Serviio not showing on Viera L32E6B
peter1212
Post Fri Nov 29, 2013 8:45 pm
Hi there,
I had just got my Serviio/server working again after a house move, and a new TV. The TV is a Panasonic L32 E6B, 32" smart TV hat is DLNA certified.
http://www.johnlewis.com/panasonic-vier ... hd/p424246
DLNA Information
YES
However after setting everything up again, but it still doesn't show.
Serviio is setup correctly (as in no changes from my last use, except the TV)
Profile is selected as Panasonic Viera E/S/ST/VT
File are shared and are able to be seen.
However on the TV Menu when I go to Apps > Media Server > view the list, Serviio does not appear, but the normal Windows Media Player does, so it's not a connectivity/network issue.
Is there a setting for smart TV's that I'm missing in order to get this to work?
Post Mon Dec 02, 2013 9:39 pm
Re: Serviio not showing on Viera L32E6B
Make sure port 8895 is open in your PC firewall / antivirus.
Return to Panasonic
