Re: RTMP/RTMPE Support
We'll wait and see, I guess. Thanks for the help.
zip wrote:Right, it's probably missing some additional parameters (swfUrl etc). You should try to do the rtmpserv trick linked in the plugin dev guide - basically pretending your PC is the rtmp server, the player will send rtmp request to it and you'll be able to see the parameters thay are using.
rtmpdump --rtmp rtmp://cp53909.edgefcs.net:1935 --app 'ondemand?auth=daEc1aMaUa8dicCbYcKcmcSbda5cfaZb3b5-bqnQIz-8-mkt_xErqN&aifp=v001' --playpath mp4:flash/playback/_definst_/drwhoconfidential_06_07 --swfUrl http://www.abc.net.au/iview/images/iview.jpg --swfVfy 1 --swfsize 2122 --swfhash 96cc76f1d5385fb5cda6e2ce5c73323a399043d0bb6c687edd807e5c73c42b37 -o /home/god/Videos/drwho_confid2.mp4
2012-08-24 08:07:29,473 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmp://cp53909.edgefcs.net:1935 app=ondemand?auth=daEdXdUcKbibqc1amcEcDdacDcwcidoana8-bqnQMC-8-snr_xFzoL&aifp=v001 playpath=mp4:flash/playback/_definst_/drwhoconfidential_06_07 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1 swfsize=2122 swfhash=96cc76f1d5385fb5cda6e2ce5c73323a399043d0bb6c687edd807e5c73c42b37
2012-08-24 08:07:29,474 DEBUG [ProcessExecutor] Starting ffmpeg -i rtmp://cp53909.edgefcs.net:1935 app=ondemand?auth=daEdXdUcKbibqc1amcEcDdacDcwcidoana8-bqnQMC-8-snr_xFzoL&aifp=v001 playpath=mp4:flash/playback/_definst_/drwhoconfidential_06_07 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1 swfsize=2122 swfhash=96cc76f1d5385fb5cda6e2ce5c73323a399043d0bb6c687edd807e5c73c42b37
2012-08-24 08:07:29,503 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://cp53909.edgefcs.net:1935 app=ondemand?auth=daEdXdUcKbibqc1amcEcDdacDcwcidoana8-bqnQMC-8-snr_xFzoL&aifp=v001 playpath=mp4:flash/playback/_definst_/drwhoconfidential_06_07 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1 swfsize=2122 swfhash=96cc76f1d5385fb5cda6e2ce5c73323a399043d0bb6c687edd807e5c73c42b37. It might not play.
ffmpeg version 0.11.1.git Copyright (c) 2000-2012 the FFmpeg developers
built on Aug 22 2012 00:01:08 with gcc 4.6 (Ubuntu/Linaro 4.6.3-1ubuntu5)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-pthreads --disable-mmx --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree --enable-version3 --enable-librtmp --pkg-config=pkg-config
libavutil 51. 70.100 / 51. 70.100
libavcodec 54. 54.100 / 54. 54.100
libavformat 54. 25.104 / 54. 25.104
libavdevice 54. 2.100 / 54. 2.100
libavfilter 3. 11.101 / 3. 11.101
libswscale 2. 1.101 / 2. 1.101
HandleCtrl: Ignoring SWFVerification request, use --swfVfy!
duration 543.80
moovPosition 40.00
width 640.00
height 360.00
videocodecid avc1
audiocodecid mp4a
avcprofile 100.00
avclevel 41.00
aacaot 2.00
videoframerate 25.00
audiosamplerate 48000.00
audiochannels 2.00
tags:
©too Lavf52.39.2
trackinfo:
length 13595.00
timescale 25.00
language und
sampledescription:
sampletype avc1
length 26101760.00
timescale 48000.00
language und
sampledescription:
sampletype mp4a
length 48942000.00
timescale 90000.00
language und
sampledescription:
length 26095616.00
timescale 48000.00
language und
sampledescription:
Input #0, flv, from 'rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEcnaKdQaocedWbKa1cycda5dyc9dbd4aZ-bqoINR-8-mkr_tEvpJ&aifp=v001 playpath=mp4:flash/playback/_definst_/drwhoconfidential_06_07':
moovPosition : 40
avcprofile : 100
avclevel : 41
aacaot : 2
videoframerate : 25
audiochannels : 2
Duration: 00:09:03.79, start: 0.000000, bitrate: N/A
Stream #0:0: Video: h264 (High), yuv420p, 640x360, 25 tbr, 1k tbn, 50 tbc
Stream #0:1: Audio: aac, 48000 Hz, stereo, s16
