WEB PAGE TO BE VIEWED IN SERVIIO
venkat1926
Post Mon Nov 04, 2013 10:52 am
I have a web page
http://gaana.com/search/songs/JAYASHREE
it is audio only
I want to get this through serviio.
the url s as it is is not recognised by serviio
what should be correct entry in console-library-onlineresources against SOURCE URL
under what category shoulod this come
onlie rss /atom feed
live stsream
web resource
thanks.
Post Mon Nov 04, 2013 1:51 pm
Re: WEB PAGE TO BE VIEWED IN SERVIIO
You need to write a web resource plugin to access the webpage files.
venkat1926
Post Tue Nov 05, 2013 4:06 am
thanks . i understood. but too late to learn anohter language. I have to discard this web resource. I shall continue to get similar songs from you tube
thanks once again.
venkat1926
Post Fri Dec 13, 2013 5:49 am
apologies I was hasty in response. will somebody give me some advice how to go about writing plugin for gaana.com.(webresource). any sample will be helpful. I presume it should be in groovy.
I am able to view youtube videos of my music without any problem in serviio. I used plug in available in the forum and modified the url. as sugged e.g.
http://gdata.youtube.com/feeds/api/videos?v=2&q=H50tGvzzFzs
this is for individual songs.
but still problem with playlists. That also I have to solve later.
Return to Audio feeds
