Impossible to stream some online sources
Dear all,
I'm using Serviio for more than a year, to stream movies & music from my computer to my Sony Bravia 2011 TV, and it works like a charm !
Recently, I saw Serviio is able to stream online contents, so I'm giving a try. After having solved the "no sound" issue, I'm now faced with a big issue... some contents are not streaming and others are. I even have contents who never stream, others always stream, and some stream sometimes... It's going to make me crazy !
I've activated the debug log file (servio.log), and below are an example of one working stream, and one non working stream (I've replaced URL by "http://path_to_online_stream").
Serviio server is running on Linux ubuntu.
Many many thanks for your help... before I'm becoming fully crazy !
OK STREAM:
2018-06-10 12:21:19,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2018-06-10 12:21:29,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2018-06-10 12:21:36,897 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:45602: HEAD /resource/1000002020001359/MEDIA_ITEM/AVC_TS_HP_HD_MPEG1_L2_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:21:36,897 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:36,898 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:36,899 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:21:36,899 DEBUG [ResourceDeliveryProcessor] Request for resource 1000002020001359 and type 'MEDIA_ITEM' received
2018-06-10 12:21:36,899 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000002020001359 (online)
2018-06-10 12:21:36,900 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000002020001359, format AVC_TS_HP_HD_MPEG1_L2_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:21:36,902 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:21:36 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:21:36,917 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:45603: GET /resource/1000002020001359/MEDIA_ITEM/AVC_TS_HP_HD_MPEG1_L2_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:21:36,917 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:36,918 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:36,919 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:21:36,919 DEBUG [ResourceDeliveryProcessor] Request for resource 1000002020001359 and type 'MEDIA_ITEM' received
2018-06-10 12:21:36,919 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000002020001359 (online)
2018-06-10 12:21:36,920 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000002020001359, format AVC_TS_HP_HD_MPEG1_L2_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:21:36,921 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000002020001359 (online)
2018-06-10 12:21:36,922 DEBUG [VideoDeliveryEngine] Delivering item '1000002020001359' for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:21:36,923 DEBUG [VideoDeliveryEngine] Delivering file 'http://path_to_online_stream/1847.ts' in native format
2018-06-10 12:21:36,925 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-06-10 12:21:36,925 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:21:36 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:21:36,925 INFO [PlaybackEventsManager] Playback of media item 1000001010001166 (http://path_to_online_stream/360.ts [http://path_to_online_stream/360.ts]) has stopped at 0% on Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:21:36,926 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2018-06-10 12:21:36,927 INFO [PlaybackEventsManager] Playback of media item 1000002020001359 (http://path_to_online_stream/1847.ts [http://fpath_to_online_stream/1847.ts]) has started at 0% on Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:21:36,995 DEBUG [OnlineInputStream] 302 returned, redirecting to http://path_to_online_stream/1847.ts?to ... 5HUVcBDhEe
2018-06-10 12:21:36,995 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2018-06-10 12:21:37,125 DEBUG [OnlineInputStream] Byte range not supported for http://path_to_online_stream/1847.ts?to ... 5HUVcBDhEe, returning the whole stream
2018-06-10 12:21:39,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2018-06-10 12:21:40,497 DEBUG [OnlineInputStream] Closing stream
2018-06-10 12:21:40,498 DEBUG [WebServer] I/O error: Broken pipe (Write failed)
2018-06-10 12:21:40,501 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:45604: GET /resource/1000002020001359/MEDIA_ITEM/AVC_TS_HP_HD_MPEG1_L2_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:21:40,501 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:40,502 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:21:40,502 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:21:40,502 DEBUG [ResourceDeliveryProcessor] Request for resource 1000002020001359 and type 'MEDIA_ITEM' received
2018-06-10 12:21:40,503 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000002020001359 (online)
2018-06-10 12:21:40,503 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000002020001359, format AVC_TS_HP_HD_MPEG1_L2_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:21:40,504 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000002020001359 (online)
2018-06-10 12:21:40,505 DEBUG [VideoDeliveryEngine] Delivering item '1000002020001359' for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:21:40,506 DEBUG [VideoDeliveryEngine] Delivering file 'http://path_to_online_stream/1847.ts' in native format
2018-06-10 12:21:40,506 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-06-10 12:21:40,506 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:21:40 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:21:40,506 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2018-06-10 12:21:40,555 DEBUG [OnlineInputStream] 302 returned, redirecting to http://path_to_online_stream/1847.ts?to ... 5HUVcBDhEe
2018-06-10 12:21:40,555 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2018-06-10 12:21:40,639 DEBUG [OnlineInputStream] Byte range not supported for http://path_to_online_stream/1847.ts?to ... 5HUVcBDhEe, returning the whole stream
2018-06-10 12:21:43,921 DEBUG [TimeoutStreamDelegator] Closing piped input stream and closing related feeder process
2018-06-10 12:21:43,922 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-122,5,main]
2018-06-10 12:21:43,925 DEBUG [ProcessExecutor] Starting kill -9 403
2018-06-10 12:21:43,932 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2018-06-10 12:21:43,933 DEBUG [AbstractAVTranscodingDeliveryEngine] Removing transcoding job 'transcoding-temp-208c3e6a275c74ab3e94e70bb7c4b5e2.stf' of client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
KO Stream:
2018-06-10 12:16:49,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
