Re: Shoutcast Audio Web Resource Plug-in - Now Full Function
I hope so..
DiskStation> ffmpeg -i http://108.61.30.179:4010
ffmpeg version 2.0.2 Copyright (c) 2000-2013 the FFmpeg developers
built on Apr 8 2014 20:49:59 with gcc 4.6.4 (Linaro GCC branch-4.6.4. Marvell GCC Dev 201310-2126.3d181f66 64K MAXPAGESIZE ALIGN)
configuration: --prefix=/usr/syno --incdir='${prefix}/include/ffmpeg' --arch=arm --target-os=linux --cross-prefix=/usr/local/arm-marvell-linux-gnueabi/bin/arm-marvell-linux-gnueabi- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-shared --disable-static --enable-version3 --enable-nonfree --enable-libfaac --enable-encoders --enable-pthreads --disable-bzlib --disable-protocol=rtp --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --disable-ffserver --disable-ffplay --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --disable-decoder=amrnb --disable-encoder=zmbv --disable-encoder=dca --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-decoder=dca --disable-decoder=eac3 --disable-decoder=truehd --cc=/usr/local/arm-marvell-linux-gnueabi/bin/arm-marvell-linux-gnueabi-ccache-gcc
libavutil 52. 38.100 / 52. 38.100
libavcodec 55. 18.102 / 55. 18.102
libavformat 55. 12.100 / 55. 12.100
libavdevice 55. 3.100 / 55. 3.100
libavfilter 3. 79.101 / 3. 79.101
[mp3 @ 0x5a290] Header missing
Last message repeated 2 times
Input #0, mp3, from 'http://108.61.30.179:4010':
Duration: N/A, start: 0.000000, bitrate: 128 kb/s
Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 128 kb/s
Regardless, ?genre=xxxx doesn't work.
Users browsing this forum: Majestic-12 [Bot] and 33 guests
