Web UI in PHP - support thread
Xmantium
Post Sun Feb 01, 2015 6:11 pm
Re: Web UI in PHP - support thread
Its changed to "Add local..."
M3kk
Post Mon Feb 02, 2015 1:42 pm
Not really.. Add Local is for browsing, Add Path is to write directly the Path..
Swoop
Post Mon Feb 09, 2015 10:23 pm
Update is close ;)
Swoop
Post Tue Feb 10, 2015 11:53 am
...and now done ;) HF
M3kk
Post Wed Feb 11, 2015 9:47 am
Thanks, a bit bugged, but its OK :).
Swoop
Post Wed Feb 11, 2015 9:15 pm
Why bugged?
M3kk
Post Fri Feb 27, 2015 10:41 am
With removing or adding shared folder is bugged. For example when i want to remove an entry, he removes the other one and so on :).
Swoop
Post Sat Feb 28, 2015 1:09 pm
Thanks for mentioning. I'll have a look ;)
ddfs
Post Thu Apr 09, 2015 7:27 am
I confirm that I have the same bug with adding/removing a path. When this will be fixed? ;)
Swoop
Post Thu Apr 16, 2015 10:27 pm
Hm, I should avoid putting in too much garbage for testing... Apparently, I tend to overlook stuff then :oops:
Should have been fixed. DL the updated version and give it a shot and let me know.
madseason41
Post Tue Apr 21, 2015 2:06 pm
After corrupting my install, I reinstalled both serviio and the latest webui. I seem to be having library path issues as well. I saved 2 library paths and they saved and scanned. I cannot add a third path. When I attempt this I get either a http error 0 box and or it removes other library paths.
I am running the latest git version, downloaded last night.
Thoughts?
Post Tue Apr 21, 2015 3:15 pm
Make sure your paths are not duplicate, eg:
c:\a\b
c:\a\b\c
This would throw an error as all files from c:\a\b are already shared anyway.
madseason41
Post Tue Apr 21, 2015 3:40 pm
They are not and the error just introduced itself after the reinstall.
Paths are desired to be:
/share/Multimedia/Video/TV Shows
/share/Multimedia/Video/Movies
/share/Multimedia/Music/iTunes
/share/Multimedia/Photos
I don't think the above is redundant or should cause problems?
Swoop
Post Tue Apr 21, 2015 8:48 pm
I think madseason41 has made another one up. I was able to reproduce it with using "add local" as an ID doesn't count up correctly. However, it doesn't seem to happen if you use "add path". Strange enough since both basically use the same functions. Will try to figure it out shortly.
You might wanna try using "add path" meanwhile?!
Swoop
Post Tue Apr 21, 2015 9:04 pm
Should be ok now. What a simple +1 can do :D
madseason41
Post Tue Apr 21, 2015 9:07 pm
You know, in my slumber of troubleshooting, I think I added the second library by choosing add path.
After coming back to add the rest I diverted back to "add local" and started noticing errors.
After trying the "add path" method to add the rest of the libraries it seems to do the trick.
Sorry if I missed this in the thread!
Swoop
Post Tue Apr 21, 2015 9:45 pm
It does not necessarily matter which one you use as either should worl but thanks for highlighting this. Reproducing it screwed my lib since the path has been overwritten somehow so it was indeed an error :lol:
madseason41
Post Tue Apr 21, 2015 10:29 pm
Hmm maybe that's how my library got messed up. That was the reason i did a fresh install.
Regardless the latest version seems to work.
Wixie
Post Sun May 03, 2015 6:03 pm
How can i password protect the webgui ?
Swoop
Post Thu May 07, 2015 10:16 pm
You have to have a .htaccess file in the corresponding directory. Just fire up google and it will guide you through ;)
