Google Chromecast
jvskill
Post Thu Feb 06, 2014 2:31 am
Re: Google Chromecast
MichaelRHall wrote:Notice it states that directplay (ie NO transcoding) is supported for:
<VideoProfile container="mp4" codec="h264" audioCodec="aac" /> --- mp4 container, h264 video WITH aac audio.
<MusicProfile container="mp4" codec="aac" /> -- mp4 container with aac audio supported to 768k bitrate
<MusicProfile container="mp3" codec="mp3" /> -- mp3 supported up to 320k bitrate.
With Serviio is possible to transcode into the format above?
This website says it should be able to accept HLS containers which Serviio currently supports:
https://developers.google.com/cast/docs/media
However, some people on other forums have indicated that this is a more recent development with the release of the official SDK. I won't be able to test this again til Friday night but I will post logs again. Unfortunately, I still think the issue of Serviio not applying the desired profile to the Chromecast will persist.
MichaelRHall
Post Thu Feb 06, 2014 6:12 pm
Just another observation:
The HLS transcode plays fine on my phone (SG3) with Avia. But when I try to push it to Chromecast, it will not play on Chromecast. When Avia is setup as the remote for Chromecast, then the file is not transcoded. Both my phone and the chromecast are set to use the Google Applecast profile. Thinking that Chomecast was still set to use the Generic profile, I tried modifying the Generic profile to transcode like the Google Applecast profile, but that did not help.
The interesting part is that when Avia is used as a Remote for Plex Media Server, Plex Media Server does not transcode either. Plex Media Server works fine when played on Chrome on my pc and then pushed to Chromecast - sound and video both work for everything that I've tried. But with Avia as the remote with Plex Media Server as the source and Chromecast as the target, Plex Media Server does not transcode.
MichaelRHall
Post Tue Feb 11, 2014 12:47 am
OK, I got Chromecast working with Serviio transcoding to matroska while using the "Google AllCast" profile provided by mightymouse2045 earlier in this tread.
It requires a bit of hack, but it works. I saw a similar work around for a different Serviio limitation, check out the following for some related background on the work around: viewtopic.php?f=11&t=2956&start=30#p34000
The work around uses perl and the "ServiioService.exe.vmoptions" file (not sure if the feature to use "Dffmpeg.location" in ServiioService.exe.vmoptions was removed in Serviio version 1.4, but it definitely works in 1.3.1).
- On windows, install ActivePerl --> http://www.activestate.com/activeperl/downloads (for example in C:\Perl\)
- Edit "ServiioService.exe.vmoptions" file and change the Dffmpeg.location variable to use a ffmpeg wrapper in perl script, like this:
(use your own Serviio install path)
     -Xmx512m
     -Dffmpeg.location="c:\perl64\bin\perl.exe c:\progra~1\Serviio\serviio-ffmpeg.pl"
- Create a perl script for example on "c:\progra~1\Serviio\serviio-ffmpeg.pl" folder path, contains the following code:
     #!perl
     use strict;
     my $args = '';
     foreach my $arg (@ARGV) {
       $args .= "\"$arg\" ";
     # replaces mpegts with matroska
     if ($args =~ /^(.*)\s\"mpegts\"\s(.*)$/) {
       $args = $1 . ' "matroska" ' . $2;
     my $cmd = "\"C:\\Program Files\\Serviio\\lib\\ffmpeg.exe\" $args";
     open(LOGFILE, ">>C:\\Program Files\\Serviio\\ffmpeg-wrapper.log");
     print LOGFILE scalar localtime . " Starting: " . $cmd . "\n";
     if (system($cmd) != 0) {
       print LOGFILE scalar localtime . " Failed: " . $cmd . " with $?\n";
       close (LOGFILE);
       die "Failed\n";
     } else {
       print LOGFILE scalar localtime . " Succeeded: " . $cmd . "\n";
       close (LOGFILE);
The above work around has worked for all videos that I've tried: avi, mkv, mp4, mov. Plays both the video and audio in sync with no stuttering of play back.
The only issue that I've seen is the length of the movie is shown at over 347 hours for all movies, so determining how much time is remaining in the movie would be difficult.
It seems ffmpeg has no problems transcoding to matroska and most modern players have no problems playing matroska, I'm not sure why Serviio does not allow it.
jvskill
Post Tue Feb 11, 2014 2:32 am
I followed your instructions with no success, but I did see this error in the general log though:
2014-02-10 20:23:43,892 ERROR [MediaServer] FFMPEG not found. Serviio will not work properly.
