Page 1 of 1
flac inside mkv on es6100
PostPosted: Sat Feb 02, 2013 11:39 am
by jules
hey,
i have a ue55es6100 it plays most of the videos that serviio sends to it just fine, but the damned thing doesn't seem to want to play flacs as sound tracks inside of mkv videos. i'm on the samsung C/D/E profile and with transocding disabled, serviio sends the file to the tv and the tv tells me it doesn't support the flac audio codec (while actual .flac music files it can play fine), however it plays the video and lets me change to the other audio tracks.
when transcoding is enabled (i assume that this should just cause serviio to use ffmpeg to transcode the flac audio inside the files to something the tv can digest, yes?) and i send one of these files to the tv using av media controller, i get an error in av media controller saying
[TV]UE55ES6100 failed to create a connection. SetAVTransport_FAILED
and serviio's debug log says
2013-02-02 12:37:14,284 DEBUG [WebServer] Incoming connection from /192.168.0.125:55009
2013-02-02 12:37:14,284 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.125
2013-02-02 12:37:14,285 DEBUG [ResourceTransportRequestHandler] HEAD /resource/135/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.64:8895]]
2013-02-02 12:37:14,285 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.125
2013-02-02 12:37:14,285 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.125, Profile=Samsung TV / player (C/D/E-series)'
2013-02-02 12:37:14,285 DEBUG [ResourceDeliveryProcessor] Request for resource 135 and type 'MEDIA_ITEM' received
2013-02-02 12:37:14,285 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 135 (local)
2013-02-02 12:37:14,285 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 135)
2013-02-02 12:37:14,286 DEBUG [VideoDAOImpl] Reading a Video (id = 135)
2013-02-02 12:37:14,286 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 135, format MATROSKA and profile Samsung TV / player (C/D/E-series)
2013-02-02 12:37:14,286 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file sample.mkv
2013-02-02 12:37:14,286 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file sample.mkv: AVC_TS_MP_HD_AC3_T
2013-02-02 12:37:14,286 WARN  [ResourceDeliveryProcessor] Invalid request, sending back 500 error
org.serviio.dlna.UnsupportedDLNAMediaFileFormatException: No media description available for required version: MATROSKA
   at org.serviio.delivery.resource.AbstractDeliveryEngine.findMediaInfoForFileProfile(AbstractDeliveryEngine.java:254)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedMediaInfoForVersion(AbstractTranscodingDeliveryEngine.java:149)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.getMediaInfoForMediaItem(AbstractDeliveryEngine.java:109)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResourceInfo(MediaResourceRetrievalStrategy.java:151)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:91)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
i've looked through profile.xml, but can't quite figure out how the transcoding tags work. Because it *seems* like there's already an entry for my particular situation in place that doesn't seem to do its work:
            <Video targetContainer="m2ts" targetACodec="ac3">
on a possibly related sidenote, i've gone ahead and manually compiled ffmpeg using the source from here (linked from the downloads page) using these instructions.
ffmpeg's output:
  built on Feb  2 2013 12:24:10 with gcc 4.6.3
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
Input #0, matroska,webm, from '/media/q/sample.mkv':
    creation_time   : 2011-09-25 22:27:39
  Duration: 00:01:09.23, start: 0.000000, bitrate: 17749 kb/s
    Chapter #0.0: start 0.000000, end 69.235000
      title           : 00:03:11.733
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1480x1080, SAR 1:1 DAR 37:27, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      title           :
    Stream #0:1(eng): Audio: flac, 48000 Hz, mono, s16 (default)
      title           : FLAC 1.0 200 kbps
    Stream #0:2(eng): Audio: aac, 48000 Hz, mono, s16
      title           : Commentary1 AAC 1.0 36 kbps
    Stream #0:3(eng): Audio: aac, 48000 Hz, mono, s16
      title           : Commentary2 AAC 1.0 36 kbps
    Stream #0:4(eng): Subtitle: text
what's odd is that while av media controller errors out as above, bubbleupnp on my android phone successfully sends the file to the tv which then however tells me that the file is not supported.
tl;dr:
transcoding off: video starts on tv, tv says audio codec not supported
transcoding on: av media controller gives an error, bubbleupnp sends to tv, but tv errors out
there just doesn't seem to be any transcoding going on at all.
