HOWTO: Serviio on DNS-320 & DNS-325
• Page 4 of 5 • 1, 2, 3, 4, 5
Hi, in future would you please also post the serviio package as a standalone download. I don't need the Debian install as I already have it installed and customized on my DNS-320. what I've done so far is unpack your customized squeeze folder and copied serviio to my squeeze install. I ran out of time last night so I still need to install apache and configure it to listen on port 8080. I've installed JRE 6 and ffmpeg. I have sickbeard and couchpotato setup and running perfectly. I had tried to use Minidlna to serve HD video to my PS3 and a Sony BD-S570 but was not completely successful. The PS3, of course, does not decode .mkv files natively but the blu-ray player can. Minidlna does not transcode and I found that while the blu-ray player received the streams they were choppy. Since there was no transcoding involved I assumed that the 800Mhz processor of the DNS-320 was too slow. After I tried PS3 media server on my laptop and streamed HD to both the PS3 and blu-ray player without problems. I was hoping to not need to use a computer in this process and rely solely on the nas. Though from what I've read here it seem like transcoding will still be an issue I want to try serviio anyway. Maybe if it can create a big enough buffer it could actually work as transcoder on the DNS-320. I'm willing to try. Thanks for your work.
Re: HOWTO: Serviio on DNS-320 & DNS-325
Hi, this is for anyone else like me who comes along that already has Debian running on their DNS-320/325. I copied the serviio directory out of the archive linked in this thread to opt directory on my 320. However, I could not get the serviio console to start. I kept getting the error below near the bootom of the log when I started serviio:
ERROR [MediaServer] An unexpected error occured. Ending the application. Message: replacement java.lang.NullPointerException: replacement
It seemed significant so I did a google search on it and it led me to this http://forum.serviio.org/viewtopic.php?f=5&t=4657 thread in the serviio forum. That drew my attention to this error at the top of the log file.
ERROR [ApplicationInstanceManager] dlink-53AD8C: dlink-53AD8C java.net.UnknownHostException: dlink-53AD8C: dlink-53AD8C
Finally, I realized that I had to edit /etc/hosts. In addition to the localhost entry which was already there I added the dns-320's hostname to the file along with the ip address of the nas. After making that change serviio started successfully. look at the /etc/hostname to get the correct hostname to put into /etc/hosts. I'll respond to any requests for help. Next task is to get setup to compile my own packages. BTW, don't install the linux package from the downloads page. It is not compiled for a headless device, though it does seem to be cross compiled and will run on ARM.
I am running Serviio 0.61 on my DLink DNS-325 and would like to upgrade my Serviio to 0.62.
What is the best way of upgrading Serviio? Thanks in advance.
edison9114 wrote:I am running Serviio 0.61 on my DLink DNS-325 and would like to upgrade my Serviio to 0.62.
The best way is to copy the folder of serviio 0.62 in /opt/.. for replace the folder of serviio 0.61.
And upgrade the version of WebUI, with the same method (replace the old folder by the newer).
tihob wrote:edison9114 wrote:I am running Serviio 0.61 on my DLink DNS-325 and would like to upgrade my Serviio to 0.62.
Is there a separate install required for WebUI? When I installed 0.61 it was included in Serviio. Won't it get installed automatically when I upgrade Serviio? Also, where do I find the WebUI install package?
edison9114 wrote:tihob wrote:edison9114 wrote:I am running Serviio 0.61 on my DLink DNS-325 and would like to upgrade my Serviio to 0.62.
Yes, it's in separate package, you will find here
Hi All
I have been working with 6.1 for a few days now and i think it is all working ok, the WebUi can see folders and says it is running, i have setup my devices with the correct profile, I tested with each of the known support files in the correct folders, it worked, until i filled my server with all my data, now when I go to my player I can see the server running, I can see folders and files, but now when i select files that worked befor I filled the drive, I get a cant play error, what could have changed?
Do i need to upgrade to newer version of Serviio and is that now version 1?
DN325_Noob wrote:Hi All
Make sure you use the right profile, ideally give your devices static IP addresses on your router.
Petr
Help translate Serviio
Hi
Ok it appears only the MKV files are coming back with an error, AVI and Divx are ok, never had an issue with PC version, is there a difference
Hello .