Could this be breaking your solution? How would I fix this, since it looks like FFMPEG.exe is located in the lib folder as expected.
MichaelRHall
Post Tue Feb 11, 2014 4:28 am
By setting the -Dffmpeg.location variable in ServiioService.exe.vmoptions, you are telling Serviio to use a different path for FFMPEG. What normally happens when Servioo transcodes a file is that Serviio calls FFMPEG to do the work of transcoding. Serviio calls FFMPEG with a rather long parameter specifying the transcoding.
The call with the parameter looks something like this:
"C:\Program Files\Serviio\lib\ffmpeg.exe" "-threads" "2" "-i" "G:\New\myvideo.mkv" "-y" "-threads" "2" "-c:v" "libx264" "-profile:v" "baseline" "-level" "3" "-preset" "veryfast" "-b:v" "1200k" "-maxrate:v" "1200k" "-bufsize:v" "1200k" "-crf" "10" "-r" "24000/1001" "-g" "15" "-bsf:v" "h264_mp4toannexb" "-flags" "-global_header" "-c:a" "libmp3lame" "-b:a" "320k" "-ac" "2" "-map" "0:0" "-map" "0:1" "-sn" "-f" "mpegts" "C:\TEMP\Serviio\transcoding-temp-12093-cast2-ORIGINAL.stf"
But we don't want it to convert to "mpegts", we want "matroska". So we need to change "mpegts" to be "matroska", so that it looks like:
"C:\Program Files\Serviio\lib\ffmpeg.exe" "-threads" "2" "-i" "G:\New\myvideo.mkv" "-y" "-threads" "2" "-c:v" "libx264" "-profile:v" "baseline" "-level" "3" "-preset" "veryfast" "-b:v" "1200k" "-maxrate:v" "1200k" "-bufsize:v" "1200k" "-crf" "10" "-r" "24000/1001" "-g" "15" "-bsf:v" "h264_mp4toannexb" "-flags" "-global_header" "-c:a" "libmp3lame" "-b:a" "320k" "-ac" "2" "-map" "0:0" "-map" "0:1" "-sn" "-f" "matroska" "C:\TEMP\Serviio\transcoding-temp-12093-cast2-ORIGINAL.stf"
How do we do that? Well, Serviio won't allow transcoding to matroska, so we have to change the parameter, when Serviio is calling FFMPEG, with a script. So with the Dffmpeg.location variable, we need to tell Serviio to call a script that will transform the first string above into the second and then run the transcoding. So -Dffmpeg.location="c:\perl64\bin\perl.exe c:\progra~1\Serviio\serviio-ffmpeg.pl" tells Serviio to use "c:\perl64\bin\perl.exe c:\progra~1\Serviio\serviio-ffmpeg.pl" as the location for FFMPEG. So when Serviio thinks it's calling FFMPEG to do the transcoding, it will instead launch a Perl script that transforms the parameter, the first string above, into the second and then runs the transcoding.
So, about the error you are encountering, Serviio is saying what ever you put in for the Dffmpeg.location variable is not valid. Some things to check:
1 - Did you install Perl? If so, what is the path to Perl? Is it "c:\perl64\bin\perl.exe"? If not, you'll need to change the Dffmpeg.location variable to your path.
2 - Where did you create the serviio-ffmpeg.pl script? Was it "c:\progra~1\Serviio\serviio-ffmpeg.pl"? If not, you'll need to change the Dffmpeg.location variable to your path.
3 - Look in the serviio-ffmpeg.pl script, there is a command that calls ffmpeg.exe, is the path on your PC the same as the one in the script? If not, you'll need to change the script to the correct path.
I hope this helps!
jvskill
Post Thu Feb 13, 2014 12:12 am
Here's some screenshots to see how I implemented your fix:
Plus the error when I tried for all 3 of these files. 1 AVI (not previously working, didn't work), 1 MKV (not previously working, didn't work), and 1 MP4, (previously worked, didn't work)
2014-02-12 18:02:48,488 WARN  [ResourceDeliveryProcessor] Invalid request, sending back 500 error
org.serviio.dlna.UnsupportedDLNAMediaFileFormatException: No media description available for required version: AVC_TS_MP_SD_AAC_MULT5_ISO
   at org.serviio.delivery.resource.AbstractDeliveryEngine.findMediaInfoForFileProfile(AbstractDeliveryEngine.java:292)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.getMediaInfoForMediaItem(AbstractDeliveryEngine.java:127)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResourceInfo(MediaResourceRetrievalStrategy.java:181)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:80)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
   at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
Also, the ffmpeg-wrapper.log did not get built. I can get the more detailed logs if needed.
frer
Post Thu Feb 13, 2014 2:53 am
I'm not an expert at all with Serviio so sorry if this has been answered before in this thread. I am trying configuring Chromecast with Avia. With the AllCast, SmartCast and AppleCast I'm able to play MP4s and MKVs which is great. Unfortunately .AVIs do not play at all. I've tried the Perl solution that is suggested by MichaelRHall but to no avail.
