21 2012 11:57:32 with gcc 4.4.5
  configuration: --enable-gpl --enable-libmp3lame --enable-version3 --enable-nonfree --enable-librtmp --enable-runtime-cpudetect --enable-pthreads --enable-static --disable-shared
  libavutil      51. 47.100 / 51. 47.100
  libavcodec     54. 15.100 / 54. 15.100
  libavformat    54.  3.100 / 54.  3.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 71.102 /  2. 71.102
  libswresample   0. 11.100 /  0. 11.100
HandShake: Type mismatch: client sent 6, server answered 9
  duration              7435.84
  moovPosition          32.00
  audiocodecid          mp4a
  width                 704.00
  height                396.00
  videocodecid          avc1
  avcprofile            77.00
  avclevel              31.00
  aacaot                2.00
  audiosamplerate       48000.00
  audiochannels         2.00
  videoframerate        25.00
trackinfo:
  length                356920320.00
  timescale             48000.00
  language              eng
sampledescription:
  sampletype            mp4a
  length                185894000.00
  timescale             25000.00
  language              eng
sampledescription:
  sampletype            avc1
Input #0, flv, from 'rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEbqdBbyahb9dadDd3bzawd1cCcqcZajbmd5dGcKdPcedSbWcNcfcWbrcAcAb_dCb_-bpKTRK-eS-aAt2GAukwuws&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/CATCHUP/c42c7b3b/d8f0/47b8/8194/060175a44f9f/1-5007-0167-001_UEFA-CHAMPIONS-LEAGUE-LIVE-2011-12_TX180412_ITV1200_16X9.mp4 swfvfy=true buffer=100000000':
    moovPosition    : 32
    avcprofile      : 77
    avclevel        : 31
    aacaot          : 2
    audiochannels   : 2
    videoframerate  : 25
  Duration: 02:03:55.84, start: 0.000000, bitrate: N/A
    Stream #0:0: Video: h264 (Main), yuv420p, 704x396 [SAR 1:1 DAR 16:9], 25 tbr, 1k tbn, 50 tbc
    Stream #0:1: Audio: aac, 48000 Hz, stereo, s16
Incompatible sample format 's16' for codec 'ac3', auto-selecting format 'flt'
[ac3 @ 0xaefe8c0] channel_layout not specified
[ac3 @ 0xaefe8c0] No channel layout specified. The encoder will guess the layout, but it might be incorrect.
[mpegts @ 0xaefde20] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to '/mnt/data0/tmp/Serviio/transcoding-temp-1.stf':
    moovPosition    : 32
    avcprofile      : 77
    avclevel        : 31
    aacaot          : 2
    audiochannels   : 2
    videoframerate  : 25
    encoder         : Lavf54.3.100
    Stream #0:0: Video: h264, yuv420p, 704x396 [SAR 1:1 DAR 16:9], q=2-31, 90k tbn, 25 tbc
    Stream #0:1: Audio: ac3, 48000 Hz, stereo, flt, 384 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (aac -> ac3)
RTMP_ReadPacket, failed to read RTMP packet header1:07:39.44 bitrate=1655.7kbits/s
frame=101592 fps=206 q=-1.0 Lsize=  821307kB time=01:07:43.67 bitrate=1655.7kbits/s
video:544822kB audio:190485kB global headers:0kB muxing overhead 11.695758%
Edit: just tried an episode of titanic and it worked, and I think 4oD is now actually working for me with the latest ffmpeg+librtmp :D Will do a proper test later where I actually watch it rather than just run the ffmpeg command.
Post Sat Apr 21, 2012 6:41 pm
I've just tried to watch something, after about 10 min it stopped. The log showed ffmpeg had returned code 141. Running the ffmpeg command on its own worked perfectly. Any suggestions?
Xmantium
Post Sat Apr 21, 2012 6:49 pm
hey will, urls seems to work without "%20", noticed you added some in serviiDB, it looks alot cleaner
Example
http://www.itv.com/itvplayer/video/?Filter=BritainsGotTalent
http://www.itv.com/itvplayer/video/?Filter=60MinuteMakeover
http://www.itv.com/itvplayer/video/?Filter=TheCube
Post Sat Apr 21, 2012 7:23 pm
done, let me know if I broke any of them.
bjnash50
Post Wed Apr 25, 2012 9:12 pm
Hi
Thanks for an excellent product. I have loaded the ITV Player plugin which works well with for example Titanic but not with Vera and Scott and Bailey which are available on ITV Player. Any idea why this should be happening?
