serviidb.com
Xmantium
Post Thu Feb 21, 2013 11:02 pm
Re: serviidb.com
When I get some time over the weekend, I'll add all the plugins and logo.
Trying to have to find the right balance of logo background that suit both white and black themes.
Post Fri Feb 22, 2013 12:18 am
Re: serviidb.com
will wrote:OK, which ones are you planning on removing?
I think it is better to have it null rather than a default, that way the apps can provide one locally (could all be the same icon mind).
The no plugin required and coolsport is a bit ugly as well, not sure of an alternative.
I can implement device caching, but it is a bit of work. My main concern was not load time for users but extra bandwidth requirements for you.
I am planning onkeeping to the ones starting with Plugin.
Do not worry about the bandwidth my web server plan has 400GB monthly transfer. I have not even used half of my bandwidth and I have added cloudflare as a CDN / remote proxy. Which increases my bandwidth and should decrease the load time of the page and API around the world.
Post Sun Feb 24, 2013 4:46 pm
Re: serviidb.com
Are you able to fix the duplicate plugins?
Re: pluginAPIName vs pluginName, I don't really mind how it is used, as long as it is consistant. At the moment, the media items appear to point to pluginAPIName, if thats the case there is no point having too names but for some plugins it does look better to have the more user friendly pluginName versions. Anyway, I need to know which one to match against for when I release the next version of ServiiDroid early next week.
Post Tue Feb 26, 2013 7:34 pm
Re: serviidb.com
Bump, are you able to switch the references for media items back to pluginName rather than pluginAPIName
Post Thu Feb 28, 2013 5:08 pm
Re: serviidb.com
will wrote:Bump, are you able to switch the references for media items back to pluginName rather than pluginAPIName
Should be able to. Will look at it tonight. Sorry been busy at work.
Post Thu Feb 28, 2013 5:11 pm
Re: serviidb.com
I know that people have been having trouble with the API and site being slow. I figured out that google was indexing over 12,000 pages a day on my site. Instead of the 500 or so that it actually has. I did a couple of changes that should fix it. It should make the site faster.
Post Sat Mar 02, 2013 3:44 am
Re: serviidb.com
I have stage one of the changes complete, please check responses and let me know if there is any problems.
Post Sat Mar 02, 2013 9:05 am
Re: serviidb.com
Much better :)
Back to the content. Now that its set I'm not too fussed about the pluginAPIName being used for media items, so leave it how it is. I would however, like to understand how to add more pluginAPINames to the db, and how to remove the duplicate plugins that turn up via the API. It seams you can add a plugin, but you need the pluginAPIName to be there, which is a different type of term, is that correct?
Post Sun Mar 03, 2013 7:31 pm
Re: serviidb.com
I have enabled a FAQ page for serviidb.com. Please let me know anything that you think should be there.
@Will I am going to add a FAQ on how to enter content in the database.
Xmantium
Post Wed Mar 13, 2013 11:15 pm
Re: serviidb.com
ABC issue has been fixed, check it out! - https://www.dropbox.com/s/qtjlq5bmqtrr2 ... -29-12.png
I think the root of the problem was ABC had two website fields, thats why it may have appeared twice
Im actually using some plugins that i never used before as ServiiDB makes it so much easier to add and view content!
Hope other users finding new ways to use Serviio too.
Post Wed Mar 13, 2013 11:26 pm
Re: serviidb.com
I am testing a new server just to run the api and mysql database on. That should make the API more reliable and faster since I am using lighttpd instead of apache2 as the server. Hope to have it stable and updated by the end of this coming weekend.
This will also free up about 200 meg on the webserver VPS to make it more reliable.
Post Wed Mar 13, 2013 11:48 pm
Re: serviidb.com
moltra wrote:I am testing a new server just to run the api and mysql database on. That should make the API more reliable and faster since I am using lighttpd instead of apache2 as the server. Hope to have it stable and updated by the end of this coming weekend.
Cool. I have not followed this topic too much, but is it now stable enough to integrate it in the console? You'd probably get a lot more traffic.
Post Thu Mar 14, 2013 12:09 am
Re: serviidb.com
yes it has been pretty stable on the API side, plus once I get the API / database on its own server will be alot more stable
sounds good integrating to the console.
Post Thu Mar 14, 2013 4:29 pm
Re: serviidb.com
There are still two duplicated plugins, GameSpot and SHOUTcast show up under their category and also with no category, not sure how to fix it on the site. Could you look at it moltra?
Post Thu Mar 14, 2013 4:56 pm
Re: serviidb.com
Yep, planning on working on that and other items tonight
Xmantium
Post Thu Mar 14, 2013 8:58 pm
Re: serviidb.com
Would be MEGA cool if groovy plugins can be installed to the plugins folder like xbmc repo
Post Thu Mar 14, 2013 9:59 pm
Re: serviidb.com
Xmantium wrote:Would be MEGA cool if groovy plugins can be installed to the plugins folder like xbmc repo
Are you talking via the website or the API using one of the clients?
Post Fri Mar 15, 2013 1:01 am
Re: serviidb.com
will wrote:There are still two duplicated plugins, GameSpot and SHOUTcast show up under their category and also with no category, not sure how to fix it on the site. Could you look at it moltra?
Should be fixed. Had a problem in one of the background queries.
Post Fri Mar 15, 2013 8:03 am
Re: serviidb.com
Confirmed as fixed, thanks.
Post Sat Mar 16, 2013 2:01 pm
Re: serviidb.com
Hi moltra,
Your website is a very good idea and you make a good job, of course when Zip will include API to automatically add Source Url and plugin from your website it will be complete.
But I also have to said that from a user point of view, your website is not soo easy to update or navigate.
Some examples:
From a user point of view, what is the purpose of the link "API Response Time"?
How to update a plugin version from value 14 to 15 ? http://www.serviidb.com/content/trailer ... n=node/504, use the clone link ?
How to add a Compatible Devices ?
Another note... when I change section, I'm always disconnected and have to login again, why ?
Thanks,
Users browsing this forum: No registered users and 72 guests