Have I missed something in this thread or does anyone know how I can try to debug the problem?
PS: When I modify the profile in the console for the Avia device and save. As soon as I exit the console and go back later, the profile is reverted to the generic profile. Any idea why?
marinos35
Post Thu Feb 13, 2014 3:00 pm
To clarify some things
Chromecast supports mainly
The Default Media Receiver supports the following media types:
Video codecs: H.264 High Profile Level 4.1, 4.2 and 5, VP8
Audio decoding: HE-AAC, LC-AAC, CELT/Opus, MP3, Vorbis
Image formats: BMP, GIF, JPEG, PNG, WEBP
Containers: MP4, WebM
When someone develops a receiver app for chromecast (like Avia did) they can choose if they want to add some additional support
Media Player Library
The Google Cast SDK includes a media player library that simplifies support for other scenarios that require DRM or Adaptive Bitrate Streaming. You can use this library in conjunction with a Custom Receiver to add support for the following media types:
Containers: MPEG-DASH, SmoothStreaming, HTTP Live Streaming (HLS)
Level 1 DRM support: Widevine, PlayReady
Subtitles:
TTML - Timed Text Markup Language
WebVTT - Web Video Text Tracks
Note: The Media Player Library is currently in beta release.
Avia probably hasn't added the Media Player Library, so their receiver mainly supports (as well as the default receiver) only the first quoted formats
I'll also try to create a transcoding profile, so I thought I should give here some info of the support limitations
MichaelRHall
Post Thu Feb 13, 2014 6:01 pm
jvskill - Your setup looks very similar to mine. I encountered that error when both Avia and Chromecast were not both set to the "Google AllCast" profile - for me it was when just Avia was set to use the "Google AllCast" and Chromecast was not set to use any Profile.
A related issue is that Serviio does not seem to show the Chromecast device in the Serviio Console Status. The way I got around this issue was by changing IP addresses. Serviio could see my phone as Avia Media Renderer and my PC as an Unrecognized Device. But did not show Chromecast in the Serviio Console Status list. So I changed the IP Address on my PC by messing with the router DHCP list so that it tied my PC's MAC address to a new IP address (internal to my network). Serviio Console Status then saw my PC on the new IP Address, but left the old IP Address that the PC used to be on in the Serviio Console Status list, even though it was not being used. Then I went back to the router and tied Chromecast (by MAC address) to that IP Address. Set both the IP Address of Chromecast, and my phone to "Google AllCast". Restarted Serviio Service and then it worked.
So there does seem to be an issue with Serviio recognizing the Chromecast. But luckily Serviio doesn't fully clean up its list.
MichaelRHall
Post Thu Feb 13, 2014 6:24 pm
jvskill - One thing I noticed about your setup that will cause problems is the space in the Dffmpeg.location variable in ServiioService.exe.vmoptions. You have -Dffmpeg.location="c:\perl64\bin\perl.exe C:\Program Files\Serviio\serviio-ffmpeg.pl" where I have -Dffmpeg.location="c:\perl64\bin\perl.exe c:\progra~1\Serviio\serviio-ffmpeg.pl". The space in "Program Files" will cause problems.