Im new to the forum.
I bought a dlink 320 and im trying to istall serviio.
I cant copy nothing to the serviio folder....
How can i solve this ?
Thnks
Thnks
This ny Log :
2012-09-08 15:56:20,889 INFO [MediaServer] ------------------------------------------------------------------------
2012-09-08 15:56:20,912 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-09-08 15:56:20,913 INFO [MediaServer] Petr Nejedly 2009-2011
2012-09-08 15:56:20,914 INFO [MediaServer] http://www.serviio.org
2012-09-08 15:56:20,915 INFO [MediaServer] Java 1.6.0_18-Sun Microsystems Inc.
2012-09-08 15:56:20,916 INFO [MediaServer] OS Linux arm 2.6.22.18
2012-09-08 15:56:20,917 INFO [MediaServer] File encoding: US-ASCII
2012-09-08 15:56:20,922 INFO [MediaServer] Headless mode enabled: true
2012-09-08 15:56:20,923 INFO [MediaServer] User home dir: /root
2012-09-08 15:56:20,923 INFO [MediaServer] Temp dir: /tmp
2012-09-08 15:56:20,924 INFO [MediaServer] ------------------------------------------------------------------------
2012-09-08 15:56:22,439 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-09-08 15:56:23,097 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-09-08 15:56:42,715 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-09-08 15:57:35,397 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-09-08 15:57:48,803 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-09-08 15:58:05,623 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-09-08 15:58:17,720 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-09-08 15:58:30,317 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-09-08 15:58:40,737 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-09-08 15:58:47,794 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-09-08 15:59:20,941 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-09-08 15:59:23,545 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-09-08 16:00:01,532 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-09-08 16:01:05,562 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-09-08 16:01:35,430 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-09-08 16:02:02,743 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-09-08 16:02:18,049 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-09-08 16:02:21,629 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-09-08 16:02:34,736 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-09-08 16:02:40,674 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-09-08 16:03:01,842 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-09-08 16:03:12,387 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-09-08 16:03:39,258 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-09-08 16:03:55,966 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-09-08 16:03:58,096 INFO [WebServer] Socket buffer set to 65535 bytes
2012-09-08 16:03:58,102 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-09-08 16:03:58,921 INFO [PluginCompilerThread] Looking for plugins at /opt/serviio/plugins
2012-09-08 16:03:58,936 INFO [PluginCompilerThread] Started looking for plugins
2012-09-08 16:04:03,486 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-09-08 16:04:04,430 INFO [WebServer] WebServer starting on port 8895
2012-09-08 16:04:04,582 INFO [EventDispatcher] Starting EventDispatcher
2012-09-08 16:04:04,584 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-09-08 16:04:04,709 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-09-08 16:04:04,738 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface egiga0 (egiga0) and address 192.168.1.9, timeout = 0
2012-09-08 16:04:05,078 INFO [RendererSearchSender] Searching for Renderer devices
2012-09-08 16:04:05,091 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-09-08 16:04:06,501 INFO [RendererManager] Stored a new renderer: uuid='671ae275-7536-416e-b3b5-9e528263ab6b', name = 'Unrecognized device', ipAddress='192.168.1.103', profile = '1'
2012-09-08 16:04:06,599 INFO [RendererManager] Stored a new renderer: uuid='fe59c3d8-7b43-446a-9715-43f0c0c8915b', name = 'Unrecognized device', ipAddress='192.168.1.5', profile = '1'
2012-09-08 16:04:31,729 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-09-08 16:04:31,770 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 16:04:32,030 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 16:09:34,917 INFO [RendererManager] Stored a new renderer: uuid='05e69708-cda8-4cf1-8844-80587d57257b', name = 'Unrecognized device', ipAddress='192.168.1.4', profile = '1'
2012-09-08 16:10:45,754 INFO [RendererManager] Stored a new renderer: uuid='91f85cbf-bd47-4f6c-b971-9311835a15f0', name = 'Windows Media Player', ipAddress='192.168.1.8', profile = '1'
2012-09-08 16:51:06,739 INFO [RestletProxy] Starting Serviio WebUI on port 8123
2012-09-08 16:55:49,626 INFO [RestletProxy] Starting Serviio WebUI on port 8123
2012-09-08 17:17:12,045 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-09-08 17:17:12,300 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-08 17:17:12,302 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-09-08 17:17:12,426 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:19:14,665 INFO [MediaServer] ------------------------------------------------------------------------
2012-09-08 17:19:14,694 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-09-08 17:19:14,695 INFO [MediaServer] Petr Nejedly 2009-2011
2012-09-08 17:19:14,695 INFO [MediaServer] http://www.serviio.org
2012-09-08 17:19:14,696 INFO [MediaServer]
2012-09-08 17:19:14,697 INFO [MediaServer] Java 1.6.0_18-Sun Microsystems Inc.