Re: flac inside mkv on es6100
PostPosted: Sun Feb 03, 2013 2:29 am
by jules
i've got the distinct feeling that serviio's samsung tv C/D/E series profile doesn't have working transcoding information for the ES series (or at least my particular model), as there are a lot of things now that don't work, among them:
  • anything i add as an online resource and plays fine via VLC or on the phone
  • any .mkv file with h264 video and FLAC audio
just seems like there's no transcoding going on at all, as the tv always instantly tells me i'm trying an unsupported format.
here's the device spy output:
http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO
http-get:*:image/png:DLNA.ORG_PN=PNG_TN
http-get:*:image/png:DLNA.ORG_PN=PNG_SM_ICO
http-get:*:image/png:DLNA.ORG_PN=PNG_LRG_ICO
http-get:*:audio/vnd.dolby.dd-raw:DLNA.ORG_PN=AC3;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=AMR_3GPP;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/3gpp:DLNA.ORG_PN=AMR_WBplus;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/x-sony-oma:DLNA.ORG_PN=ATRAC3plus;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_LTP_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_MULT5_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L3_ADTS;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L3_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=BSAC_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/mp4:DLNA.ORG_PN=BSAC_MULT5_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO;DLNA.ORG_FLAGS=8D100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_PAL;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_NTSC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_PAL_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_NTSC_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_ATRAC3plus;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_SP_MPEG2_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_SP_G726;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_HEAAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_ATRAC3plus;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_HEAAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L5_SO_G726;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_HEAAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L4_SO_G726;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_MP4_P0_L10_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_3GPP_P0_L10_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_CO_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_MPEG2_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_CO_MPEG2_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_CO_MPEG2_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_3GPP_P3_L10_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_HEAAC_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_HEAAC_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_BSAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_BSAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_ATRAC3plus;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3_SD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_HEAAC_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_HEAAC_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L2_CIF30_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_BSAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_940;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_HEAAC_L2;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_HEAAC_L2_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_HEAAC_L2_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_LTP_520;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L12_CIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L1B_QCIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_CIF30_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_CIF15_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_HEAAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AMR_WBplus;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHM_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_MP3;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000
http-get:*:text/xml:SEC.COM_DIDLSIMAGE=1;SEC.COM_DIDLSAUDIO=1;SEC.COM_DIDLSVIDEO=1
http-get:*:image/jpeg:*
http-get:*:image/png:*
http-get:*:image/bmp:*
http-get:*:audio/mpeg:*
http-get:*:audio/x-ms-wma:*
http-get:*:audio/mp4:*
http-get:*:audio/x-m4a:*
http-get:*:audio/3ga:*
http-get:*:audio/ogg:*
http-get:*:audio/x-wav:*
http-get:*:audio/x-flac:*
http-get:*:smi/caption:*
http-get:*:video/x-msvideo:*
http-get:*:video/x-ms-asf:*
http-get:*:video/x-divx:*
http-get:*:video/x-ms-wmv:*
http-get:*:video/x-mkv:*
http-get:*:video/mp4:*
http-get:*:video/x-avi:*
http-get:*:video/avi:*
http-get:*:video/x-flv:*
http-get:*:video/mpeg:*
http-get:*:video/3gpp:*
http-get:*:video/webm:*
any pointers?
PostPosted: Sun Feb 03, 2013 11:54 am
by zip
It looks like a problem with the controller. It asks to play the file natively but Serviio wants to transcode, therefore then there is an error. Are you using the c/d/e profile for the controller IP? Can you play the file when browsing on the tv?
It's also possible that the controller sw cached some stuff and didn't register the fact you turned transcoding on.
PostPosted: Sun Feb 03, 2013 2:11 pm
by jules
ah man, it never even occurred to me to set a profile for the controller. this now lets me play everything fine!
i find it both absurd and inspiring that you provide so much firstline support for your application. i'll buy one of your licenses now, sir.