2018-06-10 12:16:53,694 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:46263: HEAD /resource/1000003010001441/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:16:53,695 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:16:53,696 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:53,696 DEBUG [ResourceDeliveryProcessor] Request for resource 1000003010001441 and type 'MEDIA_ITEM' received
2018-06-10 12:16:53,696 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000003010001441 (online)
2018-06-10 12:16:53,696 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000003010001441, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:16:53,697 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file http://path_to_online_stream/184.ts
2018-06-10 12:16:53,697 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "http://path_to_online_stream/184.ts": AVC_TS_MP_HD_AC3_ISO
2018-06-10 12:16:53,697 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:16:53 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:16:53,712 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:46264: GET /resource/1000003010001441/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:16:53,712 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:16:53,712 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:53,712 DEBUG [ResourceDeliveryProcessor] Request for resource 1000003010001441 and type 'MEDIA_ITEM' received
2018-06-10 12:16:53,712 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000003010001441 (online)
2018-06-10 12:16:53,713 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000003010001441, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:16:53,713 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file http://path_to_online_stream/184.ts
2018-06-10 12:16:53,713 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "http://path_to_online_stream/184.ts": AVC_TS_MP_HD_AC3_ISO
2018-06-10 12:16:53,713 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000003010001441 (online)
2018-06-10 12:16:53,713 DEBUG [VideoDeliveryEngine] Delivering item '1000003010001441' for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:53,713 DEBUG [VideoDeliveryEngine] Delivering file 'http://path_to_online_stream/184.ts' using transcoding
2018-06-10 12:16:53,714 DEBUG [AbstractAVTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:53,714 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://path_to_online_stream/184.ts
2018-06-10 12:16:53,714 DEBUG [ProcessExecutor] Starting /usr/bin/ffmpeg -fflags +genpts -threads 0 -analyzeduration 10000000 -i http://path_to_online_stream/184.ts -y -threads 0 -c:v copy -c:a:0 ac3 -b:a:0 384k -ac:a:0 2 -map 0:0 -map 0:1 -sn -f mpegts pipe:
2018-06-10 12:16:54,214 DEBUG [StreamBasedTranscodingDeliveryStrategy] Adding client to stream multiplexer: Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:16:54,714 DEBUG [StreamBasedTranscodingDeliveryStrategy] Already multiplexing stream output to client: Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:16:54,715 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "http://path_to_online_stream/184.ts": AVC_TS_MP_HD_AC3_ISO
2018-06-10 12:16:54,715 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-06-10 12:16:54,715 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2018-06-10 12:16:54,715 INFO [PlaybackEventsManager] Playback of media item 1000003010001441 (http://path_to_online_stream/184.ts [http://path_to_online_stream/184.ts]) has started at 0% on Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:16:54,716 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:16:54 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:16:58,490 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2018-06-10 12:16:58,490 DEBUG [WebServer] I/O error: Broken pipe (Write failed)
2018-06-10 12:16:58,494 DEBUG [ServiioHttpService] Incoming request from /192.168.0.103:46265: GET /resource/1000003010001441/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 192.168.0.6:8895]]
2018-06-10 12:16:58,494 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.103
2018-06-10 12:16:58,495 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:58,495 DEBUG [ResourceDeliveryProcessor] Request for resource 1000003010001441 and type 'MEDIA_ITEM' received
2018-06-10 12:16:58,495 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000003010001441 (online)
2018-06-10 12:16:58,495 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000003010001441, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2018-06-10 12:16:58,496 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file http://path_to_online_stream/184.ts
2018-06-10 12:16:58,496 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "http://path_to_online_stream/184.ts": AVC_TS_MP_HD_AC3_ISO
2018-06-10 12:16:58,496 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000003010001441 (online)
2018-06-10 12:16:58,497 DEBUG [VideoDeliveryEngine] Delivering item '1000003010001441' for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:58,497 DEBUG [VideoDeliveryEngine] Delivering file 'http://path_to_online_stream/184.ts' using transcoding
2018-06-10 12:16:58,497 DEBUG [AbstractAVTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre'
2018-06-10 12:16:58,498 DEBUG [StreamBasedTranscodingDeliveryStrategy] Already multiplexing stream output to client: Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:16:59,370 DEBUG [PipedOutputStreamMultiplexer] Caught exception: Read end dead
java.io.IOException: Read end dead
at java.io.PipedInputStream.checkStateForReceive(PipedInputStream.java:262)
at java.io.PipedInputStream.receive(PipedInputStream.java:226)
at java.io.PipedOutputStream.write(PipedOutputStream.java:149)
at org.serviio.external.io.PipedOutputStreamMultiplexer$3.call(PipedOutputStreamMultiplexer.java:87)
at org.serviio.external.io.PipedOutputStreamMultiplexer$MultiplexCaller.multiplex(PipedOutputStreamMultiplexer.java:119)
at org.serviio.external.io.PipedOutputStreamMultiplexer.write(PipedOutputStreamMultiplexer.java:89)
at org.serviio.external.io.PipedOutputBytesReader.processOutput(PipedOutputBytesReader.java:58)
at org.serviio.external.io.OutputReader.run(OutputReader.java:47)
2018-06-10 12:16:59,371 DEBUG [PipedOutputStreamMultiplexer] Removing client from multiplexer: Identifier=192.168.0.103, Profile=Sony Bravia TV (2011), Name=TV Chambre
2018-06-10 12:16:59,498 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "http://path_to_online_stream/184.ts": AVC_TS_MP_HD_AC3_ISO
2018-06-10 12:16:59,498 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2018-06-10 12:16:59,498 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2018-06-10 12:16:59,499 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Sun, 10 Jun 2018 10:16:59 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/1.9.1,transferMode.dlna.org: Streaming]]
2018-06-10 12:16:59,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.6
