SKYSPORTSPLUS - A SPORTS STREAM WEBRESOURCE
Yes - they are using rtmfp hence the questions
Re: SKYSPORTSPLUS - A SPORTS STREAM WEBRESOURCE
http://www.fengyunzhibo.com/
This the site they are using.So far very reliable streams.Any way of tapping these.
bobz wrote:http://www.fengyunzhibo.com/
If you can read feng shui..!
No offence intended
May be try google translate.
Hi!
I have a problem with the plugin, no items are shown. The log file says there should be 12 items, but the list is empty.
Thanks!
Thanks!
They have switched to some servers the plugin cannot decode. Hopefully I will post an improved version with Serviio 1.3
Ok, thank you for the reply and explanation. Is there any working plugin for sport streams? I'm especially interested in Golf. Or maybe there is any other solution for streaming from my PC to the WDTV Live Player?
Greetings!
Greetings!
try hahasport or stopstream
€: deleted
Please delete your post as it is a duplicate of the one I already answered. This thread is only for skysports and its status was posted above.
Currently seeing the following errors in the log file when trying to use the SkySports.Plus. This is the same for all the channels. Any ideas?
- Code:
2013-07-21 12:42:11,847 DEBUG [FeedItemUrlExtractor] skysportsplus: Starting extraction of url for item: ch99*11:00 GMT-England vs Australia Test *11:00 GMT-The British Open
2013-07-21 12:42:11,847 DEBUG [FeedItemUrlExtractor] skysportsplus: Source Link: http://www.cricfree.tv//star-cricket-live-stream-3.php
2013-07-21 12:42:11,979 DEBUG [FeedItemUrlExtractor] skysportsplus: Source Link 2: http://cricfree.tv/update/starcricket2.php
2013-07-21 12:42:12,089 DEBUG [FeedItemUrlExtractor] skysportsplus: http://cricfree.tv/update/starcricket2.php - http://movietrailers.yt/player2.js NOTFOUND
2013-07-21 12:42:12,089 DEBUG [FeedItemUrlExtractor] skysportsplus: Finished extraction of url: no result
2013-07-21 12:42:12,089 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2013-07-21 12:42:12,089 DEBUG [WebResourceParser] Skipping web resource item 'ch99*11:00 GMT-England vs Australia Test *11:00 GMT-The British Open' because it's not of type VIDEO
As explained above....
l need help.
log file shows [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
Quelletyp: Web Ressource
Quell-URL: http://www.skysports.plus
Software Version is 1.3.1
Plugin Version is 24
what I'm doing wrong???
plugin needs update, I think.
Dos it work for you?
I'm using http://atdhe.to/ or www.firstrow.org for soccer and it's quite good.. but there are ads Some streams without ads please ?
Nonsense. cricfree works fine and you are just spamming your movie site. Moderator should delete your id.
its not working or i do something wrong? i put the plugin in the right folder,then in online sources,i put cricfree.tv,and select web resources,its ok?
mine dont work either (skysports, hahasport...)
Is this plugin still working?
Im running Serviio 1.4 on an Intel QNAP with v24 of the plugin.
http://www.skysports.plus has been added as a web resource, my logs show the following:
(newest at the top)
(newest at the top)
- Code:
2014-01-25 12:55:38,187 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:37,854 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:37,564 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:37,265 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:36,997 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:36,740 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:36,443 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:36,165 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:35,754 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:35,476 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:35,182 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:34,910 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:34,657 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:34,357 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:34,118 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:33,836 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:33,537 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:33,247 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:33,015 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:32,741 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:32,495 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:32,226 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:31,946 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:31,707 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:31,440 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:31,169 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:30,810 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:29,938 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:29,702 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:29,349 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:29,052 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:28,787 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2014-01-25 12:55:22,175 INFO [PlaylistMaintainerThread] Started looking playlist changes
2014-01-25 12:55:22,167 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-01-25 12:55:22,166 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-01-25 12:55:21,977 INFO [PlaylistMaintainerThread] Finished looking for playlist changes
2014-01-25 12:55:21,877 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-01-25 12:55:21,777 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
