Serviio on UnRaid
Here is a post on the unRAID boards from someone who has already accomplished this.
#!/bin/sh
## Serviio start Script ##
DIRNAME=`dirname $0`
PROGNAME=`basename $0`
LANG=en_US.UTF-8
export LANG
# OS specific support (must be 'true' or 'false').
cygwin=false;
darwin=false;
linux=false;
case "`uname`" in
CYGWIN*)
cygwin=true
Darwin*)
darwin=true
Linux)
linux=true
esac
# For Cygwin, ensure paths are in UNIX format before anything is touched
if $cygwin ; then
[ -n "$SERVIIO_HOME" ] &&
SERVIIO_HOME=`cygpath --unix "$SERVIIO_HOME"`
[ -n "$JAVA_HOME" ] &&
JAVA_HOME=`cygpath --unix "$JAVA_HOME"`
fi
# Setup SERVIIO_HOME
if [ "x$SERVIIO_HOME" = "x" ]; then
# get the full path (without any relative bits)
SERVIIO_HOME=`cd $DIRNAME/..; pwd`
fi
export SERVIIO_HOME
# Setup the JVM
if [ "x$JAVA" = "x" ]; then
if [ "x$JAVA_HOME" != "x" ]; then
JAVA="$JAVA_HOME/bin/java"
else
JAVA="java"
fi
fi
# Setup the classpath
SERVIIO_CLASS_PATH="$SERVIIO_HOME/lib/serviio.jar:$SERVIIO_HOME/lib/derby.jar:$SERVIIO_HOME/lib/jcs.jar:$SERVIIO_HOME/lib/concurrent.jar:$SERVIIO_HOME/lib/freemarker.jar:$SERVIIO_HOME/lib/httpcore.jar:$SERVIIO_HOME/lib/jaudiotagger.jar:$SERVIIO_HOME/lib/jul-to-slf4j.jar:$SERVIIO_HOME/lib/jcl-over-slf4j.jar:$SERVIIO_HOME/lib/log4j.jar:$SERVIIO_HOME/lib/sanselan.jar:$SERVIIO_HOME/lib/slf4j-api.jar:$SERVIIO_HOME/lib/slf4j-log4j12.jar:$SERVIIO_HOME/lib/org.restlet.jar:$SERVIIO_HOME/lib/org.restlet.ext.xstream.jar:$SERVIIO_HOME/lib/xstream.jar:$SERVIIO_HOME/config"
# Setup Serviio specific properties
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dserviio.remoteHost=192.168.0.2"
# For Cygwin, switch paths to Windows format before running java
if $cygwin; then
SERVIIO_HOME=`cygpath --path --windows "$SERVIIO_HOME"`
JAVA_HOME=`cygpath --path --windows "$JAVA_HOME"`
SERVIIO_CLASS_PATH=`cygpath --path --windows "$SERVIIO_CLASS_PATH"`
fi
# Execute the JVM in the foreground
"$JAVA" -Xmx384M $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
2011-01-16 12:24:05,851 INFO [MediaServer] ------------------------------------------------------------------------
2011-01-16 12:24:05,852 INFO [MediaServer] Serviio DLNA media streaming server v 0.4.2 (rev. 683706a96104)
2011-01-16 12:24:05,853 INFO [MediaServer] Petr Nejedly 2009-2010
2011-01-16 12:24:05,853 INFO [MediaServer] http://www.serviio.org
2011-01-16 12:24:05,853 INFO [MediaServer] Java 1.6.0_11-Sun Microsystems Inc.
2011-01-16 12:24:05,853 INFO [MediaServer] OS Linux i386 2.6.32.9-unRAID
2011-01-16 12:24:05,853 INFO [MediaServer] File encoding: US-ASCII
2011-01-16 12:24:05,853 INFO [MediaServer] ------------------------------------------------------------------------
kjricker wrote:Yeah. I am looking into how to do that now. I have never compiled anything, so this may take me a while. I'll report back when I can get that done.
