Version 1.5 released
We are pleased to announce that version 1.5 is available for download.
This version is mostly focused on making using Serviio easier and less error-prone for the users. Java now comes bundled with the Windows and OSX versions, so you don't need to install it on your system manually and deal with problems when your Java gets updated. Linux users still have to install Java 8 (which is now the minimum requirement). OSX version is now distributed as an installer and starts the server as a service when your Mac boots up - no more Force close when shutting down your Mac. Only 64-bit Macs are supported now.
The library indexing engine has been reworked, so that you get your filesystem changes reflected in the library immediately, without the need of a constant refresh. It should also make the process less CPU intensive. Remote drives are also handled differently without any side effects.
Apart from these, there are many smaller improvements and fixes.
As always, thanks go to the testers, translators and the guys helping at the forum.
Petr
Help translate Serviio
