Post Wed May 18, 2022 8:22 am
Video stutters and is poorly controlled on Sony KDL-32WD603
hello. there is a problem with playing video files on the TV, as it stutters and is poorly controlled. That is, I rewind, the video freezes. I watched the load on the PC, then, no more than 40%. Linux is worth it. TV 2016 series.
nikolanp@rosa2021 ~/Video> ffmpeg -i Storks.mkv
ffmpeg version 4.4.1 Copyright (c) 2000-2021 FFmpeg developers
built using gcc 11.2.0 (GCC) 20210728 (ROSA)
configuration: --prefix=/usr --enable-shared --libdir=/usr/lib64 --shlibdir=/usr/lib64 --incdir=/usr/include --disable-delete --enable-libaom --enable-postproc --enable-gpl --enable-pthreads --enable-ladspa --enable-libbluray --enable-libtheora --enable-libvorbis --disable-encoder=vorbis --enable-libvpx --enable-libxcb --enable-libxcb-shm --enable-libxcb-xfixes --enable-libxcb-shape --enable-runtime-cpudetect --enable-libfdk-aac --enable-libdc1394 --enable-librtmp --enable-libspeex --enable-libfreetype --enable-libgsm --enable-libcelt --enable-avresample --enable-version3 --enable-proprietary --enable-nvdec --enable-nvenc --disable-libopencv --enable-libopenjpeg --enable-libopus --enable-libsoxr --disable-libxavs --enable-libmodplug --enable-libmp3lame --enable-libass --enable-gnutls --enable-libcdio --enable-libpulse --enable-libv4l2 --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-version3 --enable-libx264 --enable-libx265 --enable-libvo-amrwbenc --enable-libxvid
libavutil 56. 70.100 / 56. 70.100
libavcodec 58.134.100 / 58.134.100
libavformat 58. 76.100 / 58. 76.100
libavdevice 58. 13.100 / 58. 13.100
libavfilter 7.110.100 / 7.110.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 9.100 / 5. 9.100
libswresample 3. 9.100 / 3. 9.100
libpostproc 55. 9.100 / 55. 9.100
Input #0, matroska,webm, from 'Storks.mkv':
encoder : libebml v0.7.7 + libmatroska v0.8.1
creation time : 2016-12-20T09:16:53.000000Z
Duration: 01:26:57.82, start: 0.000000, bitrate: 17394 kb/s
Stream #0:0(eng): Video: h264 (High quality), YUV420P(Progressive), 1920x804, SAR 1:1, 160:67, 23.98 fps, 23.98 tbps, 1k tbps, 47.95 tbps (default)
Title : Storks (2016)
Stream #0:1(rus): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
Title: AC3 (Dubbed) Blu-ray NORDiC
Stream #0:2(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s
Title : DTS (Original)
Stream #0:3(rus): Subtitles: Subtitles (default)
Title : Russian (Forced)
Broadcast #0:4(rus): Subtitles: Subtitles
Stream #0:5 (English): Subtitles: Subtitles