Post Thu Apr 26, 2012 7:37 am
bjnash50
Post Thu Apr 26, 2012 8:40 am
Yes, that is exactly how I entered the URL's.
bjnash50
Post Fri Apr 27, 2012 9:53 am
It would seem that after further investigation the shows that will not play have a Guidance rating on ITV Player
si_blakely
Post Sun Apr 29, 2012 8:45 pm
I have just installed the ITV Player plugin and set up a feed - I am getting these errors in the serviio log
2012-04-29 21:27:20,827 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ITVPlayer (UK only)): index is out of range 0..-1 (index = 0)
        at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
        at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:169)
        at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
        at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
        at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
        at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:4949)
        at org.codehaus.groovy.runtime.dgm$251.invoke(Unknown Source)
        at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
        at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
        at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
        at ITVPlayerExtractor.extractItems(ITVPlayer.groovy:72)
        at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
        at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:56)
        ... 4 more
Any thoughts
Post Sun Apr 29, 2012 9:44 pm
what url?
si_blakely
Post Mon Apr 30, 2012 8:26 am
si_blakely
Post Mon Apr 30, 2012 9:00 am
And it looks like that show has dropped off the ITV Player. Trying another show now, but won't be able to check till later tonight.
Si
Xmantium
Post Wed May 30, 2012 1:01 pm
Havings issues with the Jeremy Kyle Show (I swear its for my wife :roll: )
I added http://www.itv.com/itvplayer/video/?Fil ... myKyleShow
Im thinking it maybe because this show has some adult language (thats bleeped - the wife told me :? ) it may need verification of age
CPU gets maxed out and get this error message
2012-05-30 13:25:31,245 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ITVPlayer (UK only)): The operation took more than 60000 ms and has been cancelled.
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
   at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:157)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:94)
Caused by: java.lang.RuntimeException: The operation took more than 60000 ms and has been cancelled.
   at org.serviio.library.online.PluginExecutionProcessor.execute(PluginExecutionProcessor.java:64)
   ... 4 more
2012-05-30 13:27:37,680 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
I thought i'll try a single episode after closing Serviio as it was maxing 100% cpu for long time as http://www.itv.com/itvplayer/video/?Fil ... myKyleShow has multiple episode content even after deleting the content from Serviio.
So i added http://www.itv.com/itvplayer/video/?Filter=309876 at 1.39pm
I get samme error message in logs at 1.40pm
heres the weird part, cpu hovers around 50% then at 1.42pm it maxes to 100%
At 1:50pm, after 8 minutes its still 100% max load so decide to remove the URL content by pressing remove and then save
Gone into the logs and appears Serviio is still busy looking for the ITV player episode
At 1:56pm, my cpu is still maxed out even after deleting the URL over 5 mins ago so decide to Exit Serviio completely which got my cpu down to under 5%
Full logs here of the http://www.itv.com/itvplayer/video/?Filter=309876 url event
2012-05-30 13:40:35,885 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
2012-05-30 13:42:43,687 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
2012-05-30 13:44:43,714 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
2012-05-30 13:46:49,699 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
2012-05-30 13:48:55,681 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
2012-05-30 13:50:37,728 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-05-30 13:50:42,680 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-05-30 13:50:42,719 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2012-05-30 13:50:49,680 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2012-05-30 13:50:49,704 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-30 13:50:55,708 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
2012-05-30 13:51:06,681 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-30 13:56:15,381 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-05-30 13:56:15,480 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-05-30 13:56:15,535 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-05-30 13:56:15,535 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-05-30 13:56:15,670 INFO  [FeedUpdaterThread] Finished looking for online resources information
2012-05-30 13:56:22,682 INFO  [PluginCompilerThread] Finished looking for plugins
2012-05-30 13:56:22,695 INFO  [WebServer] WebServer shutting down
2012-05-30 13:56:22,695 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-05-30 13:56:22,696 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-05-30 13:56:22,696 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-05-30 13:56:22,696 INFO  [EventDispatcher] Leaving EventDispatcher
2012-05-30 13:56:26,768 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-05-30 13:56:41,445 INFO  [DatabaseManager] Shutting down database
2012-05-30 13:56:47,041 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
Think there maybe a bug in Serviio also not stopping its max load as it continues to add content even after its been deleted
Post Thu May 31, 2012 6:07 pm
Xmantium wrote:heres the weird part, cpu hovers around 50% then at 1.42pm it maxes to 100%
I've now hopefully fixed the case of when you remove it it should stop the CPU usage. It will still try to parse it every few minutes until you remove it from the list or disable. Please test in the next Beta.
Xmantium
Post Thu May 31, 2012 6:10 pm
Thanks zip, looking forward to it along with .3gp playback!
Do you know why Jeremy kyle show is not listing?
Post Thu May 31, 2012 7:15 pm
updated the plugin, try it now
Xmantium
Post Thu May 31, 2012 8:41 pm
Thanks again zip! Working smoothly!
Sorry if i made you watch the Jeremy Kyle show! :|
Return to Available plugins
Users browsing this forum: No registered users and 69 guests