frer
Post Sat Feb 15, 2014 1:26 am
Hi again,
As mentioned in my earlier post, mp4s and mkvs are working fine with the generic profile. AVIs don't work though so I guess I only need transcoding for these. I tried modifying the Chromecast profile and changing the video decoding for:
         <Video targetContainer="mpegts" targetVCodec="h264" targetACodec="mp3" aBitrate="320" forceStereo="true">
            <Matches container="avi" />
         <Audio targetContainer="mp3" aBitrate="320">
            <Matches container="flac" />
            <Matches container="ogg" />
            <Matches container="adts" />
            <Matches container="mp2" />
            <Matches container="wavpack" />
            <Matches container="mpc" />
            <Matches container="ape" />
         </Audio>
      <OnlineTranscoding>
      </OnlineTranscoding>
      <HardSubsTranscoding>
         <Video targetContainer="mpegts" targetVCodec="h264" targetACodec="mp3" aBitrate="320" forceStereo="true"/>
      </HardSubsTranscoding>
Still I get an error for Unsupported file format in Avia and chromecast. Here is the log:
2014-02-14 20:01:49,657 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.10.102, Profile=Google ChromeCast'
2014-02-14 20:01:49,658 DEBUG [ResourceDeliveryProcessor] Request for resource 646 and type 'MEDIA_ITEM' received
2014-02-14 20:01:49,658 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 646 (local)
2014-02-14 20:01:49,671 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 646, format AVC_TS_MP_SD_MPEG1_L3_ISO and profile Google ChromeCast
2014-02-14 20:01:49,672 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file The.Walking.Dead.S01E01.Days.Gone.Bye.HDTV.XviD-FQM.avi
2014-02-14 20:01:49,672 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The.Walking.Dead.S01E01.Days.Gone.Bye.HDTV.XviD-FQM.avi: AVC_TS_MP_SD_MPEG1_L3_ISO
2014-02-14 20:01:49,675 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 646 (local)
2014-02-14 20:01:49,677 DEBUG [VideoDeliveryEngine] Delivering item '646' for client 'Identifier=192.168.10.102, Profile=Google ChromeCast'
2014-02-14 20:01:49,677 DEBUG [VideoDeliveryEngine] Delivering file 'The.Walking.Dead.S01E01.Days.Gone.Bye.HDTV.XviD-FQM.avi' using transcoding
2014-02-14 20:01:49,677 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.10.102, Profile=Google ChromeCast'
2014-02-14 20:01:49,683 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\Videos\The Walking Dead\Season 1\The.Walking.Dead.S01E01.Days.Gone.Bye.HDTV.XviD-FQM.avi
2014-02-14 20:01:49,683 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -threads 2 -i E:\Videos\The Walking Dead\Season 1\The.Walking.Dead.S01E01.Days.Gone.Bye.HDTV.XviD-FQM.avi -y -threads 2 -c:v libx264 -profile:v baseline -level 3 -preset veryfast -crf 10 -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a copy -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-646-cast2-ORIGINAL.stf
2014-02-14 20:01:49,725 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2014-02-14 20:01:49,738 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-02-14 20:01:49,919 DEBUG [ServiioHttpService] Incoming request from /192.168.10.110:48873: POST /serviceControl HTTP/1.1, headers = [User-Agent: Android/4.4.2 UPnP/1.0 Cling/2.0,Soapaction: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",Content-Type: text/xml;charset="utf-8",Host: 192.168.10.100:8895,Content-Length: 489]]
2014-02-14 20:01:49,919 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.10.110
2014-02-14 20:01:49,920 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.10.110
2014-02-14 20:01:49,921 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.10.110
2014-02-14 20:01:49,928 DEBUG [ContentDirectory] Browse() called for renderer aVia Media Renderer (profile cast2) with parameters: objectID = I_F^FOL_R1, browseFlag = BrowseDirectChildren, filter = *, startIndex = 200, count = 20, sortCriteria = +dc:title
2014-02-14 20:01:50,000 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.110:49468s
2014-02-14 20:01:50,458 DEBUG [ImageDeliveryEngine] Retrieving resource information for item 1912 and profile Google ChromeCast
2014-02-14 20:01:50,458 DEBUG [ImageDeliveryEngine] Getting media info for transcoded versions of file echo.JPG
2014-02-14 20:01:50,469 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2014-02-14 20:01:50,500 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-02-14 20:01:51,004 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.110:49468s
2014-02-14 20:01:51,204 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-02-14 20:01:51,205 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The.Walking.Dead.S01E01.Days.Gone.Bye.HDTV.XviD-FQM.avi: AVC_TS_MP_SD_MPEG1_L3_ISO
2014-02-14 20:01:51,257 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-02-14 20:01:51,257 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-14 20:01:51,259 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-02-14 20:01:51,259 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Date: Sat, 15 Feb 2014 01:01:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache-control: no-cache,Content-Range: bytes 0-49999999999/50000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-02-14 20:01:52,010 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.110:49468s
2014-02-14 20:01:52,350 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: E:\Google Drive\Multimedia\5754 Somerled\047.AVI
2014-02-14 20:01:52,429 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i E:\Google Drive\Multimedia\5754 Somerled\047.AVI
2014-02-14 20:01:53,012 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.10.110:49468s
2014-02-14 20:01:53,421 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
Any idea what is wrong with my setup or how I can get these to work?
