Started a mediabrowser on iOS - some troubles
LeChatNoir
Post Sat Dec 15, 2012 7:58 am
Re: Started a mediabrowser on iOS - some troubles
Really ?
OMG :-(
It seems you'll have to implement this :mrgreen: Do you think it's possible ? Is it on your roadmap ?
Post Sat Dec 15, 2012 1:42 pm
It is, but not sure when. You can start with audio and images, and send videos to other players (if you can), and implement the native playback when Serviio supports it.
LeChatNoir
Post Sat Dec 15, 2012 3:43 pm
It sounds good !
Let's do it like this.
See you soon.
LeChatNoir
Post Tue Dec 18, 2012 10:04 pm
Hi there,
Still some questions about servo :)
I'm experiencing issue with WMA files.
The server seems ok to serve the files. The API doesn't say "Oh wait, it's not a serviio supported format". So response seems ok but in fact, my player never gets datas and buffer remains empty.
Apparently, ServiiGo is managing this case... How do you do ? Do you "hard test" the wma extension ?
Post Tue Dec 18, 2012 11:14 pm
Can you open the resource URL in a browser? I'm not sure if iOS plays these files natively or if they need to be transcoded to mp3?
LeChatNoir
Post Wed Dec 19, 2012 6:14 am
Yes, it plays in a browser.
But it didn't play in ServiiGo, neither in my iOS proto :-(
In ServiiGo, application tells "Serviio can not encode this format" (or something like that).
Post Wed Dec 19, 2012 8:16 am
That message doesn't come from ServiiGo, did it say 'Transcoded audio is not supported with Serviio 1.0.X' as with Serviio 1.0/1.0.1, the server doesn't close the connection once you finish downloading a transcoded file so there was no way for me to know when I had actually finished downloading it and therefore had to disable playback. This is fixed in Serviio 1.1
LeChatNoir
Post Wed Dec 19, 2012 11:17 am
That's interesting.
Yes, it is that message.
So, I understand that if the file is original, you play it. If it's trancoded, you don't (in the current version) because server doesn't close the connection...
Actually, I'm playing files and observe time player. I compare it with duration get from the server and when buffer is empty, I'm comparing duration vs plaer current time. If it's equal (about), I'm considering the item is terminating and I'm lauching next one.
Apparently, you do not proceed like that ? Could you tell me how you manage it ?
Post Wed Dec 19, 2012 11:33 am
ServiiGo is different as I download the music myself (unless it is a live stream) as I cache music on the device (and also prefetch the next track). I start writing into a file using a random access stream, once I have ~300KB or so I start playback by passing the partial file to the player. This all works fine if I know the exact content lenght/the server cleanly closes the connection when done as I can then finish and move onto downloading the next track in advance. However, because the connection is never closed and I don't know the content length, the method that reads from the music and writes it to a file will never stop. I guess I could estimate it based on bitrate and reported track length, but decided not to bother with hacky fixes as the server deals with it properly by using chunked encoding and closing the stream at the end in 1.1. I suggest you pm zip for beta access to 1.1, or wait as it should be due out very soon.
LeChatNoir
Post Wed Dec 19, 2012 12:42 pm
Ok thanks.
I'm not doing like that for the moment.
I'm just using streaming.
I see how I can do prefetch and caching but for the first release, I'll remain on simple stuff :-)
Because even simple stuff is already complicated...
So, for my WMA files, I guess I must define a profile that say "WMA for iOS ? Encode it". Am I right ? Where can I create that profile ?
Post Wed Dec 19, 2012 12:44 pm
we can build a profile, but start with a simple scenario first. try streaming mp3.
LeChatNoir
Post Wed Dec 19, 2012 8:05 pm
Ok. Streaming MP3 is ok.
I'm currently polishing and managing some stuff around background playback.
See you
LeChatNoir
Post Fri Dec 21, 2012 3:47 pm
Hmmmm, new issue.
My music player is almost finished.
Everything seems ok so I'm using it to deeply test it.
And I've got a pb : when I let the music play, it plays about 2 songs and then stop. As if there was a connexion break with the server.
Does the server has a timeout ?
Post Fri Dec 21, 2012 3:52 pm
no, it doesn't. Check the serviio detiled log if there are any errors
LeChatNoir
Post Fri Dec 21, 2012 4:11 pm
No, sorry...
With some album, no problems...
With some others, problems. It seems I have an issue :)
LeChatNoir
Post Mon Dec 24, 2012 1:51 pm
In fact, the Apple standard object allowing to stream audio is kind of buggy...
When the application is in background and after 10 minutes, as soon as a title is ending, if buferring the next one is too long (more than 3/4 secs), the system consider that the application is not playing audio anymore and suspends the application. So the system can go into deep sleep mode...
I've found a hack to avoid that. But it was tricky to debug because of the about 10 minutes of background playing...
Sometimes, Apple is not so cool :lol:
LeChatNoir
Post Mon Dec 24, 2012 1:52 pm
And by the way... Merry Christmas ;)
LongChair
Post Mon Jan 07, 2013 11:16 am
Just wanted to say that I am highly interested in Ipad Serviio client application, so I will follow your developments :)
Should you need any beta testing ... I can try to help :)
Just to throw some ideas that could eventually inspire you :)
My dream ipad app would be :
- Be able to browse servio from Ipad.
- Be able eventually to play from Ipad. I found that some dlna browsers use external apps to avoid the stream decoding issue (use of Oplayer or Gplayer for instance).
- Be able to select movie from Ipad and play to a dlna rendered (Samsung Tv for instance).
Good luck & keep up the good work :)
LeChatNoir
Post Sun Apr 07, 2013 10:56 am
Back on my iOS dev (sorry, I've been interrupted couple of weeks...). And a new problem :
the serveur is a new version of serviio (1.1) and I've got some troubles : when playing audio, and trying to browse others albums (while audio is playing background), server don't answer. As if it were too busy. All my requests finishes with timeout...
The server is through internet. The client is connected through wifi.
Post Sun Apr 07, 2013 10:40 pm
even through a rest client?
Users browsing this forum: Google [Bot] and 51 guests
