Sony Bravia KDL 40W600B : Can't access Media on Serviio
Posted:
Wed Jul 11, 2018 5:54 am
by lehuybao
Hi everyone !
I am a newbie.
This is a fisrt time I have a post in forum.
I have a problem is as follows:
Everyone can help me solve it, please !!!
P/s: My laptop : Serviio 1.92 with Windows 10 _ 1803.17134.112
lehuybao.
Re: Sony Bravia KDL 40W600B : Can't access Media on Serviio
Posted:
Wed Jul 11, 2018 12:45 pm
by atc98092
Further down the same page, there is the network settings. Make sure that bound IP address is the same as you see there in the status window. From that address, it appears you are not using a static IP address on your laptop. It's best to use a static IP when a computer is acting as a server, so devices can always find it with the same address. In fact, your IP address seems awfully high in the range for being a dynamically assigned address. Usually the last digit (yours is 240) is far less than 100, and often as low as 3 or 4.
Next, confirm your other devices are all on the same IP address range, meaning the are all 192.168.1.something different. I've seen laptops continuing to use an IP address from a previously connected network, and might be in the wrong range. Since your device list only shows the Serviio computer, that seems suspicious, as my list shows almost everything on my home network, including devices that never connect to Serviio.
Posted:
Wed Jul 11, 2018 1:14 pm
by lehuybao
Thank so much Dan !
I'll try its.