2012-09-08 17:19:14,698 INFO [MediaServer] OS Linux arm 2.6.22.18
2012-09-08 17:19:14,698 INFO [MediaServer] File encoding: US-ASCII
2012-09-08 17:19:14,703 INFO [MediaServer] Headless mode enabled: true
2012-09-08 17:19:14,704 INFO [MediaServer] User home dir: /root
2012-09-08 17:19:14,704 INFO [MediaServer] Temp dir: /tmp
2012-09-08 17:19:14,705 INFO [MediaServer] ------------------------------------------------------------------------
2012-09-08 17:19:16,207 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-09-08 17:19:16,847 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-09-08 17:19:39,104 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-09-08 17:19:52,974 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-09-08 17:20:10,957 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-09-08 17:20:22,686 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-09-08 17:20:34,951 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-09-08 17:20:45,099 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-09-08 17:20:51,973 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-09-08 17:21:24,152 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-09-08 17:21:26,690 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-09-08 17:22:03,697 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-09-08 17:23:05,966 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-09-08 17:23:35,033 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-09-08 17:24:01,666 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-09-08 17:24:16,552 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-09-08 17:24:20,043 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-09-08 17:24:32,793 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-09-08 17:24:38,600 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-09-08 17:24:59,215 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-09-08 17:25:09,464 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-09-08 17:25:35,042 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-09-08 17:25:51,488 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-09-08 17:25:53,875 INFO [WebServer] Socket buffer set to 65535 bytes
2012-09-08 17:25:53,881 INFO [Device] Created UPnP Device with UUID: e2e9519c-763e-3e14-9249-97c0b72905d1, bound address: 192.168.1.9
2012-09-08 17:25:54,470 INFO [PluginCompilerThread] Looking for plugins at /opt/serviio/plugins
2012-09-08 17:25:54,494 INFO [PluginCompilerThread] Started looking for plugins
2012-09-08 17:25:59,892 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-09-08 17:26:01,507 INFO [WebServer] WebServer starting on port 8895
2012-09-08 17:26:01,779 INFO [EventDispatcher] Starting EventDispatcher
2012-09-08 17:26:01,781 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-09-08 17:26:01,867 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-09-08 17:26:01,956 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface egiga0 (egiga0) and address 192.168.1.9, timeout = 0
2012-09-08 17:26:02,042 INFO [RendererSearchSender] Searching for Renderer devices
2012-09-08 17:26:02,043 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-09-08 17:26:28,489 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-09-08 17:26:28,529 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:26:28,656 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 17:28:14,305 INFO [RendererManager] Stored a new renderer: uuid='a339d06e-922e-415a-b9e6-3443d82e3b02', name = 'Unrecognized device', ipAddress='192.168.1.13', profile = '1'
2012-09-08 17:28:14,318 INFO [RendererManager] Stored a new renderer: uuid='9ab1229b-feae-4c41-6205-413bec6ece72', name = 'Samsung DTV DMR', ipAddress='192.168.1.13', profile = '7'
2012-09-08 17:28:35,210 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-09-08 17:28:55,831 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-09-08 17:38:44,118 INFO [RestletProxy] Starting Serviio WebUI on port 8123
2012-09-08 17:42:41,598 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-08 17:42:41,697 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:42:41,808 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:42:41,839 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 17:42:45,016 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:42:45,127 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:42:45,197 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 17:45:35,768 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-08 17:45:35,876 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:45:35,988 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:45:36,026 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 17:45:43,033 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-08 17:45:43,136 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:45:43,247 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:45:43,313 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 17:46:03,354 INFO [UpdateChecker] Checking if a new version is available
2012-09-08 17:48:09,229 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-08 17:48:09,336 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:48:09,722 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:48:09,813 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 17:48:24,495 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-08 17:48:24,606 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:48:24,717 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:48:24,755 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 17:48:26,607 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-08 17:48:26,716 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:48:26,827 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:48:26,877 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 17:48:35,988 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-08 17:48:35,989 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:48:36,326 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:48:36,409 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 17:51:29,932 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: pt_PT
2012-09-08 17:52:08,682 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-09-08 17:53:10,430 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-08 17:53:10,526 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:53:10,673 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:53:10,733 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-08 17:53:44,433 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-08 17:53:44,536 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-08 17:53:44,647 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-08 17:53:44,685 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Sorry...and the servio server dont start automatic.
