HDTRAILERS VIDEO WEBRESOURCE
NX3
Post Tue Aug 14, 2012 4:26 pm
Re: HDTRAILERS VIDEO WEBRESOURCE
Xmantium wrote:
NX3 wrote:How can you tell if the trailer is from apple ?
Theres usually an Apple watermark on the bottom right
Ahh thankyou :D
NX3
Post Tue Aug 14, 2012 6:13 pm
Everything works bar Apple trailers for me, this is the detailed log of a stream failing.
2012-08-14 19:05:27,203 DEBUG [ProcessExecutor] Starting ffmpeg -user-agent QuickTime -i http://trailers.apple.com/movies/independent/taichi0/taichi-tlr1_h720p.mov
2012-08-14 19:05:27,236 DEBUG [FeedUpdaterThread] Cannot get information about the URL, it might have expired already. Trying again.
2012-08-14 19:05:27,237 DEBUG [FeedItemUrlExtractor] HDTrailers: Starting extraction of url for item: [8]Tai Chi 0
2012-08-14 19:05:27,459 DEBUG [FeedItemUrlExtractor] HDTrailers: Getting item: [8]Tai Chi 0
2012-08-14 19:05:27,460 DEBUG [FeedItemUrlExtractor] HDTrailers: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://trailers.apple.com/movies/independent/taichi0/taichi-tlr1_h720p.mov, thumbnailUrl=http://www.hd-trailers.net/thumbnail/tai-chi-0-1344617115-poster.jpg, expiresImmediately=true, cacheKey=http://www.hd-trailers.net/movie/tai-chi-0/_720, live=false, userAgent=QuickTime]
2012-08-14 19:05:27,460 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://trailers.apple.com/movies/independent/taichi0/taichi-tlr1_h720p.mov
2012-08-14 19:05:27,461 DEBUG [ProcessExecutor] Starting ffmpeg -user-agent QuickTime -i http://trailers.apple.com/movies/independent/taichi0/taichi-tlr1_h720p.mov
2012-08-14 19:05:27,495 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://trailers.apple.com/movies/independent/taichi0/taichi-tlr1_h720p.mov. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:382)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
   ... 2 more
It appears ffmpeg doesn't understand the command "user-agent" command, yet to look up....
  built on Jan  7 2012 18:21:29 with gcc 4.6.1
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid --enable-ssse3
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
  libpostproc  51.  2. 0 / 51.  2. 0
Unrecognized option 'user-agent'
Failed to set value 'QuickTime' for option 'user-agent'
Post Tue Aug 14, 2012 8:49 pm
Your ffmpeg is obsolete. Here is currrent output per Serviio 1.0
C:\Users\John>ffmpeg -user-agent QuickTime -i http://trailers.apple.com/movies/i
ffmpeg version N-41860-g6fd0b55 Copyright (c) 2000-2012 the FFmpeg developers
  built on Jun 23 2012 19:49:05 with gcc 4.6.2
g-config
  libavutil      51. 61.100 / 51. 61.100
  libavcodec     54. 29.100 / 54. 29.100
  libavformat    54. 11.100 / 54. 11.100
  libavdevice    54.  0.100 / 54.  0.100
  libavfilter     2. 82.100 /  2. 82.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'http://trailers.apple.com/movies/indepe
ndent/taichi0/taichi-tlr1_h720p.mov':
    major_brand     : qt
    minor_version   : 537199360
    compatible_brands: qt
    creation_time   : 2012-08-10 16:16:03
    comment         : Encoded and delivered by apple.com/trailers/
    copyright       : ┬⌐ 2012 All Rights Reserved
    title           : Tai Chi 0
    timecode        : 01:00:00:00
  Duration: 00:01:09.81, start: 0.000000, bitrate: 5393 kb/s
    Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1280x544,
 5253 kb/s, 23.98 fps, 23.98 tbr, 2997 tbn, 5994 tbc
      handler_name    : Apple Alias Data Handler
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 134
 kb/s
    Stream #0:2(eng): Data: none (tmcd / 0x64636D74)
NX3
Post Wed Aug 15, 2012 7:37 am
Ops ! Thanks...... I must have messed up the sources....
NX3
Post Wed Aug 15, 2012 5:26 pm
You using the latest soruces from ffmpeg not the serviio versions ?
I got sources from here
http://www.serviio.org/download
Post Wed Aug 15, 2012 6:27 pm
I'm on Windows and don't need the source.
