ILIVE - A Video Livestreams Server Collection
You delete a plugin from the same place that you add a plugin.
Re: ILIVE - A Video Livestreams Server Collection
Thanks really appreciate jhb50
Will try it when get home from work
Beta Tester
Beta Tester
It seems dead for me as well. It acts like it is scanning but the logs tell me error occurred "might not play"
Site has changed as posted 5 back.
Everyone still dead in the water with this one too? Mine was working great until just last week, now no feeds show up. Going to the website through a browser works fine.
I am not sure if it's a coincident or what but all ilive streams came right up after I recompile ffmpeg to v2.
Npuser
Npuser
Possibly you used the KSV modified librtmp rather than the git version which is used in the windows ffmpeg. If so it supports redirect which I live now reguires.
On my Linux NAS, ive compliled the latest ffmpeg v2.0 with librtmp from git, i got nearly all the streams
Wondering if the KSV patch will show me more streams - theres a easy guide to update it here - http://wiki.xbmc.org/index.php?title=HO ... te_librtmp
Is there a particular stream that uses the the KSV patch?
Xmantium wrote:On my Linux NAS, ive compliled the latest ffmpeg v2.0 with librtmp from git, i got nearly all the streams
@Xmantium, can we compile for WD Live? As you know powerpc builds using on this device.
jhb50 wrote:Possibly you used the KSV modified librtmp rather than the git version which is used in the windows ffmpeg. If so it supports redirect which I live now reguires.
It looks like they changed the link again so redirect is not required now.
Is there a recommendation to get it back to working on my OSX box? I have not modified anything outside of the default Serviio install. Do I need to do something with ffmpeg to get iLive to work again?
Go figure, its back. Cool.
Anyone seeing any problems out of this plugin today? I cant get videos to play from the site and sometimes it wont search the site for updated content.
They have locked them up.
Thanks for the reply. I figured it had to be something since my cbs plugins are still working.
Is anyone having issues streaming from ilive.to? Mine stopped working and I can't figure what the problem is. Channels are still streaming online on my pc so the problem is not that they're offline. Ilive folders show up on my DLNA device but there are no channels.
jhb50 wrote:http://forum.serviio.org/viewtopic.php?f=20&t=6086&view=unread&sid=604052930d33252d597991cdcc54acc8#p78311
I did all that. It was working fine until about 3 weeks ago.
2013-10-26 15:54:14,140 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://ny.iguide.to/edge playpath=2byvy55uocgnct8 swfurl=http://player.ilive.to/secure_player_ilive_z.swf pageurl=http://www.ilive.to live=1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:454)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:97)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:135)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:297)
... 2 more
... 2 more
to play ilive.to channels you need a token, so the right stream should look like that
" rtmp://ny.iguide.to/edge playpath=2byvy55uocgnct8 swfurl=http://player.ilive.to/secure_player_ilive_z.swf pageurl=http://www.ilive.to token=******** live=1
Ilive.to changes the token periodically, it would be great if we can change it manually in the plugin
Users browsing this forum: Google [Bot] and 17 guests