THanks
mmarauder
Post Sat Feb 15, 2014 3:24 am
I've gone through every option in this forum, except for the perl idea( i;m running on a linux software nas and didnt feel like with messing with that).
The other renderr options did not change anything for me. I'm not able to stream any MKV or AVI. I can however play mp4 fine. This isn't helpful for me as 95% of my files are mkv or avi.
I've given my chromecast a static lease through my firewall and it doesn't show up in serviio. I'm using serviio 1.4 Any further developments now the SDk has been released?
Post Sat Feb 15, 2014 7:13 am
Chromecast won't show up in the console because it isn't a DLNA device. You have to give a DLNA device an IP, and then reallocate that IP to the Chromecast.
Tbh, Chromecast isn't designed with DLNA or transcoding in mind. For it to work reliability will require some coordinated integration to both Serviio and the DLNA controller apps. At a minimum Serviio would need to try and discover Chromecast devices and add them to the console so that a profile can be assigned. Luckily the CDS API that ServiiGo (and MediaBrowser) uses passes the parameter directly, so while I have quite a few things to implement it should be slightly easier to get things up and running with ServiiGo, but the SDK was only released on Thursday night for Android so have only had a quick look.
bgonev
Post Tue Sep 23, 2014 12:42 pm
Has anyone found a solution for this ? Has anyone successfully created a working profile for Chromecast ?
Techlyfe
Post Wed Nov 19, 2014 3:36 am
bgonev wrote:Has anyone found a solution for this ? Has anyone successfully created a working profile for Chromecast ?
I simply got around this issue by using BubbleUpnp server and android app, which hooks into Serviio. All my issues with whatever format wasnt supported became a non issue. Damn, I just relized how late I am to this thread. Back to lurking, nothing to see here folks.
vtaylor
Post Tue Jan 06, 2015 12:02 pm
Salut Techlyfe
My first post.
Can you expand on what you did, please ? I'm trying to get (or see) Servioo/Bubbleupnp working with my Chromecast. Trying to see as the media servers are on my Syno DS214 and I don't know if it is up to transcoding. Anyway, I installed Servioo because I didn't know how to install ffmpeg/H264 for the Bubbleupnp Syno - the Bubbleupnp page says "ffmpeg has no libx264 support". I was hoping Servioo would do the transcoding for me but apparently not.
Any pointers, please ?
Vernon
ericlmccormick
Post Fri Jul 08, 2016 1:39 pm
Looks like it has been a while since someone posted here but it doesn't look like a real solution was ever found. Using BubbleUPNP bypasses the purpose of using serviio in the first place as it put the transcoding on my phone, killing my battery. I am running Serviio on my Synology that has hardware transcoding and I stream everything to my Chromecast via LocalCast and/or AllCast. Everything works great for MP4 and MKV files but when trying to load a AVI, it says not supported. I feel like there should be a simple way that tells Serviio to transcode everything no mater what the file type and no matter what the device to h264 and mp3/ACC.
Maybe this is making a specific profile or editing the generic profile but it looks from previous post that no one has a working profile. If you have one, please post your profiles.xml file.
freaknik
Post Mon Jul 18, 2016 2:14 am
I have a chromecast and use a phone with the chrome app and go to my mediabrowser and cast to chromecast, it transcodes everything perfectly.
carpler
Post Tue Sep 12, 2017 12:22 pm
I'm asking if someone found a solution to use Serviio directly with Chromecast (also with transcoding function).
I'm tried to use Bubblupnp and it works, but it's necessary to install BubbleUpnp Server on the same machine where Serviio is, and this is not a solution I like so much...
In this thread there was many attempts to let Serviio transcode and work directly with Chromecast, but it seems to me that non finally solution was found.
What I've not understand is if the paid version can help on this.
For example: Serviigo on android phones is compatible with Chromecast? There is another app (free or paid) that can be used?
Not a problem to buy the Pro version of Serviio, but not so much information on official site or here in the forum...
freaknik
Post Mon Dec 04, 2017 9:04 pm
If you have chrome browser on your phone thats all you need.
Go to http://IPOFYOURSERVIIO:23424/mediabrowser
And start playing a movie.
Click the chromecast icon in the upper left. If it doesn't appear right away, tap the screen.
Then it casts to the screen.
According to the log, mine uses the profile "HTML5".
So I edit this profile to play at 720 and it works, all vids are playing and in 720, flv, rmvb, all formats.
Previous