Thnks in advance
Thnks in advance
Can anyone help, I'm new to this but am picking things up.
I had ffp v0.7 already installed, installed serviio 0.6.1, followed all instructions and got the server running although untested on my devices.
Used webUI to set everything up.
All seemed fine, so I tried to add a profile which did have me a bit lost but eventually got it with the help of Google.
This seemed to work but could not see the new profile in the webUI.
I thought I would just get it running then worry about extra profiles, so..
Stopped the webUI as directed.
Checked I could still login as root through PUTTY.
All fine.
Inserted second HDD (my ffp, debian etc is on a 160 gig drive I had laid around)
Checked access with PUTTY again via SSH
Again all fine, started webUI just to check and stopped it again.
Set it away coping my media to the second drive and went to bed.
Got up this morning, media is copied but now I cannot get back in as root.
Get this message as soon as the terminal comes up after opening via PUTTY
Network error: Connection refused
I have actually tried twice with the same happening, I leave it for a while after I have everything working on the NAS and I can't get back in, first time I assumed I messed up and just started fresh, (the reason I used a small drive I had laid around to install the software packages on).
Now I'm thinking there might be another problem as I double checked root access all the way and it's only when I have left it for a while that this has happened.
Hope someone can help,
All fine.
galinhola wrote:Hello .
Thnks
What do you want to say when you say "i can't copy nothing?"
What did you try to copy ?
Do you have a root acces to your nas (with the debian version) ?
Crabash wrote:Can anyone help, I'm new to this but am picking things up.
All fine.
Have you a telnet acces ?
Have you thought to remove ffp's file, and put the debian file ?
I never encounter this problem, but do you think your nas reboot ?
Maybe you can check the log of your nas !
Thanks for the reply tihob.
I figured it out last night, all I did was swap sides with the drives and all seems fine. (did this after reading some people had probs with ffp on one side but ok on the other.)
What pointed me in this direction was the fact that it did it again to me after only ffp was installed, which had never happened before, difference was the other drive was in the box too, previously I had left it out until fpp, serviio etc was installed.
Working on WDTV and files visible from Panasonic BD but can't play, this is the exact situ I was in with the windows version of serviio and all I did was add the Panasonic blu ray profile for playback of every codec I threw at it. Hopefully that will happen with the NAS install too.
There is a new version for this NAS?
How to install?
How to install?
Hello, i need one full guide on how to install serviio on dns 325 ...
I have the problem that when i rename the fun_plug.debian to fun_plug and then reboot the Nas when i try to connect to Nas telnet says to me that Network error: Connection refused!
Anyone knows what the problem is? or send me a guide with the steps one by one plz!
extenue wrote:salut ,
moi aussi je suis french , j'accede finalement au contenu apres que j'ai changé le proprio et le group a root au lieu de "501"
i finally succeed to see content of folder after changed owner and group to be root instead of "501"
however , i am disappointed as it's not working properly for divX on my TV Bravia (which cannot see that natively) and it was the only purpose of Serviio ...
i am not so surprised as 700 Mhz is not good enough for reeconding on the fly
I too have the same problem / mnt/HD/HD_a2/Video ... I do not see the content, I'm not very experienced with debian commands, kindly what can I do?
thanks
I installed serviio 1.0.1 on my DNS-325 with samsung ue32es610 and seems to work very well, the only problem is the lack of back and forth filming on tv.
Thank you very much
Thank you very much