NX3
Post Thu Aug 16, 2012 8:06 pm
k, fixed using latest sources complied :)
Xmantium
Post Sun Sep 16, 2012 11:22 pm
In Top 10 feed im getting error message for Lawless
2012-09-16 23:50:18,981 WARN  [WebResourceParser] Plugin HDTrailers returned no value for resource item '[4]Lawless'
It does have trailers for this awesome movie
Post Mon Sep 17, 2012 6:20 pm
Verson 6 released to exclude restricted "Red Band Trailers" that require age confirmations.
Post Thu Sep 20, 2012 8:59 pm
Version 7 released to support changed YouTube links.
Xmantium
Post Tue Nov 13, 2012 8:06 pm
Hi jbh50, I've noticed some movies with "&" in the title comes as "&amp;"
Post Tue Nov 13, 2012 9:40 pm
Fixed in V8 now posted
slyguy42o
Post Thu Jan 17, 2013 8:21 pm
any ideas about this error?
Serviio 1.1
Windows 2k3 x86
here is the URL I am using
http://www.hd-trailers.net/?res=720
feed not showing
2013-01-17 12:19:02,171 DEBUG [OnlineLibraryManager] Resource http://www.hd-trailers.net/?res=720 not in cache yet, loading it
2013-01-17 12:19:02,171 DEBUG [WebResourceParser] Parsing web resource 'http://www.hd-trailers.net/?res=720'
2013-01-17 12:19:02,171 DEBUG [WebResourceParser] Found matching url extractor (HDTrailers) for resource http://www.hd-trailers.net/?res=720
2013-01-17 12:19:02,171 DEBUG [FeedItemUrlExtractor] HDTrailers: Starting parsing resource: http://www.hd-trailers.net/?res=720
2013-01-17 12:19:02,171 DEBUG [FeedItemUrlExtractor] HDTrailers: Parsing with HDTrailers V8- Only works with Serviio V1.0+
2013-01-17 12:19:02,171 DEBUG [FeedItemUrlExtractor] HDTrailers: HDTrailer type not found or start value too high
2013-01-17 12:19:02,171 WARN [WebResourceParser] Plugin returned null container
2013-01-17 12:19:02,171 WARN [OnlineContentCacheDecorator] Could not store object to local cache (online_feeds): Value must not be null
2013-01-17 12:19:02,171 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
at org.serviio.library.online.OnlineLibraryManager.getEarliestItemExpiryDate(OnlineLibraryManager.java:313)
at org.serviio.library.online.OnlineLibraryManager.storeResourceExpiryDate(OnlineLibraryManager.java:358)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:177)
Post Thu Jan 17, 2013 9:31 pm
Posted formats have no / before ?
slyguy42o
Post Thu Jan 17, 2013 10:12 pm
hmm not sure what you are referring to, I thought the rest of the options would just default?
Post Fri Jan 18, 2013 12:21 am
The valid form was given as http://www.hd-trailers.net?res=720
You used http://www.hd-trailers.net/?res=720
No / before ?
slyguy42o
Post Fri Jan 18, 2013 5:33 am
aha! got it! thanks!
Xmantium
Post Sun Jan 27, 2013 3:00 pm
Looks like Yahoo Trailers changed its format - http://blog.hd-trailers.net/2012/12/23/ ... on-script/ provides a fix but not sure how it will work for this plugin
Possibly ignore Yahoo Trailer sources in the plugin
2013-01-27 14:52:29,455 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://www.hd-trailers.net/yahoo-redir.php?id=c89586ac-eb70-3014-b379-9deee9072fa7&resolution=480. It might not play.
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:409)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:89)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:127)
   ... 2 more
2013-01-27 14:52:31,099 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://www.hd-trailers.net/yahoo-redir.php?id=2de34cea-2b7e-35ef-85b2-fd2b42c164a4&resolution=480. It might not play.
   ... 2 more
2013-01-27 14:52:32,585 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://www.hd-trailers.net/yahoo-redir.php?id=21a8e8bf-195f-35bf-b291-694ef55ff93d&resolution=480. It might not play.
   ... 2 more
Post Mon Feb 04, 2013 2:25 am
Version 9 posted to support new yahoo format
RalfvdEnden
Post Thu Feb 21, 2013 7:35 pm
Kudos on this plugin. However, I ran into an issue with the apple feed today. The log shows the following:
2013-02-21 16:31:31,463 WARN [WebResourceParser] Plugin HDTrailers returned no value for resource item '[50]F*ck for Forest'
It's probably the asterix in the name breaking retrieval.
Cheers,
Ralf
Return to Available plugins
